I pull a 3,000lbs pop-up camper with ease with my Santa Fe that I could never pull with the CRV. I love my Santa Fe and the way it drives. I'm very glad I didn't get the honda.
First, after I just completed my 10,000 mile service the check engine light came on. I took it immediately to the dealer and was told that after they ran the computer diagnostic, low gas was the problem. This doesn't make sense because I brought the car in with 50+ miles range left to drive and the low level light was not on. Although the check engine computer registered the engine misfiring, it seems they are not diving into the problem.
I have a problem with the service guy telling me that the gas was too low and that is the resulting firing problem. If that were the case, how come everytime the low level light goes on that the check engine light doesn't come on? I think a more detailed diagnostic is in order but the service manager seems to think that I am some dumb girl that just ran out of gas. But what explains that fact that the low level gas light indicator was not on and the estimated range of 50+ miles readout when I brought the car in?? By the way, my boyfriend was driving my car and he did run out of gas...no check engine light came on then, so what gives?
When I got my Santa Fe, I had an oil change after the first 1200 miles at the end of the "break-in" period. Then I do them every 3000 miles because of the excessive heat and city traffic here.
I had my engine air filter changed after 1 year - it was dirty. I changed the cabin air filter at the same time (Pep Boys $20) and it was dirty too. I noticed a significant increase in the A/C fan performance for the summer after the change.
I
Honestly, it is an okay car. Some squeak and rattles, but I never had any mechanical failure.
Initially, it drives ok. As time goes, I found the the front seats were too high. Also the shape of the seat was like a half egg shell. It was very uncomfortable. It takes me a month to find that out and I develop a serious lower back pain that affect my sleep.
Also the leather used in Santa Fe does not last. Quickly, they look pretty beat up.
When I decide to change car to ease my lower back pain, I went to several dealerships. Most of them were only willing to trade it for 1/3 of the price I paid. I end up give hyundai another try since they gave me the best trade-in value, which is about half of initial price.
Another thing is that the dealer I bought it was bad. They promised me the loaner car when the car is in the shop. However, when I went to the dealership after I called to confirm the loaner car, they just told me that there was some problem with their computer and the loaner car was not available.
Anyway, it is bad experience for me.
Santa Fe 3 weeks ago. I started reading this forum at that time and I am 1800 posts behind, so excuse me if this has been discussed already. I read that the dealer can program the door to auto lock at 15 mph. My question is can they be also programed to unlock when shifted into Park or the engine is shut off? BTW, so far love the truck, except for a vibration in the dash. Ouch, only 1000 miles and how will the dealer correct that?
The panel in question shuts against the side of the dash. The door panels just touch the ends of the dash when closed, and you can actually feel the vibration coming from the joint by the handle mechanism. I ended up putting a drop of superglue to join the panels together and stop the cavitation. So far it works.
It's because the cabin is so quiet you can hear every squeak and rattle and we all expect a Rolls Royce job at a Hyundai price !
Have you checked your tire pressure? Most S.Fe's are pumped up to 44 psi for delivery to prevent flat spots, and they always seem to forget to deflate them to 30 psi cold for the 18" tires. If overinflated, that may also make any vibration worse.
Look on the drivers door jamb plate for the build date and whether it was Korea or Alabama.
If it's any consolation with the vibration, when the weather is warmer and everything expands, the noise may go away.
Also look up how to replace the cabin air filter in your owners manual, for information. For further info look up post #662 under Santa Fe '07 Maintenance and Repair board.
Your head unit is probably fine. It's just as easy these days to make a decent car stereo amp with wide frequency response and adequate power as it is to make a junky one. Your head unit comes from Delphi, which is usually pretty good. If, as you've indicated, you're happy with its design and functions, I'd leave it alone. Changing speakers is your best bang-for-the-buck move. Most head units are capable of much better sound than the OEM speakers provide. Provided you upgrade to GOOD aftermarket speakers, your sound should be measurably better. I'd suggest brands such as Pioneer, Polk, Boston Acoustics or similar, and be prepared to spend AT LEAST $100/pair, and maybe up to $200/pair to get a significant improvement. Depending on how loud you like to play your music, an external amp might not be necessary. It's a simple step to change out the speakers first, and then decide if you need an amp. If you do, I wouldn't think you'd need more than 50 watts per channel (that's RMS, not "peak power"). Feel free to ask for more suggestions.
BTW, I haven't done this to my SF because I'm lazy, and the OEM speakers aren't THAT bad. The bass is kind of boomy, however, so a change might be in the wind...
2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2013 Ford F-150 King Ranch, 2000 Pontiac Trans Am WS6, 2001 Kawasaki Vulcan 800 Classic
