When driving along in the evening the headlights occasionally blink on and off. I turned on the headlight switch thinking it was the sensor but it still does it. Any thoughts? Thanks, jmurray171
the problem lies within the cluster board itself. I repair these because it seems to happen to all of the 97-2004 models. If you want, contact me at ANCTechnologies at hotmail.com
The rear blinker on the right side blinks fast, and the front bulb doesn't work at all.
I've changed the socket a couple of times....no difference.
I can sometimes clean the connectors and/or wiggle the bulb around but it'll only work for a couple of right turns).
Chuck
don't even have
a dipstick for the trans. The last time I had my pan off I welded
a
plug in. Changing trans fluid is a big mess any way you go about it. My kids Saturn has a drain plug & a spin on filter. I guess that made too much since so gm's answer was to quit making the Saturn. I thought they had a decent product with Century and Lasaber but they got dropped. Same way with S10.
I have a 2002 Buick Century that will not start. My friend has looked at it and checked the fuses themselves and says that they are good. He believes the problem is something to do with the the fuse box itself going bad. Can this happen? He knows more about cars then I do but this has both of us stumped. Something about an electrical low? (not sure about this part) We've tried putting it on a charger but I don't believe its the battery. We've tried jumping and still nothing.
my car is in peices and my wife is gonna have a baby any hour lol
what was the fix?
hope this helps., did for my dads car. Also helped fix the electronic climate control using another solder technique. also has bad resistors that burn and when resoldered worked again like new!!!!
Issy :shades:
pull tape and check wiring
Chuck
I am having the same problem. I think I have located a used part but not sure. Does anyone know the part number or what the replacement part is called. I would appreciate any info anyone can give me.
I pretty much know it's a mechanical prob with the vent mechanisms, but what can I do about it?
Chuck
I have a buick century 2000. this is the problem, the blower motor on the passenger side will not turn off, even with the engine off and the key out of the ignition. the only way to get it to stop is to pull the 60amp maxi fuse at location BAT#2. this however disables a couple of things including the break lights so of course I just got pulled over and issued a warning for nonworking break lights. I have disassembled the heater control panel and disconnected the two wire bundles but to no avail. please help.
thanks.
bob
http://www.mrwhizard.com/index.cfm
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
