Lincoln Navigator Power Running Boards
my drivers running board is driving me nuts.......
I have a 2003 ultimate with just under 60k miles.
I also have the extended service contract for only engine and power equipment... No Running Boards
the Drivers Side barely comes out and then does not go back in. it tries over and over but will not go in...
How do I fix this.
How do I fix this.
I would like to see a write up on how to fix this or where to find such information.
Drivers side motor needs to be replaced and track cleaned out... Price $640 ($340 for motor, $300 labor)
I searched for discount parts on the web and found a Drivers side motor for $65 new at a discount Ford Parts House (This motor was just the motor, no housing, housing was $200+)
I called a few other dealers...
1 dealer quoted me $90 for labor, but $340 for motor (no housing)
Incidentally that is what one dealer suggested. It seems like the running board issue prevelent. I saw tons of posts with that pronplem mentioned.
I just spent about 30 minutes on the phone with Ford Customer Care because I think it's ridiculous to expect consumers to absorb the cost of replacing poorly designed automotive parts. Customer Care contacted my service rep who then contacted the zone manager for Ford in this region, and they have agreed to cover $1,300 of the cost of replacing these running boards. My car has 90,000 miles, but has been meticulously maintained, and I don't believe the rust was caused by lack of care as my car is washed regularly to remove corrosive elements. I live in Louisville, not exactly in the snow belt.
I plan to pursue this further with Ford and would like to hear from any other Navigator owners who have replaced their running boards due to rust. My guess is that Ford knows this problem exists, and the faulty motor excuse buys them time until warranties expire.
I'm new to this board I also had the same problem but intermittent with my Gator 03. When it happens, I notice there is a message DOOR AJAR on dash board. So I guess something relate to the driver's door latch/sensor that may cause the problem
Thank you very much for this information. My 03 is doing exactly that. There is no doubt in my mind that Ford is aware of this problem and are faking ignorance. They pretend they are hearing this issue for the very first time when you called them. I am very interested in pursuing this issue. Mine hasn't been replaced yet so if there are others out there who wants to take this further I am in. Once again, thank you for the information.
They know there's an issue. It's always been an issue. However, 90,000 miles is a long time later to expect them to fix anything.
I also have a Lincoln LS and while a great car, there's a design problem with the front sway bar causing it to wear out bushings far too quickly. Ford has redesigned the sway bar but refuses to replace the badly designed ones. It would cost me nearly $1000 to have the properly designed sway bar put on. I dont like that anymore than u like what's happening with your PRBs. But that's the story. I dont know if other mfgs would treat things any differently.
There is a specific rust warranty but I don't know if it's applicable in this case. I'm sure Ford would have preferred to fix the root cause instead of paying to replace all the motors.
As for the fact that it shouldn't happen - of course not. But it sounds like it was due to a design defect that trapped water and not due to poor materials. That could happen on a $12K Hyundai just as easily as a $200K Ferrari.
I had my Driver side boards + motor replaced under warranty (69k miles)
diver side motor replaced but they did not do board.
Thank you for the info on you running boards, I hope others respond as I think there is a hidden issue that Ford/Lincoln is covering up... :lemon:
I know this site has been wonderful in keeping some people linked about this issue but perhaps we should contribute and set up a dedicated and narrowly focused site specifically to campaign for a recall, including going after dealers.
I am suggesting dealers as well as Ford motors because they are assisting the company to perpetuate this fraud of “the issue being isolated”.
This really sucks due to the fact that we spent $60000 for that car and I can't even put up with the rust for more than 4 years. Pathetic.
I thought that I was the only one but now that I see all your comments, it makes more sense. It's happening with all the 03 models.
The funny part is that's happening only on the driver's seat. Why?
We need to do something about that...
The problem used to occur intermittently noticeably after driving in
wet conditions the running board on the drive side will stay out.
When the car in motion the running board would retract.
Because of this my truck continously display the message
"Door ajar".
Another issue I am having is with the side mirrors not
working like it should. When I first start up the truck the
both side mirrors will attempt to position itself but then
appears to get stuck making continous clicking noise.
When I try to adjust with the control it seems like its not calibrating.
For example if I attempt to ajust the mirror to tilt down it will go up and when
I have it tilt right it will tilt left. Has anyone experienced this before.
I really need advise before I pay costly repair fees. I know others can relate.
My truck is no longer under warranty. Even when it was the dealer told me that
wasn't covered. So I'm basically hanging. Please Help!
Another prob i have now and my car is in the shop..... Huge squeaky/gurgle seemingly under car in the suspension. It sounds like a horse jogging with fluid in its gut. You hear it instantly upon putting car in drive. Both at low and high speeds and especially if its bumpy/ in a parking lot. The dealership heard it just pulling out of the service bay. They replaced sway bar and bushings under warranty. I picked it up and didnt even leave parking lot and it was still doing it. They now have had the car 5 days (no rental or loaner vehicle given to me :mad: ) and they say they cant reproduce the problem!!!!!!!!!!!!!! It does it 100% of the time it is NOT intemittant. I swear because i bought the car 50 miles away for $7,000 less (new) they are jerking me.
I already had ABS speed sensor replaced out of pocket (at the dealership I bought it at) for an intermittent breaking failure PERFECTLY described in this forum. I documented this forum to ford headquarters and they still wouldn't warranty it becasue the problem couldn't be duplicated... Well let me tell you i should have sent them the underwear i was wearing the two times it happend.
Can anyone comment on my horrible squeaky chassis??? Nobody can find the problem and its awful loud. :sick:
using that systems button find the catagory for running boards in/ out and set it how you want. I use it often at the car wash to leave the boards out so the guys can spray them or when my mother rides with me otherwise she stumbles over the things.
Duh think not.
Running boards seem okay now tha weather is good but i dont trust them.
Also in reference to using the dash to control them from coming out at all. I read in the book that even if you turn them to stay out that after you go faster than 7 miles an hour they will still attempt to retract. So although you can set them to stay out, it's only if you are going slower than 7 miles an hour. Go figure.
Also if anyone finds out where to get the step pads cheap please post. Lincoln is killing us all on this one it appears.
I called Ford customer service and we are now 20k over the warranty, so no one will do anything. They are just passing the buck back and forth. We met a guy with a 2008 that said he had the motors replaced free before the warranty ran out, so make sure you get them checked and replaced if they are not working properly. We also had to replace the window mechagnism on the passenger side and the air compressor for the suspension.
The running boards have been a huge problem.
I would like to know of other owners that have had similar issues in an effort to have Lincoln repair / correct this issue. The more data collected there may be a chance to have Lincoln correct the issue.
