Toyota Tacoma Brake Questions
linkfeeney
Member Posts: 58
in Toyota
Sorry guys...
I'm going to get a pick up truck, just to move things around and go off-rd sometimes.
I notice the Toyota tacoma has drum brakes?
my 2000 Nissan Altima has drum brakes. When I was looking new cars... pretty much all toyota vechicle has rear disck... so why are they still using it? Is their a huge disadvantage having drum in the rear on a pick up? the new tundra has rear disc. The frontier has disc. Tacoma doesn't... weird... or just cheap?
I was quoted over $500.00 for front brake pads and rotors at the dealer. I assume the cost of toyota original parts is high.
NTB quoted me less than half that. Any thoughts on the quality of your average replacement brake parts vs the TRD parts? Will I pay in the long run for the cheaper parts?
Why so expensive at toyota?
Around 20,000 miles or so, my 2009 Tacoma's brakes started squeaking when applied. Its often squeaks right before it completes the stop. Its also quite loud and embarrassing on a new model. Additionally, right as I apply the brake, I hear a metal 'clink' sound coming from the wheels. (It almost sounds as if the brake pads are loose until the pedal is pressed)
Anyone else experience or know anything about this?
Other than that drum brakes are more than adequate for the lighter duty required of REAR braking.
Replace the pads.
If NTB price includes new rotors then price is VERY good. But they more likely will simply turn the rotors or not bother at all.
I was wondering if you resolved your Tacoma's brake issues. I bought a brand-new 2010 tacoma and at 7,000 miles the brakes began to squeak when applied. Had the rear rotors changed out twice for being warped. Helped the problem for a while then the squeaking returned. Thinking this truck was defective, I traded in to the dealer for a 2011. I have 1900 miles and the same problem is happening with this Tacoma. Did you find out anything about your truck???
