General Intake / Exhaust Mods
I'm concerned about a previous post regarding K&N's direction to disconnect the battery to reset the computer. No where in the instructions does it mention disconnecting the battery. Shouldn't the electronic sensors automatically adjust for the air flow? When a stock air filter becomes dirty over time, doesn't the sensors adjust for the restricted air flow? Something sounds fishy with the posts regarding reduced gas mileage. My mpg have gone up slightly, but probably only because I replaced a very dirty air filter!
Yes, over time the car's computer would *eventually* readjust on it's own -- but by disconnecting the vehicle's battery to reset the computer, you are essentially forcing it to reprogram itself IMMEDIATELY to the current engine conditions, so you'll see the effect now, rather than having to wait for it.
When I put a K&N air filter and a cat-back exhaust on my 99 Jeep Grand Cherokee, the tech suggested doing the same thing --disconnect the battery so that the onboard computer would re-adjust for the increased air intake and reduced backpressure... It made sense, so I did it -- and saw my MPG on the trip computer jump by 3-4 miles per gallon after my first tank of gas.
http://www.autophysics.com/cones.html
When I ask at car stores around here, I get strange looks -- this happens a lot as I often ask for things that I think should be available but aren't. One guy was useful though and advised never to use PCV tubes for this purpose.
It would be cool to find some that can be bent at an angle, or better still, already bent at an angle.
any educated guesses?
BTW,
what is the impact of having a greater flow of air into the engine?
increased HP?
increased mileage?
Recently, I found my car gets fewer mileage, do you think this is related to the dirty filter? (I changed my oil religiously and check tire pressure on the weekly basis and use brand name gasoline). Please help me out. Thank you
Chris
b_dunn12
Ever heard of Kia and Daewoo? Are those considered on the higher quality or lower quality of products being produced in South Korea? One Korean company that DOES produce worthwhile products is Sam Sung. So yes, I do know what I'm talking about. They are smart enough to know that Americans will buy just about anything that sounds good, even if it sounds too good to be true. Maybe they learned this from GM?
And I'm curious to know what Sony has to do with Korea? Even if Sony products are manufactured in Korea (SEK), the products must still meet Sony specifications. Do you know what SEK stands for?
Steve
www.perfomanceint'l.com. Lowest price and quick ship!
A happy customer!
Also comparing K&N to standard air filters, what does -30 C. air do to the tacky oil that K&N provides for their filters--does it become hard as one drives along at 70 mph creating a huge windchill. Would one have to use a different oil or perhaps even a standard filter with no oil. Sorry for all the questions -- I just seem to be full of them tonight. I would appreciate it if someone could enlighten me or if there are any sites on the web with any info.
As for web sites, try www.howstuffworks.com
Yes,there are! For example, if there are too many O2 molecules in the fuel/air mixture, much of the energy available to do work actually goes into heating the excess O2 molecules, i.e., the engine runs less efficiently.
There should be an optimum mixture of fuel and oxygen. It's not clear, to me, what the net effect of cold air should be without more detail.
tidester
I think the stock airbox with a freer flowing filter might do the trick.
Next question: Does a K&N with particles in it flow more or less freely than a paper filter after same time period?
Is this all just a bunch of hype???
There wasn't a smiley :-) , so I am not sure if you were serious or not.
Urban legend file.
So intake air being cooler DOES increase engine efficiency, but does NOT always give better gas mileage...kinda weird huh?
Good mornin
Rando
A clogged fuel filter does the same thing, doesn't hurt anything as long as fuel flow is low, but at high flow rates it can start cutting down on flow when engine needs it the most.
I had the K&N on my 92 Civic, and would not do it again. It made more noise than power. (Friends said it sounded like a v8, but just laughed because it went like a Honda!)
I now have a Jeep, but will use the OEM filters, just change more regularly.
I put the K&N filter on my 95 Blazer and 99 ZR2 just to have a theoretically better flow filter but mainly to avoid buying several air filters over the life of the vehicle. I usually buy vehicles new and keep them till they rot so getting lifetime stuff
(brake service/alignment/air filters) usually pays for itself,,,so far it has anyway. I never really expected any power or mileage gains, and so far I haven't seen any either. I doubt that I would notice any power improvement, I don't do the jackrabbit thing, I'm a pretty easygoing driver. Something else, 65-75 mph is still about 2200 rpm in those trucks, probably wouldn't notice anything until you really got a good bit higher rpm than that.
As an example, put a bandana over your face like the old cowboy train robbers and take a walk-no problem, now go running and see how it restricts the air when your breathing hard, then you would see the difference...air filter/fuel filter/oil filter...same thing.
Unless you keep the vehicle for a long while it wouldn't pay for itself at all. We used to turn the top of the air breather cover upside down on our trucks back in the 70's, made LOTS of noise doing that too, that brings back memories!
You confirmed what I have observed. It makes no power difference for all intents and purposes.
Maybe in a race track environment where it is at full rpm all the time, and you don't care about certain other things, it might make a difference.
But to buy it for performance...???
In all fairness to K&N there was no claim for increased MPG. It possibly may have some benefit under loaded conditions such as pulling the 30' Award travel trailer. That is the main use for the van anyway. Also winter blended fuel may be a contributing factor to poor mileage at this time.
I got the K&N gotta have bug from the Olds. Intrigue site, as it is always an in demand item there since K&N does not list a filter for the Intrigue. A lot of owners purchase a non listed K&N for the Intrigue. Sort of reminds me of a child instinct for candy, if you can't have it the more you want it. I even put one on my 2000 Alero 2.4 liter. Another waste of money.
I disconnected the battery and shorted the leads.
Picked a spot at the service station and filled the tank to completely topped off. Took a short 60 mile highway trip and fueled up in the exact same position to topped off completely. The mileage was 25.3 mpg. This is not a real world test as I was trying to determine what was going on and maximum mileage. I drove a nominal 60 mph for the test. The normal loaded mileage at 65 to 70 mph has been 20 to 21 mpg. But my daughters and family's got that ridicules 17.86 mpg on a 500 mile rt.
I had done things trying to get better fuel mileage.
Mobil 1 in the differential.
Semi synthetic in the transmission.
TOYO 800 ultra tires at max rated 44 psig.
Lubricated brake calipers to reduce drag.
Use Mobil 1 10/30 in the engine.
Fuel mileage is only for bragging rights anyway. I have always spent more in trying to obtain better mileage than than the fuel advantage will ever return.
If you are really trying to get good gas mileage on the vehicle you are probably driving it pretty easy, easy start, easy stop...you can get a vac gauge and install it in the dash. Light foot gets high vac and gets better gas mileage, it's a constant reminder to watch a leadfoot...
and also use the lowest octane gas that does not ping.
oh yeah, back to topic, the K&N filter should not make any noticable diff in the gas mileage, so enjoy the freedom of not changing it very often.
Fire was actually discovered huh, never would have believed it...
Auburn Chemical Engineering 1984
Good luck
Most of the claims are anecdotal and most of the gains are psychological. People spend $40 to replace their $7 paper air cleaner and they want to believe they got something for their money so they "feel" the performance difference.
P.T. Barnum had it right.
But I can hear the deeper breathing under full acceleration and extra noise means extra HP, right! That is what all the Hondas have with those pipes and big open mufflers they add on. Or maybe with the Honda it's the dished wheels and 45 or 55 series miniature tires. They must run like a real performance vehicle with those changes.
