Toyota Yaris Lighting and Electrical Questions
A rock had the best of my driver's side fog lamp. I purchased the replacement lamp, and set out in my driveway to pop it in.
Lets just say its a bit of a puzzle under there, has anyone done this repair? If so, what is the trick to getting access to the fog lamp to replace it?
HINT:
• Use the same procedure for both the RH and LH sides.
• The procedure described below is for the LH side.
1. DISCONNECT CABLE FROM NEGATIVE BATTERY
TERMINAL
2. REMOVE FRONT FENDER LINER
(a) Remove the 3 screws and remove the front side of
the front fender liner.
3. REMOVE FOG LIGHT ASSEMBLY
(a) Disconnect the connector.
(b) Remove the 3 screws, then remove the fog light.
(c) Turn the fog light bulb, in the direction indicated by
the arrow in the illustration, to remove it.
Copied this from the Yaris repair manual... sounds complicated. After doing all this, it has to be aimed. Is your car under warranty?
I am still on wtee, but broken lights are not covered...
I have no idea what it could be
Can anyone give me any advise on what could be wrong with it or how to fix it????
Did you ever get to fix the problem with your Yaris? I was wondering if you did because I have a 2006 Yaris with the same problem. If you did fix it can you let me know what the problem was. Thanks. :shades:
