Ford Taurus Fuel Pump
kstoecklein
Member Posts: 4
in Ford
I have a 2000 Taurus, 104K miles, 3.0 DOHC engine, auto trans.
This situation has happened to me 4 times within the past 7 weeks, and seems to occur at random.
The problem (so far) typically occurs after a short drive (approx 5 miles), and after the car has sat for at least a few hours (as when driving home from work or shopping). I'll stop to pick up my mail at the apartment complex, shutting off the car for about 1-2 minutes. Then as I'm driving away, the engine dies and will crank but not start as if out of fuel. After letting the car sit for about 30 minutes or more, it will start and run normally. I have determined that after the engine dies, the fuel pump is not running, as I cannot hear it run-up when the ignition is turned on. When I do hear the fuel pump run-up, the engine starts fine. I have subsequently replaced the fuel filter and fuel pump relay (in fuse box under hood) and it would seem the only thing left is the fuel pump itself. I took it to a dealer and they were no help, since their diagnostic machine didn't see a fault code. I am hesitant to replace the fuel pump ($600 job!) unless I know for sure that this is the culprit and will solve the problem. Also, this does NOT happen only on very hot days, and the car has always had at least 1/2 tank of fuel when it occurred (these always seem to be suggested causes).
Is there anything else that could cause an intermittent fuel pump failure? It seems to me that if the fuel pump were bad, it would be more obvious and just stop running for good.
So...... I'm good to go, and I hope this will help someone else down the road.
Thanks for everyone's input.
Well, I'm just glad to be up and running again.
Question:
1. Is there a check valve in the system that prevents the fuel from draining back into the tank when the pump is off. If it is lkeaky, the heat of the engine could force the fuel out of the fuel manifold and possibly put fumes into the pump making it loose its prime. A waiting period may allow the fumes to dissapate and allow the pume to operate again.
2. If there is not a check valve then the gears of the pump would perform the same function. If the pump is worn and the fuel leaks around them then the same condition could occur. Can anyone confirm this possibility?
Thanks Vector1
Any and all suggestions would be appreciated as I am getting very frustrated.
I still have an in for Ford or Motorcraft parts and can save u some $
My e-mail address
cliff0rd20@comcast.net
My e-mail address
Cliff
I'm working on a friends 99 taurus 4 dr.. Towed it 3 hours to my house from his daughters place who had it before it died. My testing shows inertia switch ok( not popped) relays in the black box ok....swapped them around, however, I'm not hearing the fuel relay pull in. "0" pressure at test valve on fuel rail when in "on" or "start" Listened with a stethascope against a long drill bit shoved down the fill pipe to see if I could hear anything...nothing. So what prevents the fuel relay from turing on?? By jumping 30-87 on the relay base turns on the fans but not the fuel pump.I'm going to check grounds and maybe run a separate ground for it and secure it to the floor as recomended previously. I'm not convinced that the problem is the pump. Not till I see good voltage at the pump with a good solid ground. Do you know what colors should be what on the fuel pump harness? I'm thinking I may find crushed wires on the top side of the tank... any ideas??
i own the same car for over 3 years now,sure what is happening with you is happening with me,try change the cables that connect the spark plugs but anyway it a normal thing with this car,when cold it starts slow, especially in morning but when hot it starts fine
I had the fuel pump not kicking over when I'd turn the key. I'd turn the key back and forth and finally after a few minutes or half an hour of turning the key back and forth fiNALLy the fuel pump would kick over and I could crank the car - it'd then start up.
I finally got stranded for 2 hours with this issue and after going back 3 hours later to tow the car to have the fuel pump replaced it started right up. I changed the fuel pump anyway just to get it overwith. This was in October. Now 3 months later the cars just dieing while Im driving as if I'm out of gas. Even though I calculate it quite accurately. Of course meaning ever since putting in an 'Airtex' Complete assembly it reads the wrong amount of fuel and was never this way before. I've checked everything from ignition to spark and even hear the fuel pump kick..just sounds as though nothings going through. I added 2 fresh gallons just in case and get nothing. Not even any pressure when I checked the valve on the fuel rail.
Yes the line is clear, fuel filter is new, relay is good and even swapped around with others. It cranks over to a start with sterter fluid but does not stay running. pulled spark plugs and bone dry. gotta spend more money on another fuel pump so I can actually get the motorcraft rrrr... any other known issues before I go break my back yanking the stupid pump agaIN??
to rear,for any sign of leakage. If you DO have good fuel pressure and no start, replace you idle air control valve. it's mounted by the throttle plate air intake, about 3" long, elect plug in on end and mounted with 2 8mm bolts.
hope this helps.
link title
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Anyway, test the fuel pressure make sure it meets specs. Possibly an intermittent problem with fuel pump relay. Do not rule out the fact that you could be losing spark and you actually have intermittent electrical problem. Don't forget to check for spark after it stalls!! If no spark suspect crank sensor if equipped but problem is probably related to something that controls both fuel and spark!
Hope this helps
Check these items & let me know
Cliff
have you found the Hot feed wire that goes to your pump ? Do you have access to a fuel pressure gauge ?
If you apply 12 V to the pump,with the key shut off, can you hear the pump run,build up pressure than stop ?
Cliff
Dropped gas tank and checked wires. No voltage to the fuel pump or very low voltage if any. Ran a hot wire from the battery to the pump and it runs. Checked the inursa switch and it is OK. Changed the relays around and purchased a new fuel pump relay. Installed relays and checked for power and no power. Checked under the dash all fuses and nothing wrong there. Followed wires around car and nothing seems out of the ordinary. Ran a hotwire from the fuse box to the pump and pump does work. Checked all grounds applicable to the fuel pump. Is running a hotwire such as I have done really OK to do or should I start over and keep tinkering with it?
1. with key off & 12 V to pump, does the pump run for about 2 sec and then stop running ?
2. do you have access to a fuel pressure gage. ?
3. Hard starting may be due to a bad air/fuel enrichment valve, located on the air intake at top of eng. This valve has a diamond shape base and is mounted with
2 8mm bolts and has a 2 wire loom at the end of tube.
You can buy a new 1 at NAPA. These valves have been known to cause hard starting.
