Jeep Cherokee Grand Cherokee Noises and Sounds
1234568
  • jrmecujrmecu Member Posts: 1
    Don't know if you've found the answer but my experience was very similar and it turned out that you have to have an OEM belt from the dealer not from an auto parts store. This took me quite a while to figure out. I installed several belts from auto parts stores but they were just slightly larger and so I was continually having a squeal. Also you might replace the serpintine tensioner pulley if they haven't already.
    These are both cheap and easy fixes.
  • funzone2funzone2 Member Posts: 6
    Thank you for your reply (jrmecu) I'm contacting my " mechanic" today and giving him your message on the OEM belt. So far, they've changed the compressor, clutch, belt tensioner. new serpentine belt, a/c dryer and feed tube. It's been in their garage for two weeks and $750 later, stilll squeeling. I don't think they've changed any of the whole pulleys.. Welcome to FLORIDA
  • drewppydoggdrewppydogg Member Posts: 2
    Sorry forgot to up date. It was the over drive bearing. He was able to replace without removing the tranny. Able to replace from side plate. It cost me only $300.00 from a local tranny shop. Good Honest man. Quite as a church mouse for over 20,000 miles
  • malakesmalakes Member Posts: 3
    I have a very annoying knocking in the passenger side rear of my Jeep. I have replaced the shocks, due to one being bad, and since it has made noise.
  • topat46topat46 Member Posts: 20
    I had the same issue with my 2004 GC Limited. I had new shocks installed and had a knock on the rear drivers side. Turned out to be the shock was not tight enough to hold it still on the shock bracket. It made quite an annoying knock.
  • senoritagatosenoritagato Member Posts: 3
    My 2004 Jeep Grand Cherokee is doing the same thing. Shut off and then about 15 seconds later, about 30 clicks. If I start the engine back up it stops but when I turn off it will continue. Doesn't do all the time, but very frequently. Have you had any success in finding out the problem? Thanks
  • boscotchiboscotchi Member Posts: 2
    Mine is still making the noise. I'm pretty sure it has something to do with the "blend doors" that regulate and mix the passenger air. I've had problems with the blend doors twice before and it costs about $800.00 to have the dash pulled out to replace a $20.00 part so I've learned to live with this particular irritation. The noise on mine doesn't start until the key has been turned off for two minutes and by then I'm usually long gone from the car. Another reason I'm reluctant to have it fixed is because, after owning probably 40 cars in my 70 years, this one has caused me more grief than all the others combined; it's just one thing after another, but I'm nothing if not stubborn. I bought it new thinking it would last me until I quit driving; we'll see.
    Thanks for your reply. If you please, I have another question. You think it has something to do with the blend doors/passenger air. Is that after you've run the a/c or heat, or all the time? Also, after you pulled the dash and replaced the part, did it stop for a period of time. Since I live in a climate where a/c is not used a lot...Muchos Gracias...
  • fielderlbfielderlb Member Posts: 1
    funzone, did the OEM belt fix your problem. I'm experiencing the same thing on my 2004 4.0
  • enyawrejenyawrej Member Posts: 1
    edited November 2010
    were my front driveshaft is i got a leak. i thank it is a bad pinion seal anybody knows for sureand also hearing grinding and clicking sound when turning corners slow
  • rickerkrickerk Member Posts: 1
    hello, new to site. i have a 99 jeep grand cherokee larado that sounds like the same issue.
    background; had rear end noise, opened it up and found all the bearings bad and the ring and pinion bad from the bearings being so worn. changed all and the bearing whirl noise went away. 2500 miles later i have the noise that you guys descibe above. i though maybe i did something wrong to the rear end, opened it up and everything checked good. put it back together and went for a road test. sure enough when i put the tranny in neutral the noise all but goes away.
    when i bought the jeep the tranny leaked at the rear seal so i changed it before anything would happen. however, i feel that this may have a contributing factor to what i believe is a tranny bearing problem. the noise is a deeper growl noise but i was also wondering if it could be the drive shaft? this jeep has the CV type of drive shaft at the tranny end and your standard u joint type at the rear. thoughts????
