Toyota Prius Engine Problems
2
    bwilson4webbwilson4web Member Posts: 80
    There is a common problem with a sticky throttle plate after 3-4 years. Every fall I clean it and no problems for the rest of the year.
    Sticky Prius Throttle Plate
    Bob Wilson
    stevegoldstevegold Member Posts: 185
    Is this a common problem on the 2004-2009 Prius? I've never heard of this before.
    Wool948Wool948 Member Posts: 5
    Thanks for your input, starting the engine is not the problem, it just shuts off while driving at high speed.
    chazz5chazz5 Member Posts: 3
    My Prius has 65,000 miles on it and it is a 2007. I was waiting for my wife and I had the dome ( interior) lights on and the radio on. I went to press the start button and the car would not start.
    No dash lights would light up. My key fob would not lock or un-lock the doors I had to do that manually. My interior lights and brake lights would work, but no dash lights and the car just would not start.What could the issue be anyone know?
    Prior to starting my car, my 2 year old was near the gas, break peddles. Could I have over looked the emergency break being pushed in or could this be another issue all together
    This has happened to my 2004 twice. The fix is to jump the small battery located below the trunk floor FROM the special terminals located under the hood. All it needs is enough juice to fire up the computer. After the first time, I fixed the front cigarette lighter to be on all the time and bought a small 12VDC booster battery from Autosport. Plugging that in will start the car if you remember to keep the booster charged.
    Thanks, but what do you mean by having the front cigarette lighter to be on all the time I don't understand.
    typesixtypesix Member Posts: 321
    Common problem on many cars, not just Prius. It's carbon buildup on the throttle valve.
    I found the issue.
    My 2 year old was playing near the gas and break peddles and must of hit one or both buttons underneath the steering wheel. One button says ( Key) the other says (Reset). I never use my Key Fob in the so called Key ignition so I put in the key fob and pushed in the Key and Reset buttons and pushed the start button and the car is running fine now.
    cathie2cathie2 Member Posts: 2
    I'm responding to Wool948. I have had a very similar situation, but not with the gas light. The last 2 weekends I've been driving approximately 86 miles one way. On the way home at about 133 miles all of a sudden all my dashboard lights come on and then the car kind of "hiccups" and I lose all power. The first weekend I had it towed and they had the car for 4 days. They said they couldn't figure out what it was and looking at the warrenty work, only 2 other cars came in with a similar problem and never returned again for it. So I picked up the car. The next Saturday night I went to the same place and again on the way home, it started it again. At 65 miles an hour the car dashboard lights came on and the car 'hiccupped" and then lost power. This happend 3 times on the highway because I was so far away from home, I wanted to continue to drive it as far as possible. Everytime it happens it's taking longer and longer to re-start. The dealer came and towed it again. They are now saying they think it was the "crank saft sensor". I have to tell you, once this is fixed, I'm trading in the car. It is totally unsafe and I will not feel comfortable taking it on the highway again. There is one other issue, while I'm at it, if you are where there is snow, be very careful. If you go into a skid, you lose power and can't get yourself out of it.
    I hope this helped. Tell your dealer to look at the crank shaft sensor.
    Cathie
    dono0034dono0034 Member Posts: 1
    A few days ago my 2001 Prius (147,000m) started running hard and vibrating pretty bad anytime I hit 60mph, today it seems to happen at 50mph. It's an automatic, but almost feels like it's not going into the appropriate gear for that speed. All the fluids are filled and tires have recently been rotated. Not sure what this could be, any ideas??
    Not sure what you mean by running hard, but anytime I hear about a vibration appearing at a certain speed I think about an out of balance tire/wheel. Since you just had a rotation done, a wheel weight could have been dislodged, or a tire might have some unusual wear that's now causing a problem once it got rotated from the back to the front of the car.
    Can you give a few more details on "running hard"?
    Cathie2, thank you so very much for responding to my email, I will certainly mention it to the dealer.
    whitey9whitey9 Member Posts: 138
    Go ahead with the Mobil 1. Save your money and delete the Slick 50.
