Dodge Durango Transmission Problems
Here it is I changed the fluid and filters, put it back together, filled it with ATF+4 fluid. Started it and went through the gears, and nothing happend.. It wont engage in any gear, Now its throwing a code (PO841)-Trans fluid press sensor/switch A CKT range/Perf... Now I really dont know what the problem is.. Dealer wants 85.00 for that sensor, But nobody knows anything about that code.. Can anyone Help on this one Thanks.
Any suggestions?
Cathblu
99 Durango SLT
5.9L
V8 Magnum
4x4
Thanks in advance
The forks that apply the hi lo hub and the 2wd 4wd slider have plastic tabs and do wear especially if not well lubricated (low fluid level) not allowing it to engage or disengage the hub or slider fully. Check the fluid level then Pull the drain plug..if the fluid looks bad or is real low and particles coming out of it, theres your problem. If its full and clean (Its ATF fluid, so should have a red tint), there have been some problems with the shifter motor on the side not doing its job, not properly engaging and disengaging but haven't seen one have that particular complaint.
To me, the trick is getting someone else to do it competently and cheaply!
With a little luck, someone with hands on experience will jump in and offer some guidance and inspiration.
SUVs and Smart Shopper
Mine takes about 2000 RPMs to get moving. is that your case too?
Is there anyway I fix this myself?
2005 durango SLT 5.7 Hemi. When pulling to a stop, a vibration is heard and noticeably felt through the vehicle. Place it in neutral and it stops. Does it about 85% of the time. Anyone experience this, or have suggestions on the issue? Thank you.
