Infiniti I30 Electrical Issues
i have a 2000 I30t infiniti. Can someone direct me to a possible fuse/fix? i accidentally cross/connect polarity and created short while trying to service my clock. Thank you in advance for your help
After a few miles the cruise will deactivate itself.
I would appreciate any thoughts on the matter?
I have taken to to the dealer.....no luck.
I have taken to my mechanic.......no luck
One thing that they have determined is that it sparks intermittently........but cannot find out why it will not start.
Thanks in advance
Paul
I talked to the dealer, but they say that this is normal and refuse to do anything about it. It is somewhat annoying, but I am really worried that it shows the meter is about to break. I had the same problem at about 30000 miles, and showed it to the dealer and they said the same thing then. Then the problem disappeared, but now it is back.
Anyone else out there have a problem like this? Should I push the dealer?
I am new to the forum. 2002 I35 gold, 96K miles, Bay Area, CA. Two things 1) I throw my driver side window button to auto close. The window goes all the way up then back down to some mysterious preset opening setting. 2) I have a 18.7 miles per gallon reading (it never changes) which is a step change from the 21.5 and 20.8 I used to get a year and a half ago. Either the reading is wrong or gasoline formulation has changed. I worked at a Refinery from '84-'97. I love this forum!!
before trying to figure out the problem. Good battery and alternator is the heart for the operation. When battery is bad, it acts along with weather such as dry and warm is good, and cold and humid is bad. That might explains why sometime you have good or bad reading of the battery.
Side light bulbs could be easily replaced when you bring your car to an oil change. I would bring them to Walmart. They should not charge you more than $20 to perform the change since I can do all of them in less than ten minutes. Clock light bulbs have to be bought from a dealer. It is best if you ask the dealer to change it the next time you bring the car in for a service.
If your car head light is an HID, then it needs to be replaced by a dealer as well. If the cost is too high, I would go to a Stereo/Alarm store to put on a pair of aftermarket HID light. They are very nice and can be bargained for less then $250 including installation. Ebay sells them as cheap as $50 a pair kit.
Thanks in advance!
Paul
Pete
The parasitic draw has been a problem for years - 3 new batteries have been replaced in 7 years (on the 4th now). Stereo problems seem to be common in Nissans. See also the Infinity I35 Electrical Issues Forum for a discussion on these problems.
Let me know if you learn more about these symptoms and solutions.
Cheers
also the check engine light came on! knock sensor bank 1 and cat bank 1! after clearing code it came back on with cat bank 1 and bank 2! cleared that code and light came back on with cat bank 1 and knock sensor bank 1!
the car has 62k miles! do i start with the knock sensor or just buy everything?
i cant use high octaine or injector cleaner to clean cat can I?
thanks :confuse: :lemon:
Blackgnturbo@aol.com
http://www.ebay.com/itm/OEM-00-04-Infiniti-i35-i30-Xenon-D2R-Headlight-ballast-H- ID-Igniter-Control-Unit-/200609640193#vi-content