    Change oil AND filter at 5K mi. Drain while at operating temp ( the engine that is ).
    kdhspyderkdhspyder Member Posts: 7,160
    Yes this certainly is the solution. The KEY button turns off the 5 proximity sensors of the SKS ( in your manual early on ) including the sensor inside the vehicle that actives the engine when the SKS fob is inside.
    You'd use this button also is you're going to leave the vehicle undriven for 4 weeks or more so that the 5 sensors don't run down the small 12v battery in the back. Upon your return you'll need to use the SKS fob as a normal keyless remote fob in order to get back into the vehicle, release the KEY button as you did, and reactivate the 5 sensors.
    heriksonherikson Member Posts: 1
    2005 Prius - Had a regular dealer service at 46k and they said the belt to the water pump pulley (the service invoice just says drive belt, v-ribbed) was cracked, needed to be replaced. 1000miles later the
    coolant flow control valve went bad. 200 miles later the belt
    shredded. Replaced belt, thermostat, coolant, did diagnostic - no further issues.
    I picked it up today and it didn't get 10 miles before apparently shredding the belt again. At least, when you look in the engine on the left side there's an obvious pulley and no belt was there. The engine really overheated and the same 3 warning lights came on - overheating. I'm having enormous problems getting the first service dept. to take responsibility. The national customer service is helping in baby steps. All this and I've got the top extended warranty but no one wants to just call the whole mess a warranty issue. Anyone have belt problems?
    You need a software upgrade for an old TSB. No charge.
    Computer misreading a sensor keeps the engine from starting and then the traction battery runs out 3-5 minutes later. Could happen at highway speeds. Got a lot of press four years ago. TSB=no problem.
    jonniedjonnied Member Posts: 9
    Vehicle: 2005 Toyota Prius
    Current Mileage: 187,000 Miles
    Dealer Proposed Action: Replace the recharable battery ($4,300), run diagnostic and possible replace Inverter for another $4,200)
    Here’s my predicament…
    Where do I start...?
    I purchased a 2005 Toyota Prius New...it currently now has 157,000 miles on it. Was driving through the desert to Vegas and my light on the dash turn on (check engine light, vsc, red (!) ) and then my air con goes out...not good for a newborn in the car. Brought it to Fletcher Jones Toyota of LV. Told me that my Inverter water pump went out. $600 dollars later and back in Cali the next day...my lights turn on again. Take it to Hooman Toyota of Long Beach..stated that they just forgot to reset and didn't find anything. Same day in Corona, CA....light turn back on. Take it to Quality Toyota. Told me that the actual Inverter needs to be replaced for like $4k. I was hesitant and then drove it for about a month. On my way back from Van Nuys, lights turned back on and then I started to lose power on the freeway until it stopped completely. Weird thing was that a week prior to this occurring, when I was driving in San Diego, I noticed that the energy monitor was at full bars, which is very unusual; the newest development was that the engine would not turn, even at complete stops and the battery fan located near the rear seats will not turn off.
    After cooling the vehicle for a few minutes, it would start moving again, but would die out after a few miles…engine would have a high idle and then the car would no longer accelerate.
    I then got the Prius towed back to Quality Toyota of Corona expecting to get the inverter replaced, but after doing another diagnosis, they told me that the rechargeable battery need to be replaced. They also mentioned that they will not know if the inverter needs to be replaced until they replace the battery, run a new scan and if it shows that the inverter comes up faulty, then I will need to replace the inverter as well.
    I contacted Toyota about the issue and since I surpassed the 150k miles, they cannot warranty neither the inverter nor the battery. The battery alone is about $4,400 w/tax and labor and another $4k plus tax for the inverter. Not sure if the prius is worth saving at $8,400…even if I do have a carpool sticker.
    Any thoughts or suggestions on what just might be happening for Toyota seem to be very questionable about their diagnosis. Any assistance is greatly appreciated!!!
