Ford Mustang Transmission Problems
1356
  • ramamoeramamoe Posts: 2
    :sick: HELP,,I am having a hard time locating a part. Does anyone out there know where you can pick up a stock shift linkage for my 2007 V6 5Sp T5 tranny?? Ford wants to sell me the entire shifter assem. for $600.00 Can. All I want is the linkage. It is a 3/4 " square steel rod about 10" long with to studs at either end. Or is there an aftermarket linkage that will work Thanks Guys and Gals in advance
    RAMAMOE
  • moronixmoronix Posts: 29
    I would try junkyards. Must be a wrecked one somewhere. Search internet for recycled parts.
  • try cj pony parts .com they might have it .....
  • when my five speed is in nutral it sounds like it is grinding and soon as you push in the clutch it stops. whats up with that ?
  • contact the BBB auto defect department they will be a big help ... good luck... :lemon:
  • Hello: I'm running into similar issues with a 2009 GT I just bought in August. The trans is louder then how I think it should sound. Bought it back to the dealer twice and the technician stated he hears something but wasn't ready to say anything was wrong. He did comment that he thought the sound was coming from the trans. He sent out an inquiry to Ford to see if there were any other complaints and supposedly Ford said no. After reading these posts that response sounds like alot of bull. I notice this problem more when the windows are up and it sounds like the noise is coming from the floor on the passenger side. For the first couple of weeks I drove it around with the windows always open to better hear the rumbling of the engine. Since it's been getting colder the windows have been up more and now it's more noticeable. Not a clunking sound but more like the gears get louder, especially in second gear. Get's louder when I accelerate and rpms go above 2,000. I love the car but this sure puts a damper on the whole purchase. I may just bring the car to my own mechanic who also installs transmissions to get his opinion.
  • remember its under warranty,if someone tampers with n e thing and ford finds out,well you know what that means.im on my second mustang,i had 07 and now the 08,i am still having trouble with tranny at times,im keeping this one,just wish ford would come clean.same issue as the other one,noise in transmission during shifting,not as bad as the 07 tho,but still there.gonna take advice and call BBB.GOOD LUCK,
  • I was driving my pony when I tried to shift into 5th it was like it was in neutral and when I got home after driving all the way in 4th I found that I couldn't shift into reverse please someone tell me this is not going to be something major
  • im sure by now you have a answer to what happen.what year tang do you have?
  • I have an 05 mustang v6 automatic transmission. I've never had any problems out of it until the other night. I was stopped at a red light and pushed the gas to go and the RPM's jumped really high like to 5000. The engine reved really hard. At that point it wouldn't shift out of 1st gear. I rode in 1st to the nearest gas station and parked it. It will not go into reverse and it will not shift to neutral to be able to push it any where. Originally thought it would be out of transmission fluid and though I haven't had it checked recently (been told you have to check it from the underside of the car which is also where you fill it up) my car has not leaked any fluids, no lights have come on, nothing on my message board, and no problems while driving. I have no idea what could be wrong. Does anyone have any ideas before I get it towed to the dealership? I don't want to go in blind and get charged for something that might have nothing to do with the problem.
  • Go under your car and check your vacuum hoses and transmission modulator. since not knowing your car history or care, may I suggest replacing your vacuum hoses and transmission modulator anyway? Had similar problems years ago! Good luck!
  • hi guys
    the other day I started the car perfectly, waited a few minutes and left home.. I heard like the revolutions on my car went up but I thougth it was cold still. I stop in a sign and when I tried to go on it just didn't. couldn't go backwards or forward.. nothing but the engine still work
    no lights came on to warn..
    We checked the transmission fluid but it was good. I took it back to the dealer and they said it was the transmission, we changed it but the problem still.
    can you tell me what it can be...
  • dbm3dbm3 Posts: 1
    Changed the automatic transmission fluid and filter in my 2005 Mustang today. Its the first time anyone but the factory has been in there. Looked OK except for one big surprise. There was a piece of black plastic tape in there sloshing around, about 5 inches long, an inch wide and kind of crinkled up like plastic does when has been hot. Has anyone else seen something like this? This kind of concerns me, and I changed the fluid/filter early at 60K vs 100K as it has started to 'think' a second or two longer than normal when moving to reverse.
  • akirbyakirby Posts: 7,911
    That method doesn't change all of the fluid. It's recommended to use the dealer machines that suck out and replace the fluid using the cooler lines. This gets 95% of the fluid out including the torque converter whereas dropping the pan only gets about 2/3. There is no need to change the filter - if there's enough stuff to clog up the filter the tranny is already toast.
  • Ford screwed us, but we fixed the problem. Ford knows of this issue and hides it.
    The problem is the SAME as our 2005 GT where pitch went way up after 40mph and got lounder and whinnier the faster you went.....it it was a noisy ring and pinion set witih pinion and carrier bearings. Total cost $500. Could have been done under warranty but Ford kept saying..."that's the way it's supposed to sound."
    Bull ____. Hope you don't have the same problem, but if you do it is a warranty issue.
  • 1996 3.8 V6 Ford Mustang transmission slipping.
    I have a 1996 3.8 V6 automatic Mustang with somewhere around 150,000 miles on it. Today it was 8 deg outside and I started the car and headed down the road. Well it started searching for gears and would shift up and down the spectrum.
    Then it would kick out of gear or slip (not sure) then start searching for gears again. I never had a problem with this transmission till today. Do you have any ideas?
