Toyota Echo Audio Questions
I want to install the Infinity Kappa 693.7i speakers but not sure how to so if anyone can help that would be great. 2000 echo 2 door.
Thanks for your reply
when i step on the brake or use the turn signals, I can here a crackle sound in my speakers?
The radio went off before but all of a sudden came back on for a few months?
I know its a short somewhere and need to find as I travel for work and need music.
Anyone have the same problem or advice?
Danny
The light wires and connections can be easily broken by something in the trunk and cause the short. Take a look from the trunk.....
Found this out after giving up on the original after it went silent, replaced it and had a bad install of the new audio and started to do research and found that the original was probably not the problem. Now the light colors don't match either so the change is very obvious. O well!
He's grinning... but I hope he doesn't go deaf!
Any feedback would be appreciated.
The key turns out, was that my son mentioned the radio would cut out sometimes. I drove it for a while and sure enough there was a random radio short of some type. It would act up the day before the battery went dead. We replaced the stock radio with a nice aftermarket and experienced no further issues. The radio was the last thing even the mechanics suspected.
But if you have a problem like that you can just disconnect the battery at night.
However last December, my radio suddenly stopped working and few days later, I had to change the battery. Then in last 3 months, my battery would die on a cold wintery morning (temperatures less than -20°C). I replaced the battery twice assuming that it was defective battery. However, it is difficult to presume I would get 3 defective batteries in a row. After reading your problem, I think I will change the radio and see if battery is still giving the problem
Peter
Or maybe try another disk?
The fact that the radio portion still works fine indicates to me that the battery change had nothing to do with it.
Good luck and tell us what you do/what happens!
