1994 jeep grand cherokee
i have a 1994 grand cherokee, 129,000 miles, when making a sharp turn such as pulling onto road, or in a parking lot, either forward or back ward, i get this noise in the rear end, , the wheels seem to be spinning at a different speed, ive had the differential service and the oil changed, it helps for a while , but after a few days it starts up again, sometimes if feels like the whole rear end is coming out, it use to do it in the front also, but after service no longer does it, in front, just the rear, the wheels just seem to jerk around help please, david t
If you have experienced it, how do you go about it?.
when you have light on there fault codes in the computer wright them down then let us know what they are then can poss help you
you probably should get the gears in the rear-ends checked.
i just bought the same jeep, and the woman i bought it from said the same things you had said, the noises, etc;. We are in the process of locating a rear end to fix it.
get it checked before you blow the gears out, as it is quite dangerous to drive that way. making sharp turns often cause this problem. assuming that your jeep has quadritrac, sharp turns cause the front and back tires to turn at different speeds and can damage the 4WD gears in the rear-ends, and it will cause the wheels to spin at differnt speeds. Right now, only the back tires spin on my jeep. Hope this helps!">link title