    Wait until the temps go up or put it in the garage to warm up and see if it still happens. Something could have frozen temporarily.
  • o10mustanggto10mustanggt Posts: 1
    edited August 2011
    Ok im seriously about to **** a brick my brand new gt is 3 months old with 8,000 miles and out of no where my trany deff took a ****. i took my car in for an its second oil change at my ford dealership yesterday at 1 everything was fine. i drove the car home and a couple times that evening. today I left my girlfriends house get out of the development and its fine get on the main road shift 1 through 5 no problem . . . then all the sudden as im coming to the light down the road like 1/2 a mile i hear a weird whistling noise(thats the closest description i got) i try to downshift to 2nd while slowing down . . . . i cant shift out of 5th!!!! so i stop at the light with clutch depressed and turn the car off. i finally manage to force it out of 5th with car off into neutral only i can only move the shifter side to side and up i cant go into 3rd 4th or reverse. so i turn car back on and force into first pull away it makes weird grinding noises but i can drive and i shift into 3rd same thing weird grinding noise but works. i still cant get into 3rd or 4th at all. i try shifting into 5th it goes but as soon as i let out clutch it just revs up like in neutral. so i had to drive all the way home using 1st and 3rd thankfully not extremely far. DOES ANYONE HAVE ANY IDEA WHAT HAPPENED TO MY CAR!!!!!???? of course this happens on a Sunday when the dealerships closed :mad:
  • look at my postings,the 07 i had and the 08,both 5 speeds and both of them problems,ford is ,(i think) not telling the truth.also i notice my stearing was off center, the rt door is off center,gt emblem is off center and the rear bumper is off some,and over spray on my gas lid.and the odomator was reading 5 mph to fast.hum,well they reset the toll and said nothing was wrong with the odomator,but it was reading different after i left,for the bodie stuff they say it was a factory thing,and would strighten it out for me.sounds to me like its been fixed.but i bought it and the other one as a new car.and i also hear noise in the drivetrain from time to time.
  • ilcooljilcoolj Posts: 14
    My friend has a 2006 Mustang GT with 43K, bought it brand new and now auto trans. is slipping bad. He's had vehicle serviced regularly by the dealer but did not extend his warranty. '06's are all Lemons, so much for the S-197...
  • darleydarley Posts: 2
    The manual transmission on my new mustang is very noisey at best, but when driving on the freeway for a while in 4th and 5th it starts this high pitch whistling noise, the head mechanic at the dealers heard it too and agreed there was something wrong, the manager decided to change the transmission without even letting the mechanic even look at it.
    Got the car back and they said it was fixed.....and guess what it is still there and even worse, anyone else had this issue?
    Did you get this sorted out, read my post about my new 2010 mustang, the same whistling sound after a few miles in 4th and 5th, they changed the transmission without even looking at it, and its even worse now.
    Let me know asap.
    You need to take the car back to the dealer and ask them to install 2 dampers that eliminate the whining sound. The bolt on the rear differential allowing to absorb the noise coming from the rear axles.
    Probably fell off the truck, my '06 probably did when i got me from the dealer, I saw that the L/F gap between the hood was more and the other side left. 2 years later I barely rear ended a guy and the paint on the bumper just chipped and flaked off. My body man told me the car had been hit before, problem is how can you prove it once you drive away from the dealer?
  • I have a 1996 ford mustang manual transmission making funny noises can anyone help me
  • sstati23sstati23 Posts: 1
    Did you get that problem solved?
    I just bought a 2010 Mustang V6 a week ago and I started hearing a humming/whistling noise when I am in 4th/5th gear also. My car had less than 100miles on when I started hearing it. I am not sure where it is coming from but when I hear it, it seems to come from the center console/gear box. Again, I am not sure if the sound is just been tunneled in from outside.
    Does it sound similar to your situation?
  • dlercherdlercher Posts: 3
    I have a 94 mustang gt and i installed a 95 transmission out of a cobra
    is there anything else i need to change or do to dial in the transmission and i want to replace the speed sensor do i buy one for a 94 or a 95 and do i have to change the board on the car?
  • ponyboy3ponyboy3 Posts: 2
    I have a 2007 manual 5 speed, and have the exact same problem in 4th and 5th, and as i read other posts their are many people with the same problem. To me its seems to be a design flaw, i cannot see that can be a desirable sound. A gentleman on this site mentioned putting in dampers to deaden the sound. My understanding of the problem is that their is no sound deadening in place and because the set- up is aluminum casing the noise in cab is very noticeable. at least that was the way ford explained it to me. I am writing a letter to ford to explain that this seems to be a common problem with many people. If that doesnt work and i can find evidence of a safety issue i will contact nhtsa @safercar.gov and will encourage all who will listen to do the same. I love my stang and would love to see this problem resolved. Good luck
  • ezshift5ezshift5 West coastPosts: 855
    The very positive reviews of the new V-6 2011 Mustang have both surprised and delighted me. My last Ford was a Sunliner with the 312-inch TB Special V-8.
    Does the new V-6 get a new (and hopefully improved) 6M transmission?
    My current 6M (out of Marysville, OH) is damn near flawless (with a GMSFM assist), but planning ahead won't hurt.
    all the best, ez....
  • reddenredden Posts: 2
    edited May 2010
    the transmission will not come out of park. the button on the shifter will not go down all the way in. the steering wheel is not locked either. yes pushing down on the brack... Well thanks for the info....
Ford Mustang Transmission Problems - Page 3 - Car Forums at Edmunds.com
