Toyota Camry EGR valve "Check engine light on"
I have a 2001 Toyota Camry 4 Cylinders
that has the check engine light I took it
to Autozone for the free reading which
it came out the EGR Valve I bought and replaced
it but after two days or so it came back on
again Does anyone know what the problem could be?
then someone told me that it could have been
the Throttle Position Sensor I replaced it and still
have the same problem?
thanks for ya'll help
abe
abe
You'll be zero'ing in on the problem.
EGR Valve. is there any way to test if I got a bad EGR Valve?
thanks.abe
It appears from your posts, that AutoZone converted the error code for you to the first item on the potential cause list which was EGR. Doubt that the new EGR would be defective. You need to expand the problem focus area.
You can google the error code.
flow insufficent
abraham
- EGR valve stuck closed
- Open or short in VSV circuit for EGR (that's the Vacuum Switching Valve)
- Vacuum or EGR hose disconnected (or clogged, or cracked)
- Manifold absolute pressure sensor
- EGR VSV open or close malfunction
- ECM (that's the main engine computer)
Check your Carspace mailbox for additional assistance. Goodluck, and let us know how you make out.
did you ever find the problem with your Camry? I'm having the same problem. I also took mine to Autozone and got codes P0401 and P0402. I was about to go buy an EGR valve until I read your email. I just bought the car two days ago. I'm afraid the owner could not resolve problem.
Thanks for any help you can pass my way.
Alan
I also have the same problem. I have a 1998 Toyota Camry with the code P0401 and bought a new egr valve. After about 60 miles on the car the same code pops up again. I have failed emission test twice already. Also I drove my car about 200 miles and all the monitors on my car still haven't reset itself. Somebody please tell me why? Any suggestions??
Pat
My Camry is a 2002 and it wasnt the vsv valve but i found the part i needed by troubleshooting. This is the part for my car. WVE 5S2037 it says in the description of the part it could be the part you need if you are getting a p0401. The 2000 camry the guy in the Youtube video was working on needed a new vsv. like the guy above said you can test it by checking the ohms of it
