weird new 07 forester
charleyliu
Member Posts: 7
Our new 07 forester is weird sometimes:
1)when I start up the car, I feel obvious shaking from left to right, which is not normal when I drive others cars.
2) when I stop at a red light or a stop sign, I hold the brake, then when I lift my feet (but not hit the gas pedal), I feel that the car just stall there. There is no trend to drive forward.
3) When I stop at idle, I feel some vibration in the car, even my seat is vibrating.
The car is only drived for 20 miles. Are these phenomenon normal for a new forester? I mean are there any other new foresters that do not have such problems. If they are normal, then what's the cause ?
Please helps! We even suspect our new car is a lemon.
The side to side shake, and vibration is normal for the Subaru. It is a 4 cylinder boxer-style engine. This means the pistons strike out horizontally and can shake the vehicle side to side on a start, and also at an idle.
I've got an '07 Forester X and have rented a few other Subarus and all do this.
Does your engine stall? Or does it not move forward when the brake is released?
As far as the stalling goes, I would get it checked.
--S
"Yes, We get an auto-tranny. We didn't feel much vibration from steering wheel but a lot from the front seats, is that similar to your experience?"
-mike
I have got the same problem (#1 on your list) on my brand new 07 Forester, plus I also hear some unusual noise from the engine on cold start.
I am planning to take my car back to the dealer today.
Did you get any answers from your Subaru dealer?
Please let me know.
Thank you for feedback.
I took my "lemon" to the dealer.
Car is there for more than week now - they are trying to fix the problem. I know it is not normal, I had Forester before. Meanwhile I am getting round arounds from SOA. I am very frustrated with whole experience of buying new Forester.
Good luck with your "lemon".
Is there any way you can take your Legacy to the dealer at the same time as the Forester to give them a side by side comparison? Good luck!
Kyle
I called the dealer and they suggested driving it for another two weeks to see if the problem works itself out (not the response I was hoping for). Have any of the previous posters had any success with an explanation from your respective service departments concerning this problem?
That'll reset the program and it'll run rich at first, then slowly lean out the fuel mix as it learns your driving style. But at least you get a fresh start right now, as opposed to two weeks from now.
The symptoms make it sound like it would be the spark plugs, plug wires, or maybe even the ignition coil, but it's so new that I have trouble believing that's what it is. Plus you're not getting any misfire codes.
Looking back, I sadly sold my 2004 WRX (that had ZERO problems!) for a new 2007 Forester 2.5 X, to save on insurance and gas prices. Sure wish I could jump back into a WRX, but it's not in the cards right now.
So, here's the breakdown and I'm curious if anyone else has had issues with their 2007 Forester? One of my friends has an identical one and hasn't had any.
2007 Forester 2.5 X (non-turbo) Premium Package, Automatic
I've been driving it for 1 year, 1 month.
It has 27,000 miles on it (trips, 50 mile round trip work commute, weekend driving).
1) At 15,000 miles the sunroof stress fractured. = Subaru replaced under warranty.
2) Since day one, the low gas light comes on at 1/2 a gallon left in the tank instead of the 2.5 gallons the manual states. During an experiment I ran out of gas. = Yesterday Subaru replaced the fuel sensor/leveler under warranty.
3) Four weeks ago when starting my engine it would run very rough and even while at idle on the road after it warmed up. The Check Engine light came on and the code read: "Camshaft Circuit Sensor Malfunction". = Subaru said some wires were loose and tightened them, under warranty.
4) Last week the same engine roughness started occurring and two days ago the Check Engine light came on. = THIS TIME Subaru comes back and says I need new Catalytic Converters!!! They'll be replaced under warranty... but at 27,000 miles?!?! What gives? They have no clue what's causing the problem.
I swear, Subaru is rebuilding my car like it should have come from the factory. My concern is at this rate I'll be out of warranty in 2-3 months. Then what? Expenses out the rear?
The only "modification" I have is a basic K&N air filter, replacing the stock filter. Friends have had it in their cars for years, without any issues.
Thoughts? Much appreciated!
(I think I'm going to look at getting another vehicle. It'll definitely be a Subaru... maybe even another Forester.)
The day I bought it.
One other time for a recall.
That's it. I sold it to a private party, and did all the maintenance myself.
You're just not lucky.
-mike
I'm on my 2nd Forester with over 130k combined miles and the only dealer trips have been for a couple bad oxygen sensors replaced under warranty back in 2000. Oh yeah, I had a loose airbag sensor under the driver's seat a while back too.
What? You been burning grain alcohol or something?!?! :P
Well at least you'll still have the 5yr/60k powertrain warranty
-Frank
Len