    It appears to have fixed the problem. After 3 different sepentine belt changes and After my mechanic changed the compressor and tensioner 2 times and then changed a compressor clutch., he put on Mopar belt and the squeeling went away. There is still a minor squeek , sometimes, when I start it, but it goes away. Bottom line, change the Mopar belt. It cost $50. So my mechanic charged $650 for the work and the REBUILT compressor and parts that he changed and only charged $50 for the new Mopar belt.-- What a guy.--- What a sweetheart
    Thanks to the fellow that gave me the advice.
  • carter8carter8 Member Posts: 1
    Had a similar problem on my 1996. I tried several of the same remedies. Turned out to be the bracket just behind power steering pump was broken. Couldn't find it until it failed - broke into six pieces. $30 replacement fixed it. (replacement part is better reinforced)
  • hiofisrhiofisr Member Posts: 1
    My 99 Grand Cherokee Laredo (inline-6 with SelecTrack) hums when the 4wd is engaged. It's become more and more prevalent over the last two seasons. Had a local do-all mechanic look at it and he "didn't see anything, just threw some thicker fluid in the transfer case so you can trade it off." That didn't help my problem or his reputation, as I won't be revisiting or buying any used cars off him. Anyway, I still suspect the transfer case, but don't want to take guesses as to rebuilding or replacing. BTW, I know this isn't front hubs or CV joints as I've experience those noises before and this is different, plus this is only present in 4wd.
  • nlw450nlw450 Member Posts: 1
    Was told by dealership needed u-joints, cant buy them only the whole drive shaft, $961.18. went to junk yard and found used one, put it in and was fine for the fist day and a half, now back to the clanking sound when ever I take off, still sounds like u joints bad again new shaft only had 30,000 miles on it.is there any thing cad could make them go bad that quick? or could it be my transfer case? I have all wheel drive.
  • carknownothingcarknownothing Member Posts: 1
    Tonight, the rear hatch door on my 2001 Jeep Grand Cherokee started making a loud (as in I can hear it from several feet away) grinding-like noise whenever the doors are unlocked. Since the doors automatically unlock when the driver's door is opened from the inside or the unlock button on the key ring is pressed twice, it is a bit annoying and worrisome. As far as I can tell, the hatch still locks and unlocks normally, but I have yet to officially lock the hatch and tried to open it, since I didn't want to accidentally set off the alarm and wake my neighbors this late at night.
    Does anyone know what might be causing this noise? And if so, is it a cheap and easy fix? I know very little about cars, and I'd rather not have to spend a ton of money on this repair, even if the noise makes me cringe every time I hear it.
  • barkman2barkman2 Member Posts: 1
    Hi, I have a 2004 Grand Cherokee Special Edition 4wd, 4.7L engine. When I go over a sharp bump, I am getting a very annoying!!creaking/crunching type noise from the front passenger side. It only occurs when hitting a sharp bump or dip in the road, drives perfectly fine otherwise and doesnt have any other noises under normal driving, turning, etc. It has recently had new shocks, and tierods. I initially thought perhaps balljoints, but since it makes no noise at all when turning, probably not. I am thinking maybe control arm bushings or a bad coil spring insulator? Any thoughts would be really appreciated before I bring it into get it looked at. Thanks.
  • dlcjeep2005toodlcjeep2005too Member Posts: 1
    I think I have the same problem, seems to be part of the HVAC heat/air system but still makes the noise even when the fan is off... have you found the solution yet? I have and 8 ltr and have been listening to this noise for 6 months, seems worse when it's cold...
    Thought originally it was the blend door. I ordered one on-line and took to my mechanic. Turns out it was actually the heater motor for the passenger side. Part of dash did have to come out but he put in the new motor, the blend door anyway and charged me around $500. It would have cost about $1100 at dealer. No more clicking and the heater runs great.
