Thanks for any insight...
Keyless entry: You can change how the doors unlock by doing the following: Turn power switch off, when the indicator on the key surface is turned off, push and hold the panic button while pushing the lock button for about 5 secs. This will cycle the car through different lock features. There's about 6 different modes and you have to wait 5 secs before trying another mode. (pg 43 in owner's manual)
For voice control: Press talk switch>help>operating guide>tel. Follow instructions on the screen. To cancel, press and hold talk switch, press phone on steering wheel, say cancel, and then press cancel. (pg 286 of owner's manual)
Gas mileage: hard to say because so many factors influence it. How's your maintenance? -new air filter? tires inflated to correct pressures (esp. because of winter)? changed the oil? Do you have low rolling resistance tires? Aftermarket tires? Aftermarket wheels? Wheels and tires will have a dramatic affect on your MPG. What about your driving style? When you want max MPG, braking is your enemy as well as fast starts. You can achieve 50 MPG but you will be the one everyone is passing on the freeway. You should be able to expect 42 to 48 MPG though for average conservative driving. Make sure your not carrying around unnecessary weight in the car because it will affect your mileage quite a bit.
Last, look on ebay and try to get yourself an owner's manual. You'll know your car a lot better. Good luck and I hope my answers help you out.