    Hey Cathie 2...I just posted for the first time for I had the same exact issue and I was trying to see if any other ppl had the same issues. If you read my post earlier, I have a 2005 Toyota Prius w/ 158k miles on it. The first time I got it diagnosed, they told me that it was the inverter and that it would cost $4k for a new one. I waited for about a month for I was skeptical and then my car did the same thing yours did...it hiccuped a bit then the engine idled and then slowed down and died. The only addition I had to this was that a week prior, the engine was hiccuping, but also the engine stayed on...even at stops and in traffic...the battery cooling fan stayed on and never shut down. I got my vehicle towed to the dealerhship and I was prepared to pay the $4k for the inverter, but they did another diagnosis and told me it was not for sure the recharable battery. That alone will cost $4,200 plus tax...then they will re diagnosis the vehicle and see if the inverter is still needed.
    SO PLEASE...if you have been diagnosed with another or cheaper way than my diagnosis...then I am all ears! Hope your diagnosis works for you and then I can try that vs doing my route.
    Also if you are under 150k....Toyota should warranty the recharable battery & I think 100k for the inverter...so if it is...you might want to relay this to the dealer and see if this can get replaced on your vehicle.
    Hope this helped!
    Thanks for the heads up steve. I looked into that as well...so I went with the lesser evils vs swapping out the battery. I took cathie2's advice and getting the crankshaft sensor replaced for 300 bucks and then getting the software updgrade for 100 bucks. Since I am over the 100k, they won't offer the free upgrade. they told me if I replace the battery, then they will install the upgrade for free.
    Well if this fixes the problem, then Toyota HQ will hear an earful for I have an open case with them about this situation. My service director indicated that those were not the issue and that the codes pointed to the battery and inverter replacement. Will find out today.
    Thanks for the reply and will keep you posted if it works or not.
    Hi Steve,
    Just got the update...replaced the camshaft sensor and got the software upgrade...the tech actually thought it did the trick, but after a few miles and going up a hill...car started to hiccup again and flashed the dash. When he got back, codes were saying that it was still the recharable battery. Well it was a $400 dollar experiment, but was alot better than hitting that $4k initial price tag. Any other thoughts or suggestions are duely appreciated.
    JON
    Recently got a system upgrade for my '05 prius w/157k miles on it. Also got the camshaft sensor replaced. It sort of worked...
    Toyota Tech is telling me that lights came back on and still reporting that the battery needs replacing.
    I did a test run tonight and ran the car for over an hour at 80mph. Hiccuped a few times during acceleration, but held all the way. The main difference is that my energy moniter is acting more normal. Before the service, it was at fully green capacity...to the top for an entire week...not much power being transferred to assist the engine. That is now in the blue range which is working good.
    The same or bad thing is that my engine continues to run while I am at a complete stop...a really slow idle, but never turns off any more. The other issue is that my recharable battery cooling fan in the back seat does not turn off. I am still contemplating on switching out the battery....I am also considering doing an aftermarket upgrade that will give me the first 60 miles on electric and then shift it over to the hybrid side...more costly, but feels like i'm tossing away my 4k with another toyota battery. PLUS, thier warranty for the battery is unlimited miles for up to one year. What happend to the 100k warranty...so if this fails after a year again, then I'm back to square one.
    Sorry...just venting because this is the fourth dealer I went to...all with different outcomes....prius techs or just people guessing at the codes that pop up on the screen...your guess is as good as mine!
    johnwyojohnwyo Member Posts: 8
    To see if your HV Battery is ok, run your engine while in Park, and watch the display that shows your green battery. It should charge up to all green. Another check, run engine in park for 10 minutes, then shift to drive. The engine should shut off, and it should be powered by electric power at slow speeds, if your battery is in good shape, and charging system good shape too. Oh, need to shut off air cond., defroster, heater, and accesories, and lights before testing.
    This is the first serious battery problem that I've read about. I think the 100K mile guarantee has to cover more than one year, If you drove that much, they'd disallow
    coverage on the grounds that it was commercial usage.
