I noticed it has been a while since you have posted your dilemma. In case you have not figured it out, I have a 2001 beetle, and might be able to help you. There are two circular pieces of plastic on the inside of your trunk, opposite the taillights on the outside...they should be black and sloped. These pieces pop off, giving you access to the lamp. All you have to do is push the taillight out from the inside (by means of a weird protrusive, funny-bent wire). There, you will find the wires and the housing for your lights, which simply unclip. Make sure when you replace the light, you tighten the lens back on to your car. Good luck... now off to find out how to fix my electrical problems!
Hope I could help!
Amanda
I have a 05 Beetle GLS, I think someone stole the headlight cover, the plastic piece is missing. Does anyone know if the whole headlight needs to be replaced or maybe I can by the plastic piece that fits over the top? The dealer wants $385. to replace head lamp. THATS OUTRAGEOUS! I would appreciate any advice.
Thank You!
BEE08
The female connector plugs for all of these controls have the same design and each can connect to any of the five control’s above. The wiring diagram does not show the detail to make the correct selection and mating connection. The female connectors are difference colors: Light Green, Burnt Orange, Light Brown, and two black.
I attempted to logically connect these to the controls based on wiring and the mating number of connector pins. This resulted in multiple fuses being blown. The only connector I believe is connected correctly is the Emergency Flasher, #3 above, this connected to one of the black connectors.
Can anyone tell me the correct colored female connector to each control ?
This is the 1st time on the forum since my post. It was the ignition switch connector and wiring. There is a defect in the design, they undersized the wiring. Had to replace switch connectors and wiring. VW refuses to recall. This is a result of the fog-lights wired through the ignition switch. Overload of wire size. there have been a few small fires I have read on line. My wiring was burnt involving 3-4 wires and melted plastic.
Anyone know why? or How I can turn off the alarm without opening the hatch?
Thanks so much for your help!
Has anyone had this problem - not sure where to start but after looking at the fuse diagrams Im thinking it might be the clutch pedal switch starter lock relay - anyone know anything about this, where it is located or if Im even going in the right direction?
I just had the same problem with my 2003 bug. Before this happened, I had my alternator and battery replace than this happened. Did you ever get the issue identified and fixed?
anyone knows a easy and cheap fix ? eben unlocking it with the key will still "flash the lights"
Ok, for starters, I have a 2004 VW Beetle GLS 1.8 turbo...
It all appeared to start out as my a/c going out. It was still blowing, just not cold. So my dear husband figures he'd add some freon to see if that fixed the problem. Needless to say, that didn't fix the problem.
So of course, being that he's a man and loves to dismantle things to see how they work, he proceeds to check my fuses. He notices one of the 3 fuses under the hood seems to be shorted out. It had even left a small burnt spot and appeared to have melted a tiny part of the rubber around it.
After installing a new fuse, all hell breaks loose! Not only do I still not have cold a/c, I now have indicator lights coming on that have never came on before (EPC and BRAKE lights), I lost the temperature side of my time/temperature display near the sunroof, my cruise control no longer works and the most irritating part is my car is now making a constant low fuel dinging noise when I get above 5 mph (that's the one that's slightly longer than the seatbelt ding).
I've only had this bug a little over a year and am quite unhappy at the trouble it's caused me so far. It seems that I'm replacing either a headlight or a tail light once or twice a month. I'm almost at my wits end and hope someone can shed some light on what's possesing my car.
power steering to stall while driving. Other symptoms include the brake lights to remain illuminated, sunroof to stay open after switching to close position, very dim headlamps, door lock features are faulty, no radio, and the worst condition of this is the fuses mounted on top of the "new" battery are brittle along with the ground cable completely gone.
REMOVE RETAINING CLIP TO REMOVE OLD BULB FROM THE HOLDER...
REVERSE PROCEDURE FOR INSTALLING.
Lore from MS
1. Battery is old and near the end of its useful life. If it is about 4-5 years old, you may want to consider getting a new battery.
2. A short somewhere in the car, whereby the battery is being drained when the car is not running. This could be almost anything.
Best bet is to take this to a shop such as Pep Boys or Sears or somewhere that sells batteries and have them check the electrical system. They will tell you if the battery is old and not holding a charge properly. They can also look for a drain on the battery, if that is happening when parked.
BelAIrCarGuy
Anybody had this happen or heard of it?
Also been told to drill a small hole in reservoir bulb to allow this overflow to travel elsewhere.
Any thoughts friends?
I have similar problem: mangled switch in key sender drained key's battery.
Now replaced battery and disabled alarm, but car still won't start.
