Chevrolet Blazer Engine and Performance Problems
I am consolidating many of the topics that deal with engine related issues and engine performance.
SUVs and Smart Shopper
I have a 1998 Chevy Blazer. The Idle is fine, the acceleration is fine.
But when you get it up to a steady speed it Misfires.
I have changed spark plugs, and plug wires. Replaced the fuel filter.
Ran injector cleaner time and time again.
I don't know what else to do. Can you PLEASE help me?
thank's
John
s
s
Thanks David
You have a MAP sensor or mass air pressure on the manifold.
Anyway good luck hope it helps.
My 86 S-15 Jimmy ( 1992 engine )311,000 miles, 2.8, started having a slow idle and stalling( ran fine) so I figured I would find the vacuum leak with starting fluid. Found it,(vacuum fittings on air cleaner) idle came up so I turned it off and walked away to find a small fire by the fire wall when I came back a few minutes later.
It could have been worse. The coil and electrical connectors on them were partly melted along with the insulation on the wires going to the connectors ( but they are identifible by going back a few inches) and the distributer cap melted up one post.
What is that box mounted with the coil with what looks like heat fins on it?
I will go to the Junk yard an get a coil ( I need the connectors on top too) along with that box I can't identify ) replace the distributer cap and then I am stuck.
Maybe I will get lucky and find the vacuum hoses and fittings also but I have the feeling that without something showing me where all the vacuum lines come from and go I am going to be in trouble. I ordered a Chilton Manuel maybe they will have a diagram.
Any ideas for someone who is kind of a parts replacer rather than a mechanic?
I am also posting as a Public Service Announcement that ether ( starting fluid ) can take some time to ignite so don't walk away soon.
1. Vac comes from underhood drivers side. Follow the vac line 5/32" from by the valve cover PCV over to the drivers side and replace rotted lines (all are) and to a vac reservior can in the fender (yes you can feel to put a new line on) and one Ts off to run down to the 3 port and the final plastic at the end is for the heater controls.
2. On the 3 port rubber connector if you look inside it you will see 3 holes/lines and a keyed position hole. With the keyed hole at the bottom of your view there are 2 lines above one on left is the VENT line one on right the VAC line from the engine. Then the third line at the peak of the triangle is to the front ACTUATOR line.
3. Straight lines from the vac and to the actuator. But that vent line is T to a transfer case vent line and then should run up the transmission dip stick secured by a tie and has a vent cap on it.
4. Another check is to look at the 3 port switch which then has 3 plastic line tubes/connectore and a fixed plastic pole as the keyed position (of the rubber to line up). Looking down on the top of this 3 port switch the vac is on the left, the vent on the right, and the top of the triangle line is the actuator.
Thats it - take your time and it should work. I would change that switch anyway while under there so if any problems rules that out up front.
I couldn't believe it when a mechie showed me what it was. Are you ready?
It's the painted on Gates logo and part number. When the label goes by the top idler pulley (it is running on the back side of the belt, remember)the paint used on the label makes a distinctive "chirp". The label is painted in two different spots on the belt. I took a little silicon grease and rubbed it on one of the labels and, sure enough, only got the chirp half as often per belt rotation. Rubbed the grease on the other label and the noise disappeared completely.
The mechie said with time the noise will go away on its own, but that he had seen this on numerous belts. Treating with belt dressing will help for a while, but the dressing doesn't stick to the painted label, so once is cleans off, back comes the chirp.
Durndest thing I have seen in a long time.
I decided to switch out belts. I read through the forums and based on others recommendations for noisy belts I decided to go with the Goodyear Gatorback or a Gates belt. I went to Pep Boys, and they didn’t have either. So I went to Napa and they pulled a “Napa” belt off the shelf. I was about to walk out when the guy showed me on the back of the label that Gates made their “Napa” label belt. I decided to give it a shot. I replaced the belt and the noise was cut by about 2/3, but still there. Then I read your blurb about the Silicone Grease on the label, and it worked like a charm. The only silicone grease I could find was “Danco Silicone Faucet Grease” at Home Depot, but it worked. Thanks for the advice!!
Jim
For all - 3/36 or 3/50 on coolant change do not believe the Dex Cool 5/100 crap. At same time always a new thermostat and Stant cap.
thank you
i am thinking that is is a problem that is acuring becouse it was brining up a code and they checked it when they replaced the sylnoid and tranmission computer i still get a little hesitation so i am going to try and replace or clean this out first and if it dosnt help then take the car back to the shop on monday and get looked at agen
