Toyota Camry Hybrid Safety Concerns
When we first got our 2007 tch I noticed a faint unpleasant odor. Over time I have associated it with moisture in the AC. I started garaging it with the windows open and ran it at 80 deg til it warmed up as advised in someone elses post. I had the cabin air filter changed because of the odor a month ago, no help.
Yesterday it began smelling like chemicals when the ac compressor runs. I now leave the compressor off for fear of having a bad heat exchanger. Has anyone had similar problems . Is there a tsb out on it?
It did make me sick. I am no longer experiencing the symptoms I
had. This was my personal experience. I did not come here with
an agenda. No further answers to my post are necessary. Thanks to
all who offered me assistance. For those who answer with argument
against concerns of my post, you are wasting your time. I did not
post this to "flame" those who staunchly believe in hybrids. I solved
my very real issue. The End.
That is not true of the hybrid batteries. Each terminal,is connected to the electric motor (and charging circuitry.) Although they are not intertwined like house wiring which is 220 volts center tap and which are no longer intertwined in fuze boxes, junction boxes and wire pull boxes. The hybrid battery wires are physically close enough to cancel EMF's. look at how close he contacts are on the motor.
In any case the Emf's basically cancel.
As for the induced magnetic fields they are described in Maxwell's Equations. Firrst, there are no magnetic dipoles. The Delta operator times the B vector field is zero. There are magnetic field generated by a wire carrying current, Each wire induces a magnetic field according to,the right- hand-rule. If the thumb is pointed in the direction of the current, the magnetic field lines will be in the direction of the curled fingers. If you do that for both wires from the hybrid battery, current is going in opposite directions, so the magnetic fields cancel.
