Jeep Cherokee Off Road Mods
Hi everyone,
I have recently bought a 1998 Jeep Cherokee Limited 4.0 and am in need of some guidance in what to put in/on it.
I just put a K&N 77 Series High Flow Air Intake and am interested in installing a MagnaFlow Cat Back Exhaust System.
I am completely open to any ideas in ways to make this Jeep better for mudding, rock crawling, and just overall performance. I would first like to do mostly engine work but any expertise you have concerning other areas is greatly appreciated. Also, I am willing to spend the extra dollar to build the best off-roading Jeep around so the best products are preferred.
I can't wait to see what is in store for my new Jeep.
Thanks Guys!
Thanks Guys!
Then go with 4:10 gears in the differentials so you can turn larger tires, 2" lift = 31" tires, 3" 32, 33 with steering issues in tight turns, 6" long travel is the best for flexing, and they have lower kits, Rubicon Express, for your driveline components which will keep your centre of gravity slightly lower, as well as correct your steering with a pitman drop arm, all included and easy to bolt on for the most part.
A rear locker, selectable or ,,, personal preference, read up, will give you an incredible forward advantage on rocks, and an amazing ability to back out of muck as well. Far less wheelspin when you start off and ....
Front limited slip in the diff over a locker as you still want to turn. Dana 60's are far too much weight for a cherokee to push, unless you are putting a vette 327 under the hood. Stick with dana 44's, much less fabricating and a better brake system too.
Front and rear bumpers, but find a custom fabricator and pay him/her too build you some high clearance ( Approach / departure angle ) bumpers.
Since you have eliminated the stock airbox, pick up another battery plate and an isolator and mount it there for a marine battery setup. If you run in the winter, you will start up much better, faster performance, ready to go winch power, power for inverters, and with the high amp alternator your lights will never dim again when you are winching : ) Then install some bright lights on your roof rack so you can see every animal ahead on the trail.
Thats a good way to spend some serious money, and wheel in a whole new realm of trails and obstacles.
If you still wish to spend more money, then with ARB air locker systems front and rear for lockers... Engine mods, I would do little there, the only company that I would trust with an elec upgrade is, ahh, here look into this stuff, but watch as my 89 is not going to work for all your mods, some you will need for yourself, look further down for a few links.
1989
Jeep
Cherokee • Engine: 6-cyl. 242 4.0L MFI Venom 400 Performance Control Module ZX293194
Each $299.99 Will ship within 24 hours
1988 - 1998
Jeep
(All Models) • Engine: 6-cyl. 4.0L, 4.2L Engine Gear Reduction Starter ZX815820Y Each $249.99 Will ship within 24 hours
1978 - 1990
Jeep
with Cap and Rotor Distributor ZX507818XF
Each $179.99 Will ship in 5 to 7 days
Air Booster
1989
Jeep
Cherokee • Sub Model: XJ
• Engine: 4.0L L6
• Fuel: Gas
FI Tornado Performance Booster ZX815902U
Each $64.99 Will ship within 24 hours
Here are some tips from where I got my XJ ideas from, and pirate 4x4.
Chilton CD : )
http://discountautorepairmanuals.com/Merchant2/merchant.mvc?Screen=PROD&Store_Co- de=darm&Product_Code=CD2050xx&Category_Code=CACD
Jeep Owners bible
http://www.amazon.com/gp/offer-listing/0837601541/ref=dp_olp_2/002-3744239-29592- 08
High performance Cherokee Guide
http://www.amazon.com/High-Performance-Cherokee-Builders-1984-2001-Design/dp/193- 2494146/ref=tag_tdp_sv_edpp_pop_t/002-3744239-2959208
Enjoy your XJ,
Randy
rc
keep the rubber side pointed down, or at least sideways.