  • I just replaced all the major components in my (Jeep GC V8 Laredo w/ 131k) front end, and I still have a grinding noise/grinding feeling in the steering wheel when I turn the wheel to the right, escpecially over 40MPH.
    I have replaced the following:
    both front axles
    both front (and rear) shocks
    both front brakes and rotors
    After these items were replaced the grinding STARTED
    It felt like the front right wheel bearing.
    So, I had it replaced.
    Noise still continues.
    I am going up to Merchants to having it checked out again.
    Grinding is NEVER a good thing.
    I really don't want to replace all the ball joints, I think they just replaced the wrong wheel bearing assembly.
    Hopefully they will replace the drivers side wheel bearing AT COST since I spent $450.00 just to replace the passenger wheel bearing.
    I printed out over 20 auto parts places that had the hub for less than 75 bucks. I was charged 250. Not happy.
  • chele1082chele1082 Member Posts: 1
    Noise sounds almost like a shudder or grinding. Only happens when making a sharp left at very slow speeds, in parking lots. First sounded as if coming from rear, so thought maybe wheel bearing. One time came from both front and rear at the same time, could feel the jeep shudder. Can't tell if coming from d/s or p/s. Doesn't do it all the time. Very sparadic., but starting to do it more often. Been doing it few weeks now. Any ideas?
    Hi !...I had the same issue with my 2004 Grand Cherokee Lmt. It had 120K miles on it and I was experiencing the exact same condition. Since it felt like the hub bearing on the front driver side I change it myself along with the half axle. The condition still existed. At times it felt like it was comming from the passenger side so I change out that side also. Still having the condition. It only happened in parking lots making right or left tight slow turns. At that mileage it was time to have the transmission and transfer case fluid changed. I went to Chrysler and purchased their reccomended transfer case fluid and changed it myself. Without using the Jeep the next morning I had the transmission fluid "exchanged". I don't know how or why but the problem was gone??.................I hope this helps you.
    topat46
  • skip0822skip0822 Member Posts: 1
    Hello, I have a 2005 Jeep Grand Cherokee, V-6 83,000 miles, I have a Clicking noise, coming from what seams to be my left rear... when I'm doing about 5 to 15 miles per hour, its loud and annoying..but as soon as I get up more in speed, its gone, and returns when I slow down, its driving me nuts..any suggestions
  • drewp38drewp38 Member Posts: 1
    I have the same problem exept its when i am turning left,only at very low speed ex.parking.Spent a couple hours with mechanics at dealership only for a senior mech to tell me it was the rotors(No way).Anyways put on new rotors,no change,quite annoyed with mech's at dealership now and don't want to go back,they also told me there was no safety concern,everything is tight in front end.Not sure what to do next,going to rotate my tires today.Looking for some help.
  • tekmjr28tekmjr28 Member Posts: 3
    Sounds like your heater resistor. The vent/door closing is normal.
    Maybe E-brake shoes.
  • harly1harly1 Member Posts: 1
    I have the same thing and already had all the rear end control arms replaced and still have that same noise coming from the front thinking i might have the front control arms replaced,and i still have some noise in the rear end when i push up and down on the bumper.I have a limited lifetime warranty on the dorman control arms in the rear wondering if it could be the shocks,have you found out what the problem was with yours
  • sotcrsotcr Member Posts: 1
    edited June 2011
    I'm getting a cluncking sound and feeling transmitted to the sterrring column whenever I slow down abruptly or come to a stop. This is a 2011 Jeep Grand Cherokee V8 4x4. Anyone else have this problem?
  • ecunniffeecunniffe Member Posts: 6
    Have had the same issue in past just after having brakes done. Turned out that the bracket that holds the calipers on - one of them was slightly loose and make clunk thumping sound when brakes applied.
    check this to make sure tight. I think it was 16 iir 18 mm wrench
  • mangulomangulo Member Posts: 2
    My husband has a 1996 and we have had the same problem for years. One so called mechanic replaced a couple of different things saying that's what it was, wrong. Somebody else said transmission. Another mechanic said shocks again. Last month the damn door for somereason fell down, just ripped and we couldn't shut it. Took it to a body shop they got a door and installed it for $300. As my husband was leaving they said did he want to fix that grinding clank problem, as they were doing another Jeep for the same problem. My husband asked if they really knew what it was and they said yeah, it's the transfer case. That it's a big problem with the Jeep Cherokees. $800 for parts and labor later problem solved!!! Wish we had found them a couple of thousand $ earlier. Hope this might help.
