Buick LeSabre Brake Problems
I just changed the rear brakes and rotors. I first used a C-Clamp to compress the piston but then realized you have to turn them (I used needle nose pliers). I was able to turn them a couple of times, put them back on, depressed the brake, then turned it a couple of times more. They turned fairly easily, so I don't think I stripped the thread (if that's how the calipers are nowadays). I did both sides. Now, as before, I just drive around the block, press the brakes a couple of times and the rotors are extremely hot (to touch). Is this normal? Or should I buy new calipers? The fronts are the same, very hot. They are not wearing excessively by any means, but the previous rotors were warped, I think. The car is a 2000 Buick LeSabre with 80,000 km on it.
Thanks in advance,
Rob
Thanks in advance,
Rob
wheel sensor. Please advise how to locate sensor. Also Engine Light staying 'ON' sometimes goes away but will come back 'ON' Please advise how to resolve. :confuse:
How many miles are on the brake pads and how has the car been used? Highway driving? Town driving with lots of hard stops?
The brake pads (originals) have a metal tab that is supposed to start rubbing on the rotor a while before the brakes wear out. THis is on the outside pad. It makes a soft, strange scraping sound. Sometimes the inner pads wear more than the outer. They don't have a warning soundmaker.
The rust didn't hurt the rotors because the car was driven occasionally and never sat for months without driving. The rust would rub off the first time the brakes are applied.
The fluid doesn't have anything to do with noise or brake wear. It should be changed every few years by bleeding out the cruddy stuff near the wheel end of the lines. A competent mechanic shop will do that.
Your calipers wouldn't cause that. It's something about the contact of the pads and the rotors.
I know the replacement pads I put on my car had the front and back edges beveled at a 45 degree angle that was to keep them quieter... That's why I was tactfully asking if your pads might have been very inexpensive and didn't have that when they should. Or they might be too hard.
Are you having any other symptoms that might make you think the calipers are a problem? Dragging? Pulling? Overheating? Pulsating?
You'll have to decide what you're hearing. I'd suggest having someone drive the car slowlypast you in a parking lot to listen for the noise from outside.
Calipers were only $30 each at AdvanceAuto recently for my 98. I broke a bleeder screw and just went ahead and replaced both rather than having the bleeder dug out or doing it myself with screw extractors.
Maybe I am a stupid lady, but how do I know he is truthful?
If the rotors aren't rusted where the brake pads touch them after you've driven the car, there's no problem. If they are rusted, why is he selling you defective rotors that rust year after year would be my question to him.
Find yourself an honest location. Maybe you can use a dealership.
The thing is he never shows me, he told me that it can not pass inspection with rusty rotors and he would submit it as failed.
He told me he could "cover" the cost of the pads because they are under warranty for under 12,000 miles. But he will not pass
me for the rotors. I asked him if there was something wrong with my car and why would that happen and he said, "I don't know". Last year, and the
previous year they told me they would fail it for the same reasons, and I asked about the pads both of the times...I asked if the rotors are so bad and
must be replaced, then the pads must be a wreck too, right? AND both times he told me the pads were fine. I feel he has me by the short hairs, ouch!!!
These are only the things he said I need for the inspection!!!!
And, I told him I forgot to fill the front tire with air, it is a bit low...he said he did not check THAT. And he never said a word about the windshield wiper he sold me 6 months ago that tore!!!
Brakes are on sale there now.
I was told by other people that recently went there, and they keep having to replace rotors too. But if we don't he charges us 16 dollars for the failure.
Any comments on this shhooossh shhooossh shhooossh brake noise when driving and the shhheeeeeeeeeeesh when the brakes are applied? :mad:
My guess is the Emergency Brake mechanism is not totally releasing on this wheel but I'm not sure where to start with repairs.
Is the problem at the wheel and if so won't I have problems pulling the drum off?
Just trying to get a handle on where to start with this problem. Thanks.
If it has drum brakes on the rear, were the emergency brakes set while it was parked? (A no no.)
If so I'd try pulling on the cables next to the brake to try ot get the cable inside the outer housing to move a little or the linkage inside to move.
Otherwise you're going to have to take the wheel off and try to get the drum off of that side. It may take some moderate force to get the drum to move over the brake shoes if the emergency is stuck on. Or it may be really difficult or next to impossible.
If it can be moved backwards that may release some pressure on the brake shoes.
Emergency brakes tend to not work as well in reverse as forward; the forward movement helps swedge the secondary shoe against the drum for more braking.
If it's a disc rear brake, just take the wheel off and see what's happening.
Any chance it is a wheel bearing? You'll know that as soon as the jack the car up and rotate the wheel if it's making that much of a noise.
It's a standard for GMs of those years. Earlier used a torx head socket (1993, e.g.) Later uses standard sockets.
It is made to be rotated to retract. I bought a small cube like "tool" at one of the auto box stores. It fits a 3/8 in. socket handle and has points in different formats on different sides to "grab" the recess on the face of the piston.
You CAN turn the piston with the ends of a shorter needle nose pliers using them to press on the face of the piston.
FORCING the piston in with a C-clamp will DAMAGE the operating parts that are the emergency brake. When I checked, rebuilt calipers for the rear were $129 at Autozone, so I don't want to damage one of those.
Also be sure to leave the recesses in the face of the piston vertical so the points on the back of the brake pads go into the recess.
Page 5-67 for 2003 FSM
"Notice: When using a large C-clamp to compress a caliper piston into a caliper bore of a caliper equipped with an integral parking brake mechanism, do not exceed more than 1 mm (0.039 in) of piston travel. Exceeding this amount of piston travel will cause damage to the internal adjusting mechanism and/or the integral park brake mechanism.
1. Compress the piston until resistance is felt, but no more than 1 mm of piston travel.
2...."
The factory technicians should know how to repair it.
Good luck with your rear adjusters or parking brake mechanism. I hope they are still working correctly for you.
Myself, I'll use the factory-approved procedure, which I spoke about in the previous post.
Check the brake fluid level in the master cylinder to see if the volume has dropped.
Then try just pushing on the brake pedal with the engine running and hold it steady in pressure. See if the pedal slowly goes on down. That most likely is a the fluid in the master cylinder leaking around the piston seals.
I believe this requires professional checking. It's a safety problem.
I would think moving the car would work. But it doesn't! Next would be JB Blaster sprayed between the drum and the rim. And then heat to expand one more than the other to crack the corrosion.
