Chevrolet Tahoe Noises and Sounds
02 Tahoe, 120,000miles. when i turn the steering wheel it makes popping/clanking noises. when i turn either way. i heard some where it could be the CV joint. does anyone have any ideas?
if it is the CVjoints how much should something like that cost to fix?
thanks!
thanks!
As an aside, he also noted significant wear on the inside of the front left tire and suggested an alignment. I've never had one done (he said GMC suggests annually or every 12K, but I've never seen that recommendation before). I do get my tires rotated every other oil change, but he said it's obvious my tire place has only rotated front to back and not side to side. That ticks me off that a Goodyear shop would be so lazy. Anyway, the alignment would be about $70, and for $100 he offered to do a full "suspension service". Alignment, properly rotate and balance tires, lube the chassis.
He also tried to sell me on a $600 30K service which includes a whole bunch of stuff that's not in the maintenance guide. I know for a fact that it doesn't need anything until 50K when it calls for a transmission service, so I passed on that. But I am glad to get the other stuff done before we hit the road on Thursday, and really glad my wife and I noticed that steering shaft problem before the warranty expired.
Just started getting this symptom.....
Start the truck and a loud clicking noise that sounds similar to two pieces of plastic making contact, maybe like a gear skipping a tooth, emanates from under the dashboard on the passenger side. Click rate is about every 0.5 seconds and lasts for approximately 90 clicks and then stops.
Then when the ignition is turned off, the clicking starts again and lasts the same duration.
I suspect something in the climate control ductwork flow control. Just curious if anyone has experienced this and how it was resolved.
Thanks in advance!
Joe
Hope this is helpful.
Tires OK
Steering fluid OK
Has anyone faced the same problem?
Tires OK
Steering fluid OK
First, if I turn completely left or right there is a quite a popping noise. I imagine this is a warning as I cannot turn any farther, however it does seem very loud.
Second, every time I start the vehicle it makes a strange "static or grinding" sound after traveling 1-2 minutes. Only lasts a split second. Doesn't seem to matter if it is cold or warm out.
Want to get this figured out while still under warranty. Dealer did something w/ steering column and is waiting on another part, but for now it hasn't been fixed.
Thoughts?
____________________________________________________________________
I think this is a normal thing with all Suburbans. There was a post on this some time ago...I can't remember exactly what the sound was....something to do with the vehicle electrical system.....maybe a systems check upon start-up...whatever. Not to worry.
I had yet a third rattle, which was the steering column sleeve that was replaced through a recall.
I'm thinking I need to take it back to the dealer to check these other noises (before the warranty expires). But if anyone has these same issues or suggestions, I would appreciate it.
Is anyone else having this issu? I have an '05 Tahoe. I hear a low sounding front end rattle/squeak that is heard when going on any uneven roads or bumps. I've looked at all the TSB for the Tahoes/Suburban/Yukon and I found the following TSB:
Suspension - Rattles/Squeaks From Front of Vehicle
Bulletin No.: 03-03-08-002B Date: November 30, 2005 TECHNICAL Subject:
Rattle/Squeak from Front of Vehicle (Replace Lower Portion of Upper Insulator Assembly) Models:
2002-2005 Cadillac Escalade, Escalade EXT
2003-2005 Cadillac Escalade ESV
2000-2005 Chevrolet Silverado, Suburban, Tahoe
2002-2005 Chevrolet Avalanche
2000-2005 GMC Sierra, Yukon, Yukon XL Supercede: This bulletin is being revised to update the correction and parts information. Please discard Corporate Bulletin Number 03-03-08-002A (Section 03 - Suspension). Condition Some customers may comment on a rattle or squeak type noise coming from the front of the vehicle. Cause The front shock absorber plastic pilot ring may be wearing out, causing the shock to misalign in the insulator. Correction DO NOT replace the shock. Replace the lower portion, P/N 15834275 , of the upper insulator assembly using the procedure listed below. This new insulator has a taller plastic pilot ring that is attached to the metal sleeve to aid in the proper alignment of the insulators. 1. Remove the front shock absorber. Refer to the Shock Absorber Replacement procedure in the Front Suspension sub-section of the Service Manual. 2. Remove the lower portion of the upper insulator from the shock and discard. 3. Install the new lower portion of the upper insulator to the shock. Important: Be sure to center the shock in the frame bracket and tighten the upper mounting nut when the vehicle is on the ground. 4. Install the front shock absorber. Refer to the Shock Absorber Replacement procedure in the Front Suspension sub-section of the Service Manual.
http://www.chevroletforum.com/m_29668/mpage_1/key_/tm.htm
Rattle from front left, when turning left
Cause: noisey E7638 Support, Steering Column Replace 469 WS96
FC: 2W part#: Count:0
Thumping noise
Cause: Noisey E7620 Bearing and/or Bushing, Steering Shaft Lower Replace 469 WS96
1 88963617 Bearing 1 Misc TC
I haven't driven it enough to know whether these fixes solved the problems.
SUVs and Smart Shopper
