Honda Odyssey Window/Door/Hatch Problems
I can't figure out why this is happening. Everytime I open my drivers door, I hear one ping. There are no lights on dash, no warning signals. Nothing.
I've read thru the manual & it can't seem to tell my why this is happening.
Again it is just one PING, sort of like a bell.
Any one have a clue??
I would guess with yours that somewhere there is something that should be on or off, up or down or in or out. Experiment.
This is just one little bell sound.
edit:
I just read this: "those [beeps] are continuous if you are trying to move the van when the sliding door is open." I'll test this out later.
The sliding door on the drivers side closes ALMOST all the way, then opens...very frustrating! We've just returned from a trip to the snowy and messy roads up north, and I blamed it on some of the road crud getting into the nooks and crannies, but on closer examination, the doors hardware is rubbing the paint off on the side panel behind it. Any ideas? I really love this van other than that! Thanks for any help you all can offer!
I just bought a used 2002 Honda Odyssey. The back door squeaks and rattles when driven over not perfectly smooth roads, and at highway speeds. I tried greasing it, WD-40-ing the hinges and locking hardware, to no avail. So I tied a piece of string on the hook where the lock goes in, which seems to help sometimes. Not ideal. Any suggestions? Thanks!
Also, I have loud clunking noises coming from what sounds like the struts or strut towers, dealer said it was the steering column, they supposedly fixed that as well, but the noise is still there. I'm really worried about the door. This van is only 9 months old! Anyone know about the door issue?
Otherwise, call the dealer - if it's supposed to be constant, then have it fixed under warranty.
The wiper starts moving from the middle of the window where it stops when powered off. It is supposed to start from the bottom edge of the window. What's problem? Could I fix it myself?
Im a single dad with 4, and wondered if there might be a reset on the motor? or something and how to get to it ??
Also looking for the way to remove the lens to replace the 3rd brake light.
Thanks for your help.
Has anyone had this problem and if so, what needed to be replaced or what was done to fix it?
thanks in advance
I'd talk to the g.m, then corporate Honda if not satisfied. Seems to me the latch mechanism could be adjusted instead of springing for a new one. I'd also take it to another Honda dealership for a second opinion.
I'm trying to find out if I need to go back to the dealership or if this is an intentional design.
Don't think they are meant for small kids with little legs who use the rubber seal as their launch.
'Honda Care' (if you can call it 'care') had the nerve to tell me I caused it by continuing to use the door when I knew it was jamming. I had it into the dealer (Honda of Nanuet) in Nanuet numerous times, but of course it wouldn't jam when it was there. The next time it happened was when the door fell off!
I called American Honda and they said that after I had the body work done they would 'review' my situation.
Funny, a few years ago the subframe cracked on my '98 Ford Windstar just after the 6 year warranty ran out. Guess what? Ford paid the full amount of the $3600 repair. Now that's customer service.
I have a 2005 Odyssey and this am noticed a continuous beep while backing out of the driveway. No doors are showing as opened, as I rechecked each. The only way to stop the beeping was to turn off the power door switch next to the steering wheel. I check the contacts on each door and still can't figure it out. Anyone have this issue before?
Kate
