Volkswagen Passat Headlights
woz
Member Posts: 3
in Volkswagen
I have a 2007 Passat 3.6 AWD Spaort Pkg II Wagon. It is a great car but mine has a big flaw. When turning right at any speed above 15 MPH causes the headlamps to dip down so that you cannot see anything beyond two feet in front of the car.
My local VW dealer is working with VW who says it is impossible for this to happen. It has never failed to happen in over one year since I bought it. VW says they know no one else with the problem. They are bringing another car like mine to test and compare both of them.
Anyone else have this issue? It only happens on right turns and curves. Very dangerous when driving in the mountains at 5AM in the dark.
either way get it fixed man. that sounds horrible.
E
I blew a light bulb (low beam I think) and was wondering how to do the replacement. My car is not under warranty so I will do it myself, I refuse to go to a dealer for something like this.
I read and heard that this was tricky, in fact the owner's manual recommends to go to the dealer, since the bulbs can only be reached through the engine compartment.
altair4 posted a while ago a link that would explain how to do this, but the link is dead. The post (#160) is here:
http://townhall-talk.edmunds.com/direct/view/.f0aef02/159#MSG159
I do plan on getting a service/repair manual that would probably detail the procedure, in the meantime I though I'd post here and ask.
There are two hex screws on top of each headlight, but something tells me I should start somewhere else.
Any idea or hint?
Bulbs are all OK. I have replaced the high beams lever and switch assembly. Lights still do not come on. Any ideas?
At this point, I'm so disgusted with volkswagen, I'm considering selling the car and never returning to any of their dealerships. I've told them it's a huge safety issue, but they do nothing about it.
did you try re-aiming the bulbs?
