Chrysler 300m Climate Control
just had air fixed, leak at the wall..now it overheats..could it be related...could it be a thermostat..do I need to take it back to the shop that did the air???
Newbie from MN here.
I used to be able to start my car, let it run for 5-10 minutes and I would get some heat in the winter.
But the past couple days I start it, let it run and it still blows cold air when I get outside. It will only heat up while I am driving, and when I stop the car for a short period of time (At an intersection or something) it starts blowing cold air again.
What gives? I'm not a car buff. I just had the thermostat replaced so I doubt that is any problem. Any ideas for me??
Has anyone had this problem and been able to have it fixed? My kids are tired of wearing ten layers to stay warm.
I brought it to an a/c shop and was told that they can try to vacuum out the system and load freon and charge me about $225, but there is no guaranty that it will cool down. The a/c technician even warned me that if it is a major damage or defect, it could cost me over $2,000 to fix it.
My question is, is it worth having it recharged for $225 and if at worst spend $2,000 for fixing the a/c? Is there a way I can find out what is wrong with the a/c without spending serious dollars? Please advise. Thank you.
Mark
if compressor is locked - have you checked all fuses....check to see if power is going to compressor than if you need one get one at a junk yard for about 50 bux
you would still need freon .....and
if you want to recharge go to autozone or the like they have a kit for 29 bux
works just fine and very easy to do...just twist it on....if you have a cute girl go in they may do it for her...but seriously...dont waste time on freon if compressor is locked.
I have not yet begun, so as of this writing, there are no parts lying all over the driveway and the car (and heater) are working fine in manual mode.
I will, of course, disconnect the battery before beginning. Would like info on where this computer is located (differing web sites all say "Behind the Heater". which I presume means inside and under the dash.) Any hints on removal and replacement access and procedures would be appreciated.
Also, is there any after-install process to program the unit or anything else that you, the reader have experienced?
Many Thanks: DICK42
Replaced the electrical socket that snaps into the rear of the unit too.
Still didn't fix it.
Is your reference of the ATC panel the same as my reference of replacing the entire unit. Or, do you mean the plastic window of the display on the front?
this morning was -40 or so, i couldn't start the air conditioning, then i waited for like 15-20 min. it was ok but then it just went in max speed and never turns off. to turn off i need to shut my car down.
what might be the problem????
and how i can fix it.
thx
My wife's 99 300M has no heat. Ran diagnostics on ATC unit and returned CODE 26 (In Car Thermister) Does anyone know where is this thermistor located?
