Jeep Liberty Noises and Sounds
Is your Liberty making strange sounds? Can't figure out the source of some mysterious noise? Are you being distracted by some irritating noise? We'll discuss it here!
Also, related discussions are being consolidated here so don't be concerned if some messages appear to be out of order!
SUVs and Smart Shopper
Nescosmo.
Good luck,
Boiler
chstockd, sorry, no experience (yet, thankfully) on the air bag thing.
The noise lasted less than 5 minutes, and I noticed a little steam coming out from under the hood. This morning I checked and found no leaks anywhere and the coolant level was fine.
Any ideas what it was?
Our 2005 Liberty Renegade has the usual windsield problems, we are on our third windshield now. About two months after the last replacement, we began hearing a relatively high-pitched whistle coming from the right side of the windshield or passenger door area. It is very hard to localize and sounds a lot like a one-note harmonica. It only happens above about 65 mph and is worse on hot days than cool ones.
We've had the autoglass replacement techs look at it three times. The windshield is installed correctly and is sealed. No water leaks in. They even added a bead of that expanding foam insulation inside of the passenger side seal around the top of the door, to no avail.
Has anyone else experienced anything like this? It's driving us nuts...
- apply masking tape over the windshield joint and you progressively remove it until the noise comes back. Once an area is defined pour alcohol (from outside) along the joint. This should momentarily fill the crack and help locate the problem by stopping the whistle. Wax is later applied around that region. Alcohol also cleaned the surfaces.
- a high frequency microphone (ultrasonic) that you drag around the periphery of the windshield from inside when the truck moves at 65 mph. A meter or diode indicator will reveal the high pitch sound source when passing above the crack.
Check your hose connections and rinse the gasket of your cooling circuit filler cap under running water. The aging antifreeze could make it stick and build overpressure. My hoses are still like new at an equivalent mileage.
When driving so as to adequately produce the noise have a passenger push outward on the passenger side door/glass usually at the upper front corner. The pitch or sound level will change dramatically if it is the door seal. On small cheesy vehicles it does not take much pressure to reveal the location of such an air leak that will not usually leak water. I may take a pretty good push on a Liberty to reveal this kind of leak.
Thanks for any help....
i won the heater battle though....
so now when i shift from Park to Reverse and start to back up i get this loud, hard bang. like something is stuck?????
its so loud and hard that others in parking lots actually look!!!!
side note: i feel like my e-brake is sticky too after i went to a drive-thru carwash...so im afraid to use it now...
My 04 Liberty has the same problem and my dealer isn't giving me and answers..
Thanks..
I hear and feel a vibration and grinding noise in the rear end of my 04 Lib when I’m turning a corner or reversing at low speeds, it almost feels as though my e-brake is stuck or on, which it’s not...the dealership where I bought it, not even 2 months ago, said that they can’t find anything wrong. It’s really annoying and embarrassing because I just bought it...
Also, it has brand new brakes all around so thats not it..
Anyone????
come to a stop and when I turn the steering wheel left and right I jacked
it up and checked the ball joints and every thing looks to be fine. I also put on the spire tire but the sound is still there HELPI don't have much money at the moment to take it to the shop and I really like the Jeep very much but that sound is driving me Crazy!!!
The transfer case has nothing that can rub against the transmission shafts, so the only source of friction I could imagine should come from inside, along the chain or a bearing :confuse:
Do you have enough oil in there?
When you switch between 2 and 4WD, the parts that you move remain in the oil bath.
Sounds like we may be experiencing the same noise. I have not checked belts or hose connections to the turbo and air intake but it almost sounds like it might be something like that. Let me know if you find the fix and I will do the same.
Backhoebob
Right after installing winter tires on the vehicle and driving home there was a noise that was coming from the rear. I work for saturn saab dealership as a mechanic. It does not sound like a diff, suspention or any metal on metal sound. It sounds as if the latch for the top glass is loose. I went ahaid and opened the glass, drove around. The noise is still there. Took off the hatch panel, no change. I can't seem to figure this out. The spare tire is very secure and the liscence plate is also secure. Now I didnt get a chance to lift it up n look under since the noise wasnt there when I baught it. Checked the rear seats and they are secure in place. It's not the jack since I had a friend ride in the back seats while I drove. The noise is really comming from the rear rear.
