Chevy Cavalier Rough Idle
ok so i just got my ehaust systems fix on my cavalier...but now im having problems with it stalling out as i come to a stop...my plugs seem to be fine..me and my dad checked them out. I googled the problem and i didnt find much..but i did fine someone saying something about my master cylinder for my brakes and the seal..??? i just wanted to see some feedback and if someone knew something that could help me out..it runs fine for about 15 mins then it starts stalling out when i stop...i have to put in neutral rev the crap out of it then slam it into drive..and i hate doing that to the car. if anbody could help ill love you for ever..lol
Also, I've read that sometimes resetting the computer can solve a car running rough. Disconnect the battery for at least an hour or so. After you reconnect it and start the car, let it idle for 2-3 minutes while it "relearns" the idle.
Next, drive at moderate speeds for the first 15 minutes, sometimes with the A/C on, to put different loads on the engine. That should take care of the computer reset and, hopefully, the idle problem.
I had an Opel years ago that sat in the driveway for over a year. Although most of the gas had evaporated by the time I got around to working on it the remaining stuff in the tank looked like maple syrup that you'd pour over pancakes. I had to clean all that out and ended up replacing the pump.
You might start with the simple things and add a bottle of quality fuel injector cleaner to the tank after you're sure all of the year-old gas is out of there and it's running on a fresh supply.
You might also replace some of the easier and less expensive things that I mentioned in the previous message like the PCV valve and fuel filter, especially if it had the same gas sitting in it for a year.
Will test light show if there is power if it will I have tested it and there is nothing
any ideas please :mad:
deff. get new spark plugs and wires.. this same thing happend to me.. my wires and plugs were the expensive ones and were only like 2 months old and some how [non-permissible content removed] the bed and they did not evin look bad.. so i bought new ones and the problem went away..
*~* J *~*
[email protected]
