Subaru Outback/Legacy Tires and Wheels
nelgigenflugen
Member Posts: 4
in Subaru
I have a 2001 Subaru Outback that has the Firestone Wilderness Tire but no one has them. They have to be ordered. Is it the best tire for this car or can I go for another brand tire?
The brakes are OK, going to a bigger wheel just gives you more room, even though you don't need it.
The tires may not clear the rear strut base, though. The Outback's raised suspension leaves more clearance for the bigger tires.
I thought Outbacks had 205/70R15 tires back then, though. I thought they went to a 225/60R16 on a 16" rim for MY2000. What is your stock size? 205/60R15, something like that?
Use this tool to see how much the diameter will increase:
http://www.miata.net/garage/tirecalc.html
You can probably go 10mm wider (6mm more radius on a 60 series tires), but not much more than that. There isn't much "slop" in a Subaru, they're relatively precise, so you have less wiggle room for that type of thing.
-juice
you're right. the 16" spec i gave is actually, as it turns out, 2K up.
the tire calculator gave no difference for the speedo - but the real problem, as you said, may be the struts or something else - just eyeballing, it doesn't look like it would have enough space to accept a 205/70/R15.
Take a peek at the rear wheel well, the distance from the top of the tire to the base of the springs. My guess is you don't have anywhere close to a full inch of play in that area.
I had a stock size tire on a Foreser and went 10mm wider. That's less than half an inch, though, and only 6mm wider, and even then it's 3mm on each side.
Yours would be 205-185=20mm wider, 10mm wider to each side, so nearly half inch closer to the suspension plus an inch higher. My guess is it would not clear.
-juice
See more Car Pictures at CarSpace.com
SUVs and Speed Shop
-juice
1. What kind of winter tires would you install
2. What kind of all season tires would you intall and are winter tires overkill for an AWD?
1) Depends on where you live and how you drive and what you are looking for as far as performance. Is comfort and quietness a high priority or is grip?
2) AWD is only as good as the tires. If you can't get traction, then having AWD does no good, you just end up with 4 tires spinning instead of 2. AWD will make poor tires perform better, but only to a point. Again this also depends on where you live and how you drive. For me living in Iowa, snow tires are overkill because I just don't drive in snow that much, a good all season tire works just fine.
-mike
-mike
It also depends on how much you want to spend. Searching on TireRack for a 97 Outback yielded 24 tires with a price range of $46 to $107 each.
one great option is to use Nokian WR tires which are winter snowrated but can be run all year round. I use them as winter tires on my Legacy and all year round on my Tribeca and a minivan.
The Turanza LS (NOT the ELs) are very good all seasons.
I have had them on our '05 Outback Limited ...dumped the original Potenza's after 1,500 kms.....love the Turanza's. They give a smooth ride and are excellent in the rain and snow.
Doug
How many miles have you gotten out of a set of the Nokian WRs?
We've gotten over 47K from the OEM Turanza RE92s.
So, there really could be other factors at play there, but I still suspect the tires were the most significant one with their aggressive tread.
I do think it was worth the trade, though.
On my Legacy with the NRW (WRs predecessor) as a winter only tire I have put on 5 seasons and they are only half worn. probably about 30-35k miles on them (at least 6/32in tread still left) .
On a Tribeca with WRs all year round with 26K they still show all the 6mm marks and you can just about make out some 8s.
I have a small RV with 22K miles with a truck Nokian and they have over half tread left.
I'm looking to replace OEM for 05 legacy gt wagon and I live in Northern NY in the Adirdonack Mtns where not only does it snow a lot, but often sub zero temps for days on end. I need a tire that can handle the snow and I previously had continental contacts extreme on my 04 wrx. Great tires for the snow but I dont have that car anymore and based on tirerack, I could do better. Please, let me know your thoughts. I drive spirited sometimes but most of the time with two kids and my wife, things are more reserved.
-mike
I've run some weird tires on my 94. In stock format I went from something like 195-60-15 to 215-45-16
Try em out and see if they fit, you'll know right away if they won't fit.
