My problem is if I don't rotate the tires I will ruin the rear tires in 12,000 miles and if I do rotate I will ruin 4 tires in 24,000. Has anyone had success in fixing this problem?
I had the same problem with my 2006 Civic. They blamed me then for not rotating. At 100,000 miles I discovered Honda service bulletin 008-001 dated Feb. 8, 2008. I had the rear control arms replaced and the problem disappeardd even though I subsequently never rotated the tires.
I had the same problem with my 2006 Civic. They blamed me then for not rotating. At 100,000 miles I discovered Honda service bulletin 008-001 dated Feb. 8, 2008. I had the rear control arms replaced and the problem disappeard even though I subsequently never rotated the tires.
A) Yes, Honda had, and it seems, still has mechanical problems in the rear suspension components. As noted there was a TSB or Honda service bulletin issued to correct the rear suspension problem by replacing the rear control arms with "improved" parts. This was issued to fix 2006-2007 model years. I did not know it could be an ongoing problem.
As noted tire rotation plays a very, very big part in getting all the tire life possible. Front tires in a FWD car do double duty. They are the drive wheels and steer as well whereas the rear tires are along for the ride. All things being equal (proper inflation, alignment and tire balance) the rear tires will outlast the fronts by far if not rotated regularly. Rotate at 6K miles.
C) All that being said for a pair of tires to go from being recently inspected ( and deemed to be acceptable) to "completely bald" in that short time frame seems to be well....unbelievable. I guess it could depend on what criteria the Honda techs. used when it was decided what was "good" during that inspection. Did they say they were on the edge of being worn out but still legal in your state (for inspection purposes, assuming you have state inspections) or having quite a lot of tread left?
I have a 2006 Civic and while the uneven tire wear problem was not an issue with our car the original Bridgestone tires did wear to the point I chose not to use them last fall to go through one more Pa winter (good choice that) and replaced them at about 24,000 miles. They were regularly rotated, carried the correct tire pressure, wore out evenly (more or less) but wore out prematurely in my opinion. I replaced all 4 with Kumho Solus KR21"s that I know can last many more miles than 24K from experience on another car I own.
So, it seems Honda still has a problem or two with the Civic, rear alignment and a poor choice for OEM tires.
Because I just had my honda accord stolen from work, and i have all my keys as well and the insurance says that they dont understand how someone could of stole my car without a key?
bc my insurance doesnt think so. they told me that its really hard for someone to steal that kind of car without the key due to the chip in it?
what did ur insurance tell u?
1. Ignition. Sometimes inserting the key into the ignition is hard and it seems to catch. Also, on occassion, when trying to pull the key out, it will stick and not want to come out. Have to yank it. I'm not talking about turning the ignition off because I understand that the steering column comes into play. I'm talking about actually inserting and removing the key from the ignition.
2. Paint chips. Geez, one month and already have a half dozen chips on our hood and a few on the side panel. Very small chips. We have the Black color. It just seems as if the paint is very thin and not bonded well to the surface.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
