Has anyone else had this issue?
I have the exact same issue. Thanks.
This mynfirst time buying a car.
: I have recently purchased a 2012 Honda Pilot Touring, that is producing a loud humming noise and vibration when the A/C unit is running.
My case # is N012012-10-2301318
For over nine months now, based on the research I have conducted Honda has been aware of the problem of a annoyingly loud humming noise accompanied by a vibration in the gas pedal and brake pedal when running the A/C unit. I have addressed this issue with the dealership where I purchased the vehicle and was told the problem was due to the bracket holding the power steering reservoir. However, Honda has not come up with a fix for this issue. Today, I contacted your 800 # to get a case # even though my dealership has put my name on their list as well. My concern is very simple. I purchased this vehicle in good faith, that I was dealing with a leader in the automotive industry. One that would not under any circumstance allow any issue to go uncorrected, yet I cannot get anybody to even tell me if Honda is working on the problem, will fix the problem, how much longer it will take to correct the problem or will do nothing about the problem. I find the lack of information to your consumers to be of the utmost concern. If you are not aware of the problem, then you are not listening and or reading about the many complaints about this issue.
I would sincerely appreciate if somebody who is responsible for insuring that issues of this type are addressed, would contact me with an update as to how much longer I will have to deal with this issue.
Sincerely,
A.Michael Scavone
Before I let them do that, I was hoping someone might have some thoughts or ideas as to what the casue could be. Again, I only hear this sloshing noise when I make turns and not everytime, it's only been happening the past month or so, there is no wetness or moisture anywhere on the interior of the vehicle. The only thing thats different the past month is that I've benn running the heater when needed, but i don't smell antifreeze. I feel the noise is coming from the interior center console area but the mechanic thinks its coming from above as in the roof area. Any thoughts or input would be appreciated!
Easiest way to check this is just pull onto a flat surface and jack each spot up and remove the tire to see. If there is one in there then with the suspension expanded due to jacking you can just remove the stone.
Odie
Go to Home Depot and purchase 2 flat rubber washer or o-ring. Find them in the sprinkler department. Lift up and out the radiator reservoir put off to side and loosen the 2 bracket bolts. Removing one bolt at a time, slip a rubber washer or o-ring between the metal bracket and the car's body/frame and reinsert mounting bolt loosely so that you can do put washer behind the bracket in second location. Tighten down and reinsert radiator overflow.
I am scheduled to have my power steering pump replaced on 05/17/13.
I was skeptical about the fix since the dealership called the same day that I sent the letter. However, I was very specific when asking if this was the official fix and they said yes. I think it's pretty new so your dealership might not be aware of it. They need to contact Honda or read the technical bulletins.
The car has been "fixed" for a week now and the noise is greatly reduced. Before the fix, I hated getting in the car and actually enjoyed the cold weather because I didn't have to turn the AC on. Now it is getting warmer (DC area) and I don't hear it that much. You can still hear the compressor cycling but it sounds much more like my wife's Acura than it did before. AC causes some sound in all cars.
I'm still a bit skeptical and won't call it "fixed" until it warms up to the 90 degree weather that we will get soon. But for now, I'm cautiously satisfied.
Still, this is my last Honda!
All noises are gone.
This is the sound (the file in the link):
https://docs.google.com/file/d/0Bz0_-A6q5J6oZnlHSHVEMWlWMnM/edit?usp=sharing
Initially the AC is off, at 50 sec AC ON and at 1:20 min the engine is ON.
Can you tell me what is going on?
Just in case the AC over the hood:
https://docs.google.com/file/d/0Bz0_-A6q5J6oZnlHSHVEMWlWMnM/edit?usp=sharing">
Is coming from the front end not the back end. Is always present and is amplified over 50-60mph. Any ideas?
