Mazda MX-5 Miata Electrical Problems
My 1997 Mazda Miata headlights stopped working in the open position. The lights still operate but the raise and lower actuators do not. I checked the fuse panel for the obvious but need help in diagnosing this problem.
Sorry, never worked on the pop-up headlights. At least you can still use them. Imagine if they were stuck down!
I had lights burn out within a week of each other, and this was after 7 years of use!
thank you
Blaine
keli
If anyone has had this or similar difficulties, can you tell me what you did to fix it? Where is the regulator located. The repair book doesn't mention it so we assumed it was internal in the alternator, the parts store has a part, but we can't find it. That is about the last thing we have to check or replace, so where is the dang thing located?????
thanks,
Lisa
Schmoogey
Incredible coincidence, really.
John
I took it straight to the dealer who has now had it for several days. They test drove it (and of course there was no repeat occurence), flahsed the computer (making the warning lights go away), but still have no idea what happened. They are checking the Mazda "Tech site" to see if there are any other reports of the problem.
Has anyone else experienced this?
Check the bulbs by your right knee, that's the easiest one to access.
Guy couldn't find out polarity of battery to jumpstart it. While he is looking, the trunk light suddenly goes on. Whoa. I've only had the car a few weeks. Car had only been on for a few minutes. It has only 11,000 miles, garage kept, super clean.
Total enigma. I've noted others stating that they've had their car suddenly die, and come back to life later. The AAA tow truck guy did nothing. His battery was sitting near my battery, but he never hooked it up. 45 minutes after dying, car started as if nothing was wrong. Help. I don't want this to happen on a highway or other bad location. :surprise:
My engine started misfiring - BADLY. It sputtered at certain RPM like I've never seen.
First I checked the timing, but that was OK. I thought it might have been knocked out of the right timing setting since my Miata was hit last week (again).
Then I replaced the wires, and sure enough, they basically fell apart when I was taking the old ones out. Half of the connector came off on the spark plug, even though I had used boot grease.
Replaced those, and the spark plugs as well, and she's running like new.
fyi: regulator is integrated into the alternator
I replaced both the batt & alt. also the cooling fan relay
have had both the new batt & alt bench tested twice. both good
I have a problem with my MX5 and I think it may be electrical.
I have an erratic idle when stationary, sometimes upto 2000 rpm, when accelerating the engine is hesitant, but if fine as the revs increase. Sometimes the engine just cuts out completely, mainly when stationary. Every now and then I have a strong smell of petrol from the exhaust and at times white smoke, I do not think its coolant getting onto the system as my coolant level has remained the same. I have replaced the plugs but no change, next thing is to change the spark plug leads as i understand MX5's eat thru leads! Also after fitting the new plugs the engine would not start at all. When i took them out plug one and four were cover in black soot. I have had the plugs out a number of times since and have not had this problem again.... Any one have any suggestions?
Thanks - Steve
Anyone got any suggestions?
Does this mean my aiternator is broke or is this suposed to happen
its driving me mad
help
Both use brake fluid, but there are two containers to check.
Another thing - open the cap, and make sure it's not just a stain and but actually the real level of the fluid itself.
I had a clutch slave clyinder go bad, but the fluid level for the clutch kept getting low, which you have not observed.
If you take the battery off now the car still runs so it was the alternator after all
woo hoo
