Volvo S80 Suspension
I have an 2001 S 80, T6, with 74K miles. I love the car but have had an issue with it since I bought it in 2004. I hear random clunks, pops, and bang noises in all 4 corners. I can't recreate the noises, they just occur randomly. But they can be loud! I have had the dealer inspect it a few times always telling me that everything looks okay. But its driving me nuts. Anyone out there have any similar noises? Any Ideas what it could be? Seems too early for strut replacement...
But this time the noise is coming from the front - every time the car sets off from rest. The local garage (I'm using a local guy as my dealer is a long way from here) thought it was an engine mounting bush. Well this hasn't fixed it. So I've suggested the front shock absorbers - we'll see if that fixes it.
It's clearly a common problem. At http://www.volvo-forums.com/index.php?showtopic=7763&hl=suspension someone suggests a torn strut mount. But the garage say they've checked all that stuff. So I'm hoping the shock absorbers will do the trick.
Any updates on your problems?
1) Check the rod ends that connect to the sway bar. The sway bar in front and rear have a rod end about 8" long on each end of the sway bar, 2 in the front and 2 in the rear, inexpensive and easily changed.
2) Check the body bushings. The car is a sub-frame unit and has body bushing tying the frame to the actual body. Not too expensive, somewhat difficult to change.
Loosing coolant on the T6?
Inspect the coolant overflow hose at the block connection. This is easily done by any reputable mechanic. All the air induction tubes to the turbo have to be removed, remove the shock tower stabilizer, then remove the timing belt inspection cover, upper first, then lower. The lower is difficult to remove, due to the connection of the hose to the plastic cover, you have to disconnect the hose from the resovior, then from the cover, it is a quick disconnect fitting (poor design).
Upon inspection, you will find a "Plastic" elbow the hose is connected to will be slip fitted in to the housing and will be cracked or broken and leaking. You can obtain another plastic fitting at any parts store, small overflow hose, and clamp.
The plastic in the housing will have to be removed. I used a 6" carbide burr and a cordless drill to remove the material safely, then slip the hose on your new elbow and install in the housing, thread the hose through the lower timing cover and reconnect to the overflow resovior and re-assemble.
kp
fyi, i had my coolant flushed today as well. so far no coolant leaks for me 98k miles.
john
1. Since the beginning, when the car was new, it did not have a good turning radius and since I replace the original tires, the tires rubbed the wheel well.
Volvo's solution: To replace "wheel stops". I have paid numerous times (about once every 6 months) since replacing the original tires (Volvo says it is not a warranty item, extended or not) to correct the problem. I was told by the service tech that this is a common occurance, it sounds strange to me that this is "normal" and everybody has to replace the wheel stops.
2. The transmission has been replaced, under extended warranty right after the manufacturer's warranty expired and the extended warranty went into affect.
3. There has been a knocking noise under the front left (driver's side) floor board for over a year now. I have paid for Volvo to find the noise 5 times at $200 (totalling $1,000 for the extended warranty deductible) since April of 2009 and in February 2010, I complained to the service tech, service manager and owner of the dealership, so they "fixed" the problem with no charge to me ($200.00). Volvo kept the car over a week so they can duplicate the problem and try to "fix" it. It is May, 2010 and the vehicle has been making the knocking noise under the front left floor board since about a week after they "fixed" it last. The noise is now occurring on the under the right floor board as well as the left. The knocking noise occurs sporadically and is hard to duplicate when test driving with a tech, though it has been done and thus the guessing game begins to find the problem. The knocking noise occurs under varying conditions such as going straight, making turns, turns in the road, going over slight imperfections in the road, bumps, slow, fast, pulling into the garage, etc., it 's just very random. Yesterday I have asked the dealership to get in touch with the manufacturer and have a representative sent out. While on the phone with the service manager, he studdered when I suggested the rep. Can anyone help find the solutions to the issues?
I would recommend that you personally call the Volvo customer service hotline.
The hotline will put you in contact with a Field Service Engineer. This is an excellent way to get the help you are looking for especially when you feel you are not getting solutions from your dealer.
I received excellent help and rectified all issues since going this route.
I was truly impressed with the Field Service Engineer. It was so great to finally have someone who was there to listen and take the time to get all the pieces of the puzzle put together.
I hope you get the answers and have your Volvo functioning properly soon. Best of luck.
I bought my car second owner and was purchased used with roughly 75,ooo on it. It now has 132,000 on it and it's all highway miles. I drive 50 miles a day to work.
Since I've owned it for the last two years I've sunk well over $8,000 into it!!! And I'm still paying on it Nothing worse than having a car you owe on and then to dish out well over $8,000 more into it...... Can you say VERY Upside down on a car's equity????
Both front lower control arms
Sway Bar and Linkage
Both Front Ball Joints
All new struts and mounts around the entire car (Yep all 4)
Rebuilt Transmission at 128,000!
Ignition Coils
Multiple Alignments.
Now the car is again making serious squeaking noise in the right front wheel area when I go over bumps. It's so embarrassing to be driving a "Volvo" and have it make this noise. My buddies laugh at the fact I'm driving what is supposed to be a top notch safe car and it's always in the shop. When I bought the car I was going to take it to a Volvo Dealer but the nearest one from my house is over 30 miles away so it makes that not feasible.
I have been getting most of my service from a very reputable local garage, but it seems every time I fix something another thing just pops up. I tell ya I'm going broke on this car. I hate to cry about this but an average consumer can NOT afford to have these issues with what should be a great reliable car....
I complained to Volvo Headquarters and a guy did call me back. He said shame I wasn't taking it to a volvo dealer because then he would be able to help. They offered no assistance with transmission because I was 28,000 miles over the extended 100,000 warranty.
I tell ya if you, I used to love driving this thing. Comfortable and quick and great on gas, but man it costs way to much money to upkeep. Sorry, but not sure how much longer I would be pushing the "Volvo For Life" slogan.....
Spankey