    Try getting a Toyota rep to come to the dealer that was most cooperative.
    I had a serious question when my 2004 was new and Toyota sent a rep to Glenwood Springs, CO, to drive my Prius up a long mountain pass side by side with the dealers demo to see if I had a real problem, which I did not. I now have 55,000 miles with the understanding that my battery is still under warrantee.
    Sorry, I don't know what caused your problem, hopefully they got it fixed. I live close to, and have driven thru mountains, and live in alot of cold weather,, with no problem as far as mountain driving. I have other problems, not related to high altitude. Cold weather needs a well charged up 12 volt battery,plenty of fuel in the tank to prevent ice forming, and a clean air filter cause of less oxygen.I just learned to doing that from living in a cold climate for many moons, I mean many years. thanks, johnwyo but those two things I don't think, would cause what you experienced with your car.
    I apologize, I do not have advice to help. If I could ask some more details, Does the car have greatly reduced power, when it runs electric power only
    I would make sure all my tires have enough air in them. Then, if it vibrates at only at a certain speed range,10 to 15 mph consecutive, range,ex. vibrates from 55 to 68 mph, that can be a tire out of balance. Need to have tire rebalanced. You could put your spare tire on each tire, until you find which one it is. Alot of work, but i'm dumb enough where I have done it myself. Or, have a friend follow behind you, and try to spot a vibrating tire. In your steering wheel ,(vibration), then your front tires. I gave you some of the more common causes, there are other causes, but usually occur with car with well over 100,000 miles, and driving thru many potholes, mabey over a curb or two, HA HA anyway, johnwyo I ran over a curb or two in my day.Still do.
    davidwcdavidwc Member Posts: 1
    My 2005 Prius with 80K miles has done the same thing (same symptoms, always on the freeway) four times starting in Dec 2009. It is at the dealer now. The last time I took it in (Jan 10) this dealer consulted Toyota and they "recommended" replacing the the fuel pump, which requires replacing the gas tank and costs $1000+. The dealer's service supervisor offered that they were not sure it was the fuel pump and suggested driving it in the hope that they could diagnose it with additional information. They did not mention replacing the battery or inverter.
    This isnt much help, but it sounds like the Toyota Supervisor was being honest in trying to figure out the problem. Does your check engine light come on? If it does, if you could go by an Auto Zone and ask them to check the code from the check engine light, (for free). I would hesitate to have a battery and inverter replacement. Sounds like possible plan for extra profits. (My personal opinion)
    revitrevit Member Posts: 476
    Be careful if you own a Toyota Prius, even those that have not yet been recalled:
    Police Help Stop Runaway Toyota Prius
    shay2shay2 Member Posts: 9
    MY 2005 PRIUS HAS 69k MILES. RECENTLY NEEDED NEW WATER PUMP $600 AND NOW NEW ECU $2,000.
    i WOULD LIKE TO KEEP THE CAR BECAUSE CAN NOT AFFORD SOMETHING ELSE AND AM AFRAID OF GETTING ANOTHER TOYOTA. WOULD YOU TRY TO GET A SERVICE WARRANTY AT THIS STAGE OF THE GAME? WOULD ANYONE GIVE IT TO YOU? HOW MUCH DO THEY RUN? I AM JUST AFRAID OF MORE THINGS GOING OUT.
    THANKS FOR YOUR INPUT
    Hi There,
    I have a prius that has over 177k...at about 151k, I got my inverter water pump replaced as well. That didn't solve the problem, then they told me it was my hybrid battery. Instead of spending over 4k, I found a third party company that provided both the battery and the ECU for only $2400. Now the dealer installed everything for $800 so total was $3,600...and that is with a new battery. I'm not quite sure why your ECU is not warrantied up to 100k? Also the battery is warrantied up to 150k (which I just missed). (TaylorAutomotive.com...just fyi)
    So...the call is up to you. I actually had to go to four dealerships before they confirmed that it was the battery that needed to be replaced. First dealership was the Inverter, the other was the ECU, the other was a crankshaft sensor....