  • 02jeepgc2802jeepgc28 Member Posts: 8
    Since December 2010, my check engine light has come on five times. I've included below what was done each time at the mechanic.
    73,797 - P0456 Error Code - Evaporative emission control system leak detected (very small leak) - 11/26/10 - Possible loose gas cap, mechanic tightened and tested cap and reset the OBD.
    74,102 - P0442 Error Code - Evaporative emission control system leak detected (medium leak) - 12/7/10 - Gas cap tested bad, mechanic replaced the gas cap and reset the OBD.
    77,718 - P0455 Error Code - Evaporative emission control system leak detected (large leak) - 5/31/11 - Possible loose gas cap, mechanic tightened cap and reset the OBD.
    77,865 - P0455 Error Code - Evaporative emission control system leak detected (large leak) - 6/10/11 - Mechanic replaced the evaporative vent solenoid (solenoid was clicking loudly on the 11/26/10 date) and the crankcase vent hose (hose was cracked); reset the OBD.
    78,161 - P0455 Error Code - Evaporative emission control system leak detected (large leak) - 6/21/11 - Mechanic suggested going to the dealer because they have an advanced computer system.
    My questions:
    I've researched this on Google and it appears that many have had this issue on different Chrysler vehicles, many with no resolution. My mechanic said he could do a smoke test (pump smoke through the evaporative system) to see if that shows anything, but he said that this can be expensive to track down the problem. The dealer wants $95 just to run diagnostics (which would apply to my estimate to get it fixed, assuming they figure out the problem).
    Have you heard of this? If so, what have people tried?
    Any other suggestions?
    The mechanic said I could drive with the light on, but this makes me uneasy, especially if I go out of town. I have noticed a decline in gas mileage. Other than that, it may run slightly rough here and there, but overall doesn't seem phased by this issue. I haven't spent a ridiculous amount of money so far, but I'm trying to keep the costs down on this.
    Thanks!!
    It is a 2002 Jeep GC with almost 79,000 miles. It is the 4.0 I-6 and is two wheel drive.
  • lionel4lionel4 Member Posts: 1
    shock absorber bushings
  • lojo61377lojo61377 Member Posts: 1
    Just noticed this a few days ago, but I am a paranoid driver and hate driving a vehicle when something "could" be wrong.
    Anyway, I noticed, what seems to me, a whooshing, air-like noise. The noise seems to come from right up front, around the dash. I can turn the car off and the noise is still there.
    My husband drove it the last couple days and he says he can hear the noise but not sure what it is and other than the noise it runs pretty well. Any ideas what this could be?
    1997 Jeep Grand Cherokee Laredo
    175000 miles
    4WD but doesn't work (differential went out, had changed to 2WD)
    I had that same sound on my 93 and 95 cherokees and was told that the cause was the air conditioner. don't completely understand the science of them but the coolant in the air conditioner is just flowing back into the compressor and nothing to worry about.
  • 1sikwj1sikwj Member Posts: 1
    hey, did you ever figure out that noise. my jeep would make the same clicking/grinding noise from the rear so i sat in the rear passenger seat and with the door open and my seat beat on i leaned out of the jeep while my dad made that slow left turn and noticed it was louder outside the jeep right near the pass. rear tire. long story short. i found my muffler pipe was loose and seen the spot where it would bang against at every left turn. i guess the rubber boot or mount on the muffler hanger went bad... replaced it for $9.00 at a local autoparts store. no more embarassing noise when turning left
  • ih8yourface2ih8yourface2 Member Posts: 1
    try replacing your wheel barring on that side of the car my 98 jeep did the same thing and i fixed the barring and never heard the noise again.
