Chevy Suburban Electrical Dies While Driving and Stalls
  • mg2013mg2013 Posts: 1
    Just purchased a 1997 Suburban C1500. While testing the brakes, hard braking the suv stalled.
    Tested this about 3x at about 35 mph, stalled everytime, but cranked right back up. The suv is equipped with a trailer brake controller. If you've experienced this or a similar issue your response is appreciated.
  • balan1balan1 Posts: 2
    No, I still have not been able to get help with this issue. I have had people suggest going through a refactoring. This is supposed to update all the electronics in your car. Not sure how much it costs or if it is even possible. Very frustrating that not even a Chevrolet dealer knows what the heck you are talking about but it is definately a real problem. Any luck on your end?
  • adiemadiem Posts: 2
    no we still did not find a sollution we had it back at the dealer ship 3 times for the problem.they fixed everything else but the problem.we just got it so the dealer fixed it under warrenty but did mention they put over 6000 in it but it stills does it.I almost got rearended twice due to this problem.what the world is going on.
    Hi,I am the one who posted the problem with my 2004 would stall when starting from a dead stop.well we figured out the problem so I hope the guy with the problem check this out.they replaced the brake module do to it being cracked and rusty which later detected that the problem was the hub bearing was splitting apart causing the sencer to act was sending faulty messages to the computer as if we were sliding.Now it runs great.Hope you can get yours fixed also but I suggest getting these items checked.If the module isnt working right it will not pick up the right problem..God Bless
  • Our 2002 Burb Z71 suddenly started stalling while highway driving at 125K miles on the odometer. No warnings, no odd sounds or vibrations... just stalls. We coast to a stop and it restarts and usually continues on without incident. The stalls are erratic... sometimes we've been driving interstate for 4 hours and it stalls, then restarts and continues for 4 more hours driving. Other times, it stalls every 15 minutes while driving. Is it electrical or fuel and why isn't it consistent? There's no rhyme or reason. No codes are evident to the repair shop. They replaced the Crank Shaft Sensor, but we stalled again after driving 250 miles. Air filter has also been replaced.
    How do you troubleshoot something like this when its occurrences are unpredictable and without a code? Wow... makes us hesitant to take it on a trip for worry it will decide not to restart in the middle of nowhere. I have read all the blogs relating to suburbans stalling and have not found a solution. Ideas?
  • I had a similar problem that we solved. Thought I would post it here... it may help some of you.
    I had the same problem with my 05 Suburban 175000 miles. It first stalled pulling out into traffic a week ago, left turn, dead stall, no stearing, traffic coming - scary. I was able to get out of the way. It started right up. Ran fine for a day. Then did it again. A day later again. I learned to shift to neutral and crank it while rolling, so I could get out of the way. A couple days later I noticed it was only on left turns. I went to two dealers and two repair shops. No clue. "only on left turns?" no way. It would have to be a wire short. They didn't have time, I was traveling out of state. The car was still going "straight and right" just fine... so I drove on. then I hit a big bump in the road east of Tulsa, and it stalled, but didn't die. 10 miles later it did it again. I'm in the middle of Oklahoma, and it is getting worse. Finally, I'm in walled in construction zone, no shoulder, concrete sides, 10 miles of it, and it dies completely. I shift to nuetral and it won't start. It tries, but won't. Guages are dancing around like crazy. I'm coasting to a stop, 10mph, and there in front of me is a hole in the concrete barrier that I ease through out of traffic. I get towed to a shop and they start pulling on wires. By this time, the car has cooled and it is starting and running fine. For some reason it was worse hot. They notice on a bunch of wires that run down behind or beside the power steering pump and under the car, that the car will stall if they pull on those. So they slide under and take of the skid plate and disconnect all those wires and pull them up for examination. We cut all the tape off, and examine them. The two little wires going to the lower AC switch have a kink and a worn spot, one has the plastic off for an 1/8 inch and the wire is exposed. We taped them up... saw no other bad spots, shook our heads, shrugged and put it all back together. For some reason on the left turn and later when it worsened, on a bump, the rub got worse and worse and then shorted out completely (when it was hot) The AC was working fine, there had been no engine light codes, but this surge / short had caused the stall. It is working fine now... we just drove 200 miles with not one stall. It had gotten so bad that it was stalling every left turn and most bumps in the road. It took 1.5 hours to pull all the wires out, and put it all back. No parts necessary. Hope this helps. Western Auto in Atoka OK - Great guys! thanks!
Chevy Suburban Electrical Dies While Driving and Stalls - Page 2 - Car Forums at