    Not sure what to say shay 2...you should see what the original warranty covers for I got the platinum warranty and everything seemed to have expired just as the warranty ran out. I would simply suggest get a second opinion at another dealership and see what they find out and go from there.
    agent86agent86 Member Posts: 9
    What is EFI service as it pertains to a 2006 Prius? Is this a do it yourself type work? Also, is throttle body cleaning easy to do and what does it involve? Thank-you
    amyg2amyg2 Member Posts: 2
    We jumped our dead Prius and it started, but then had to jump it again the next day and it didn't start. Had it towed to Toyota where they said it was jumped wrong and we had to pay for a new inverter - $6100 for a 2 year old car - said because we jumped it wrong it was not a warranty repair. No way did we jump it wrong. Anyone else have this problem from Toyota?
    biomanbioman Member Posts: 172
    What did you tell the people at the Toyota dealership that made them tell you that you jumped started your Prius improperly??
    We told them exactly what happened - that the car started the first time we jumped it but not the second time, and no AAA person could jump it either.
    mm517amm517a Member Posts: 3
    When I turn on my 2002 Prius with 63K miles, the engine runs for 5 minutes but the screen shows nothing running. The dealer could not duplicate it. I have it back in today as on Sat. after turning everything off for 1/2 hour when I turned it back on it only ran for 1 minute but the green on the battery on the screen went down 1/2 the way. Anyone ever have this happen? I have to go as my car is ready. Will let you know what they say.
    You should also ask the service rep what test did they perform that led them to the conclusion that YOU did something to void your warranty. Assuming that you did not tell them anything that would indicate that you did something wrong, the onus is on them to live up to the warranty. Don't let this dealer browbeat you in to submission. If you don't get any satisfaction call Toyota customer service or take the car to another dealer.
    axlander1axlander1 Member Posts: 1
    We had almost exactly the same problem arise with our 2005 prius. The check engine light came on at 49K. So we took it in and they replaced the three way coolant flow valve, water pump assembly and belt. The car was running fine so it came as a shock when the price came in just under $1k. Of course the warranty ended in May. This seems insane on a car with less than 50k miles.
    little_pogilittle_pogi Member Posts: 149
    I do not know if you guys have heard about this latest Prius recall. On the 04-07 models, inverter coolant components needs to be replaced since it could result in loss of engine power. This tread showed that a lot of you, Prius owners, have already experience this problem. It also included myself over a year ago. I have to spend over $500 to have it fixed since it was already out of warranty. My question is, will Toyota reimburse me and other Prius owners who have to shoulder this repair expense now that Toyota finally admitted that this is a concern that warrants a recall?
    Those of you you have experience filling a claim, perhaps you can share with us any procedure we need to do.
    The announcement I read said that Toyota would refund prior repair charges in this case.
    I already spoke with my service advisor and he will be putting in a claim for reimbursement. So just go to your local dealership and they will be able to pull up the records.
    I am shooting for the entire repair that I undergone...all the way down to getting a reimbursement of the H2O inverter ($500) to potentially having a new Inverter replaced ($4,000 for the dealership informed me that that might need to be replaced next), to the radiatior I replaced a few months ago ($600) to the hybrid battery I replaced year ago ($4,500). The inverter was the first to go and then they stated that the overheating of the inverter might have caused damage to the other components in which I replaced. So skies the limit to take advantage of any costs that you replaced which was associated to the H2O inverter.
    Hope this answer and others questions.
    J
    graffiti1graffiti1 Member Posts: 1
    My local dealership keeps saying I need to replace the pump. The cost is almost $500. My Prius is a 2005 and no light indicater has come on or do I see any spots in my driveway. Has anyone else had this problem?
    Graffiti1
    The water pump replacement and any related repairs are fully covered under the recent "recall". If you paid for anything related before, you should get all your money back.
    Graffiti1...