  • steve001968steve001968 Member Posts: 1
    Low to medium pitched growling noise from somewhere in the front end which occurs only while the vehicle is in motion. Noise is most noticeable below 40 or so but is present at essentially all speeds as well as both on coast and acceleration. Noise disappears entirely when the vehicle is turned even moderately to the left and increases in severity when turned to the right.
  • apretoriusapretorius Member Posts: 2
    Hi there if you have the tow bar that slides in and locks with a pin then check that out.After a while it opens up,but just place something to stop it moving around.
    I have a 2001 JGC 4.7 v8 when i move from P and go into R and D i get a clicking sound for a few seconds then it stops. Any help please. Thanks.
  • cypressjgccypressjgc Member Posts: 1
    I have the same issue with a 2WD 2005 Grand Cherokee - opposite side. When I turn right, the roar disappears. Did you discover the problem?
  • creative4artcreative4art Member Posts: 1
    1. I am hearing an annoying significantly loud humming sound when I drive on highways at speeds 60-75mph (95-120kmph) @1600rpm. Its sort of sounds like a sound blown through large hollow tube/flute.
    2. I also can hear a rattling noise from my left rear side, its like a light metal grinding on some wheel sound.
    3. Large fart like sound a few mins after I turn off my car from the front dashboard :)... might be the AC? whats up with that?
    Anyone knows what is causing it or faced any similar problem?
    2004 Jeep Grand Cherokee Limited - 67,000 miles (108000KM)
  • hermanphermanp Member Posts: 1
    My jeep, 2006 Grand Cherokee 3.0 CRD, 135000km, makes a deep noise when switching off - a similar noise when you remove the air box completely and you hear a piston decompressing. Any suggestions what it might be?
  • ccttnccttn Member Posts: 1
    Took my vehicle to River Oaks Chrysler Jeep and had front rotors, calipers, pads, system flush. Did not pop before but pops now. It is almost as if something is binding and pops as it releases.
    I had a similar noise after front brake work. Turned out to be that the bracket that attacheds the caliper to was loose. Check tightness on that on both sides - i believe it took a 16mm wrench to tighten.
  • mgrifficomgriffico Member Posts: 1
    The tailgate lock actuator needs replacing...it's another Jeep "design to fail" part ;-(
  • scotty111470scotty111470 Member Posts: 1
    My son has a 99 Jeep Grand Cherokee that recently started making a loud rattling noise when turning sharp. It sound like it is under the hood on the driver side. Any possible problems would be greatly appreciated and how to check to verify.
  • speeddemen899speeddemen899 Member Posts: 1
    I own a Jeep Grand Cherokee and was trying to figure out why I had this jerking motion all the time. I had mechanics look at it and they believed it was my tranny. But really it was my TPS. It controlled my throttle and possible symptoms of that are:
    1) idles funny
    2) in drive or reverse it will act like it dies on you sitting still
    3) going down the rd it jerks (small or large jerks), it will feel like a car accident or the vehicle will act like it shut down for a quick second
    I've got a grinding noise on the front driver's side tire. Its more of a howling noise. Everything in the front has been replaced (Ball joints, Tie rods, Wheel bearings). I had my mechanic take it apart and the front differential fluids were a milky color and the gasket was gone. Yes, I got stuck one time out in the mud with it before. But I am not positive if its the bearings in the front differential or if its the transfer case itself. Any ideas?
  • jarol1jarol1 Member Posts: 1
    edited May 2012
    2005 JEEP CHEROKEE LIMITED HEMI 4X4 I am hearing an annoying significantly loud humming sound noice when I drive on highways at speeds 60-75mph . Its sort of sounds like a sound blown through large hollow tube/flute.TIRES AND SHOCKS NEW. PLEASE HELP!!!
  • neonmaxneonmax Member Posts: 1
    edited July 2012
    2005 jeep grand cherokee 3.7 It sounds like if the fan in dash board is hitting something, it stops after 10-20 second and it comes on intermittently?? any suggestions.
