Hyundai Tiburon Electrical and Lighting Problems
defiant_1950
Member Posts: 1
I have a 2003 Tib with under 120000K on it an have just been told the main computer has an electrical short and needs to be replaced. It is causing the left side hazard lights to remain lit after the car is turned off. Has anyone heard of this before and does Hyundai have any secret or hidden warranties for such. This seems awfully early in the cars life for a computer failure doesnt it. Regular checks at dealer, well maintained????
Of course, I think you meant 120,000 (or 120K). Still, it is not early in a car's life. The model year (2003) may be recent but 120,000 is not.
It does sound like a legit issue and probably does need replacement. However, if you are uncertain, as your post reflects, I'd seek a second opinion from a local mechanic or something.
http://www.mouser.com/Search/Refine.aspx?Ntt=*NEC*+*EP23N1ST*&N=1323038&Ntx=mode- %2bmatchall&Ns=P_SField&OriginalKeyword=NEC+EP2-3N1ST&Ntk=Mouser_Wildcards
Her is a link to rapidshare.com free file server, this is a pdf file of the entire repair with pictures.
http://rapidshare.com/files/95798381/turn_signal.pdf.html
if you have any questions feel free to ask.
Can anyone tell me how to replace a bulb for the break lights?
A000SNAKE...
http://www.mouser.com/search/Refine....1ST+&N=1323038
The companies name is mouser electronics.
I dont know if they have a minimum order when I called them back when I needed mine they were on back order so i went with a different company. I hope this helps.
Here is the site that shows how to repair it also. It worked on my wifes car.
http://www.newtiburon.com/forums/showthread.php?t=102241&highlight=bcm
i am adam from America.
this is my first time to be here.but i need you help.
I want to buy a new GPS Navigation.There are so many GPS navigationS in this website
Eeveryone looks good,i don`t know which is better for my car(Hyundai IX35 ). Could you give me some advices.God bless u,thank u.
I have checked for a bad ground or frayed wires, also checked to see if the clutch pedal is rubbing anything.
Any input would be greatly appreciated.
The problem is 2 fold, the chip starts to go bad and the wiring used in the 2003 Tiburons may not be up to code on the cars if there is one.
Additional power sources can short the BCM. Once the BCM starts to short other components including the radio, GT, may start to go. You need to do something before this happens.
Basically what I believe happens the BCM Chip(non fixable) get leakage and breaks down over time. This changes the current coming from the chip which results in the electrical failures the car is now facing.
The thing that gets me fired up is the car has fuses that don't blow. When a short happens its suppose to blow a fuse. This does not happen from what I read from other post. Probably because the short is internal(can't get to the fuse). The other thing is removing the BCM is a project by itself. It took me half a day pulling it out and putting it back in just to replace the relay. A mechanic is going to charge you $800 in labor to do it.
So let me say before I give you my opinion I love the 2003 Tiburon had lots of fun with it when it worked.
Heres your choices 1 replace the BCM and wires that were damaged. A mechanic is going to charge about $1500 bucks. You could do it by buying the unit for $600 and installing it yourself. There's guides on the net how to remove it and Hope to heaven the other electronic components are not damaged. 2. Buy a new car 3. Find the voltages the failing components are running on if they all are 12 volts run a wire to the inputs from the battery with a switch in between and attach them to the dash or door. Good Luck. If I replace my BCM will update.
Have ypu figured out the issue!? I'm like so ready to throw in the towel and get a new car. I love my 2008 tiburon but this BS is getting ridiculous!!!!!!
If you do need to change a fuse, that will be cheaper than a relay. Fuses are on the the order of $5, relays will be in the range of $10 - $20.
But first, find out what's sparking under the hood. It might be as simple as a wire that has rubbed raw and is now shorting to ground.
