Infiniti G35 keys, door locks, security system
I have a 2003 G35 Coupe. The driver side door does not lock or unlock with the remote. The passenger side still works. Any idea how to fix?
If the car receives the signal, all doors should be unlocked, not just one.
Once the signal is received, it's like hitting the unlock button inside the car.
It's not like each door receives it's own signal.
Have you attempted to pair the fobs to the car again?
Does it happen with both fobs?
Very weird issue! :confuse:
I did recently replace the window lift motor though that was a few weeks ago. The lock didn't start sticking until a couple of days ago. Maybe something is restricting it.
There's a lot of linkage and stuff in there, and something little may be in the way.
You'd be surprised at how something very small could cause it to hang up.
As much as it sucks, I'd consider getting back insode the door and double checking for restrictions.
Does anyone have any suggestions?
Mine self-locks, on average, about 3 times a month, but sometimes twice in the same day. Sometimes it locks when the door closes, sometimes when the door is partway open. In every case, the other doors remain unlocked.
The local shop replaced the lock actuator a couple of years ago, with no effect. I suspect the problem is more widespread, but that many people don't recognize it and assume they've unconsciously locked the door. Infiniti & its dealers seem in no hurry to diagnose the issue.
Funny how all this stuff happens after warranty.
Simply put, if you unlock your vehicle via remote and do not physically open the door within a few minutes, it will re-lock itself automatically.
To avoid this issue, be sure to open one of the doors after you unlock it via remote.
Did you manage to know what the problem was?
Even 'm facing the same problem
Only the driver side door does not work properly with the remote.
Dev
If it's the same problem as mine, you have to replace door lock mechanism. An you have to replace the entire thing. It's all one piece. Conveniently they don't just sell the replacement gears.
"The driver door on my 2006 G35X on occasion will lock itself when the car is left unlocked and unattended. The other doors remain unlocked. It has happened in 2 different locations approx 8 miles apart so it is not from a random signal It has happened both with the fob in the console and when I have the for with me. The dealer says no one else has complained of this problem. Am I the only one?
Does anyone have any suggestions?"
Dealers apparently aren't sharing information about this issue among themselves, or with Infiniti, possibly because they don't think it's real. So everybody who has this problem is "the only one". It's a small problem, apparently affecting only a small percentage of owners, but it certainly affects my willingness to commit to another new car that they'd service.
Plastic gears seem to be the norm for Infiniti. My CD changer is also not working and was told it's the plastic gear in the changer. Between $300-600 to repair.
Can previous year(2008) models be programmed to do the same?