    You should contact your dealership again for there was another recall on the Prius Water Pump Inverter. This was actually my 3rd time replacing it...I did spend the $500 dollars initially BUT since there was a recall, I am submitting paperwork to get that dollar amount reimbursed.
    it should be free to you if your vehicle falls under the recall. I too have a 2005 prius, so check with your dealership...if they still say the same thing, then contact another dealership and ask the same question. they should be able to see if your vehicle falls under the recall with the last 9 numbers of your VIN.
    Hope this helps.
    J
    cowkiller36cowkiller36 Member Posts: 2
    Did anyone find out what the park mechanism warning light means? What do I do?
    How do I fix this. I unplug the battery. It stays off for a few weeks then it comes back on. What do I do?
    edited September 2011
    I have a 2004 Prius. This has happened to me infrequently but more than once.
    1. Make sure you get the software upgraded by your Toyota dealer. That should be a no cost upgrade.
    2. I have ALWAYS been able to get it to start somehow, sometimes by playing with the start button which usually worked at least on the 5th or 6th try.
    3. The one time it wouldn't start at all, I disconnected the 12V battery using the underhood red terminal. After an hour I reconnected it and everything was back to normal.
    4. There may have been one occasion (in 2006 or 2007) when even that did not work so I left some lights on overnight so the 12V battery fully discharged. The next morning I jumped that battery with cables and everything was back to normal. There may have been still another earlier problem when I disconnected the hard drive under the passenger seat which caused a hard reboot when I reconnected it a few minutes later. I may be imagining this last solution.
    5. I don't recall this happening again since then. I never had to get the dealer involved except to upgrade the software as mentioned above.
    6. I do need a GPS map upgrade and will probably have to pay $250-350 for them to do that
    krautnribskrautnribs Member Posts: 4
    I have a 2005 Prius and got a recall notice for a water pump, it was installed at no cost. I think it was a universal recall for leaking pumps.
    sljbfamsljbfam Member Posts: 15
    Just got my 2004 prius fixed. The engine was making a load knocking noise when the gas engine turned on and the noise did not go away at all. So this went on for a week then noticed reddish fluid leaking on passenger side, thought it was either transmission fluid or radiator fluid. Took it to the dealer and found out it was the water pump & they also changed the outer belt. And no more noise. Also had the pedal & prius water pump done. So if you other prius owners I have read that have the constant gas engine knocking noise the water pump to the radiator may be it. Mine now has 99,710 miles on it and looking to get at least over 200k on it.
    k_prius2008k_prius2008 Member Posts: 1
    Hopefully someone can help me with this. I just recently purchased a 2008 Prius. The interaction with the Prius has been unique to say the least. i enjoy the car very much however there are problems i have noticed. First is that when I have the car running it has a significant stalling feel. I have noticed it happening at a few different times. The stalling happens everytime I drive. When I have the care idling the car seems to be running on battery them starts the gas engine and when it goes to disengage the gas engine it sputters out as if the engine is dying. Also when I am driving then go to slow at a light, stop sign or anything else that required decceleration it again has the stalling feel. The car never stops running but I am not at all buying that that is just what happened when the hybrid system engages. I have yet to have this looked at but would like to have additional information from anyone.
    Second is the keyless entry.. I have no idea why this is such a pain in the butt but I would like to have my care unlock all the doors since most often then not I am not the only passenger in the vehicle... Oh might I add that this car I go has no owners manual.
    Third is the navigation/bluetooth/voice command system. How do you get the voice system to recognize your voice? I would like to use my navigation and other toys but the voice recognition is not working at all. I am not familiar with the commands but nothing is recognized. It look forever to get the bluetooth to recieve the contacts from my Evo. Now I have to use my phone almost as a remote.
    Fourth and last thing that concerns me is the mpg. My car is currently getting 38.9mpg mixed. Most of my driving is on the highway during rush hour. Traffic has not been horrible so the average speed is 50-55. I know the vehicle is suppose to be getting 48/45mpg. This is a pretty large concern too.