-mike
-mike
-mike
Also generally your tires aren't going to last more than 50k miles. That's a lot of miles. I'd just replace all 4.
-mike
I've replaced the 4 tires with Yokohamas V4s, the same tires I had before, now I will rotate them evey chance I have. I was thinking about getting snow tires for the winter here in Massachussets, any recomendation? Thanks thepaulista
-mike
Motorsports and Modifications Host
I’m about to purchase a 2000 Subaru Outback and it turns out on inspection that the rear and front tires were not matched for tread type or tread wear, and no more than a 2/32 difference is recommended in tire size/tread, and all tires should be matched for tread. So I will have to replace them. Planning to drive the car on the W Coast in N California after relocating now from the NE, mostly for drives of 5 to 45 min during the work week, and occasional weekend trips, including ski trips to the mountains in winter. I’m looking for a top quality all-season tire that will handle well in summer and winter conditions.
I’d sincerely appreciate your advice as I’m very careful about tires every since I bought my first car in college, a 7 year old Volvo, which had tires that checked out well enough, but in a medium rain storm, driving 30 mph on a Cliffside with one lane in each direction, with no sudden acceleration or steering moves, the car fishtailed 180 degrees, and I was lucky to “land” the car in my lane close to the inside of the road against the mountain. Some oil leaking down from a town above the road may have caused the road to be slick, but as soon as I put brand new top end all season tires on the car, it handled 10x better and safer. Never experienced that kind of slippage again.
In response to this question on Yahoo Answers, this poster below who owns 2 subarus recommended Yokohama Avid TRZ’s http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=AVID+TRZ . I checked the reviews on Tirerack and the TRZs have an average overall rating of 8.52 out of 737 reviews, which is very good.
http://www.tirerack.com/survey/SurveyComments.jsp?additionalComments=y&tireMake=- - - Yokohama&tireModel=AVID+TRZ&tirePageLocQty=&commentStatus=P
He was negative on Michelin for value and quick wear:
“I'm not sure if they're available in Australia, but I ran Yokohama Avid TRZ's on my 98 Outback.. they have a 700 treadwear rating, and the rain/ snow traction is excellent (I know not a lot of powder down there, but in a sudden downpour, they are amazing).. I drive mostly on-road, over 60 km one-way to work, and have taken them off road on occasion.. really surprising for an all season car tire. From my experience here stateside, Michelin is way overpriced, and the treads are too soft to get any real life out of; they do handle well though. Had nothing but bad experiences with Pirellis, may be just me. I'm currently running Dunlop Dirrezas on my 07 WRX.. and they have been wonderful so far. Stick like glue, and good in the rain. They are a summer- only tire though” * 4 weeks ago Source(s): 17 years in the repair trade, employed with a national tire distributor; owner of two Subarus.
Also, any suggestions on best place to pick tires up in the Silicon Valley area?
Bridgestone Turanza Serenity 225/60R16 $126 H sped rated - rated for 70,000 miles, supposed to offer just a little more responsive handling and a drop quieter ride than the Yokohama Avid TRZ, thanks to the stiffer tire, rated as a grand touring tire. There are less reviews for this than for the Yokohama Avid TRZ, but it appears well rated, though winter/snow ratings appear a little lower than the Yokohama Avid TRZ. Rated to 130 mph (as if I'd drive a 2000 Subaru Outback even close to that speed).
Yokohama Avid TRZ 225/60R16 $94 T speed rated4/ - rated for 80,000 miles - rated as a touring tire. Very large number of ratings and very highly rated, both for summer and winter conditions. Considered an excellent mix of quality and value. The Yokohama Avid TRZ also got a very good review in Yahoo Answers.
I have to decide in 2 days (by Monday evening) in order to take advantage of a $75 rebate for four Bridgestone Turanza Serenity Tires, if I want them. The Bridgestone rebate brings the cost of a set of 4 Bridgestone Turanza Serenity very close to the cost of a set of Yokohama Avid TRZs.
I'd sincerely appreciate your advice - I'm a first time Subaru owner and haven't had to keep a car for a few years now, so haven't bought tires in years.