Sorry for such a long post. Its driving me crazy.....
If anyone can help me I would greatly appreciate it.
Thank you in advance.
On the moving/opening side of the door there is a rubber positionner/bumper that arrives into a vee shaped metal end_stop/ramp/receptacle that forces the alignment of the door with the truck when it's closed.
I used lithium grease on the bottom side of this ramp, and it solved my squeaking problem.
I will try that tomorow.
Oh n are the transfer cases noisy on these trucks, its pretty noisy in 4low.
Should I try changing the oil in the transfer case n the diff, or just bring it to the dealer seeing its got powertrain warranty?
I left '4WD full-time' engaged all winter and it gives a slight vibration during acceleration within city driving conditions. At 60mph I feel no difference.
For the sake of comparison, the Nissan 'Terrano' 4x4 sold in the EU which is equivalent to the Liberty has a very noisy transfer case in the LOW range. It tends to whistle.
I just purchased a 2004 Jeep Liberty and on the way home from the dealer I began to notice a high pitched whining noise that seemed to happen when I turned the wheel to the left. I might even describe it as a metal-on metal sound. The noise would stop when I hit the brakes. I took it back to the dealer the next day and they said they couldn't find anything wrong with it. Since then, the noise seems to increase after I've been driving for a while and also when I turn the wheel in either direction. It still stops when I hit the brakes. Any ideas on what this could be??
Thanks for the help!
If this doesn't work, look at the master cylinder 'home' position: you could have a bad pedal assembly that doesn't release the master cylinder when your foot is off.
It sounds like a universal joint.
When I first start the car and drive forward- no noise.
When I turn right, I hear clunk, clunk, clunk that vaires with speed so I know it is drive train and the noise is coming from the rear.
As soon as I straighten out the noise goes away.
After driving straight for 1 minute- the noise is gone until the car sits overnight.
I am suspecting the rear differential as the cause.
Any suggestings
I had the same problem. It would make more of a chatter noise rather than clunk, clunk. I guess the exact sound is in the ears of the beholder. Anyway, my vehicle had 80K miles and never had a differential oil change. I changed it out with some good Mobile 1 Synthentic Gear Lubricant 75W-140. And since my rear end is Tracc-lok equiped, I added in a tube of Limited Slip Additive.
Problem fixed!
Note: Trac-lok differential equipped vehicles should be road tested by making 10 to 12 slow figure-eight turns. This maneuver will pump the lubricant through the clutch discs to eliminate a possible chatter noise.
If that doesn't work then other areas to check would be...
Damaged drive shaft.
Missing drive shaft balance weight(s).
Worn or out of balance wheels.
Loose wheel lug nuts.
Worn U-joint(s).
Loose/broken springs.
Damaged axle shaft bearing(s).
Loose pinion gear nut.
Excessive pinion yoke run out.
Bent axle shaft(s).
Check for loose or damaged front end components or engine/transmission mounts. These components can contribute to what appears to be a rear end vibration. Do not overlook engine accessories, brackets and drive belts. All driveline components should be examined before starting any repair.
I hope this was a good post.
GoodLuck, and let me know what the final fix is.
Has anyone experienced a pulsating grinding/creaking noise with a 2004 Jeep Liberty?
A pulsating grinding/creaking noise is resonating from the rear left hand side of the car. The noise can be heard at lower speeds and whether I am or am not pressing on the break. The grinding sounds is not constant, it is a pulsing sound based on the speed of the car. If traveling at 20mph, the noise is quick with little time between intervals. When slowed down to near 5mph, the noise is drawn out with moderate time between intervals.
The breaks have been replaced. The car has been brought to the dealer (whom blamed the breaks, incorrectly). I have also taken it to another mechanic (whom blamed the tires, incorrectly - why would rubber cause metal creaking/grinding noises? oye!)
Has anyone experienced this, or know what may be causing it? Please help!
Thank you in advance!
