Jeep Grand Cherokee Gauges
mattstammy
Member Posts: 2
in Jeep
We just bought a used 2005 Jeep Grand Cherokee with 33,000 miles on it. We drove it before we bought it and everything was fine. On the way home, the check engine light came on. We took it to the dealer since it is still under warranty and they said the code showed it was a random misfire and that the plugs needed to be changed. I took it to another place to have them changed and they said it cleared the code. Well I drove it all day today and everything was fine but once I got home the check engine light is back on again. Any one know what might be the problem or of any TSB's for this? I am going to take it back to the mechanic for diagnosics again in the morning.
Just wondering if anyone has experienced and/or resolved this issue with the WK. For the last 6 months or so, my local dealership and I have been trying to resolved why my indicator lights, along with my needles blink out and lose power for about 2-3 seconds, then all blink back 'on' then go off one by one until everything looks normal again.
It used to do this about once every 1-2 weeks and the dealership has replaced the junction block, the front control module, the power distribution center module, and just recently replaced the entire instrument cluster. It still happens, just not as severly.
It's something that's gotten quite frustrating, not only for me but also the dealership as I'm sure they are sick of seeing me
Hopefully someone has found a solution?
Maybe we could share dealership names and then they can exchange info with each other to fix this for good. I'm in Niagara Falls, NY. My email address is Chade4u@hotmail.com.
Please write to me so we can get our dealerships to fix these pieces of crap. :mad:
Any ideas?
Transmisson Cylinod
02 Sensors
Computer
overdrive senser
Ignition Switch
and Valve Boby
I have only paid for 3 of the times it was in and finally told them no more. but tonight the light came back on again so I am lost for words
Any ideas of what it could possible be?
Change the alternator and I guarantee she will purr like a kitten.
Did you have the same problem that we have with the gauge cluster?
The dealer just changed the ignition switch last week. So far it hasn't done it yet. Jeep is giving us an extended warranty for all of our troubles. That's the least they can do at this point. We did turn in the paperwork to New York's attorney general for the Lemon Law just to be on the safe side.
:mad:
We have already had it disconnected while we drove it and the light still came on.
I will keep you guy posted as to the outcome of my problem Maybe I will also have to mention the wiring harness and see what they say :mad:
SUVs and Smart Shopper
Any ideas?
if just clicks when try to start but starts right up when jumped bat is low take to auto zone they can check cargin system on car
good luck
I must have read almost everything related to my issue in this forum and I appreciate all the help.
Later,
Scott
Later,
Scott
should not have hurt it by cleaning
Scott
Rodeoboy
While driving along one day all of a sudden all the lights on the instrument panel lit up and blinked for a few seconds, then they went out. Almost like it experienced a power surge of sorts.
It seems to run fine, I haven't noticed any loss of power or starting problems. But it just happened again for the third time, and before I take it in I wondered if anyone ever had this happen to them before? If so was it an indication of a larger problem?
My Infinity 2004 I35 SLIP, TCS off, ABS, AIR BAG lights are ON after a wreck. Car has less than 14000 miles on and only driver seat air bag was deployed but it was not replace. I replace the complete front left suspension system. How could I reset all or some of these lights? Please help! Thank you!
sounds as if you have a ignition switch going bad
Thanks for your help
