Older Camry Maintenance and Repair
jaybird0013
Member Posts: 2
in Toyota
The power windows on my 89 toyota canry will not roll down or up. But the lock works what could be the problem?
My 2001 Camry eats a quart of oil each month. I've had all leaks, seals, blah blah repaired, had it checked for oil gel, everything, by multiple mechanics. No one can discover the reason and I'm getting very annoyed.
The second thing that just started today is that durng low speed turns, like in the parking lot (turning in either direction), there is a weird creaking noise from the front passenger side wheel. I will be calling the mechanic, but would like to get opinions so I have some clue what's going on.
Finally, the car's CD player seems to actually damage CDs. You can put a brand new CD in there and soon it will start skipping. The more you play it in the car player, the worse it gets, and then after a bit it starts skipping in other players, too. I have cleaned the CDs carefully and I have also cleaned the CD player and none of these things have helped.
I am running out of money to keep spending on mechanics, and my credit cards are already charged up from car expenses like tires and brake replacements. The Toyota dealership is the worst quality, slowest, and most expensive for service, too. I'm at my wit's end. Can anyone offer advice or ideas? Thanks in advance.
- Regarding your creaking when you turn the wheel, it could be the constant velocity joint (the joint where the drive shaft pivots at the front axle). If the car is driven hard, those joints begin to go first at the extremes of angles. It could also be some other suspension parts, like the strut.
- Regarding the CD player, I'm guessing the cheapest solution is to replace it. By the time you have someone take it out and try to open it up to look at it, you could replace it.
- Regarding your oil consumption. I think the first thing you need to determine is whether you are leaking it, or burning it. Since it sounds like you have had some seals replaced, I'm suspecting that it's not leaking anymore but it's burning it up. If so, I would expect that you would see blue smoke out of your exhaust. Do you see smoke only at start up (indicative of bad valve stems), or all the time?
What is the history on this car (how many owners, mileage, etc), how hard has it been driven, and do you have/know the maintenance history of it? How religious were the oil changes done?
Not sure if you can see down inside the window slot enough or not. This link might help with what the door striker looks like.
doorstriker
Good luck
Regards
DIY-1 :confuse:
Normally, there are two things turning on the radiator fan. A temperature switch showing high coolant temperature, or the A/C clutch running.
Thanks for your reply
Why did you replace the temperature switch last year? What symptoms were you having, and how did you determine the switch was bad?
Regards
DIY-1
Assuming the fan is stil running after pulling the wire to the temperature switch, then pull the Radiator Fan Relay #3.
If the fan doesn't turn off, the the problem is your Radiator Fan Relay #1. If the fan does go off when you pull Relay#3, let me know....as we'll have to figure out whether the problem is in Relay#2 or Relay#3.
I pulled the wire to temp' swith not directly at the switch, but on top of the rad, there is another connector, connecting with the wire to the temp' switch. 2 wire in, 2 wire out.
The fan still run, i pulled Rad' Fan Relay # 3, fan still run, then pull Relay # 2, fan # 2 goes off, then pull Relay # 1, Fan # 1 goes off??
I tried the same with Dash fan turn off, defroster & A/C turn off, same result??
do you think there is a ground broken somewhere ??
Thanks you so much for your patient.
DIY-1
The primary coil is on pins 1&2. 12V on pin #1, ground on pin#2.
The secondary switched contact points are on pins 3&4. With pin 2 grounded, apply 12volts to pin 1, and verify that contact points are working correctly.
Do not swap relay#1 with either of the other two relays. They are different.
How do i apply 12V to pin 1 ?? sorry i am a newbie at this.
DIY-1
When you are doing that, you want the continuity meter (measuring ohms), to be measuring across 3 to 4. You should see the meter change from infinite resistance, to no resistance, to infinite resistance as you connect and disconnect the voltage on the primary.
I'm expecting you will find that your ohm meter never goes to infinite resistance across 3/4.
Well I've got the fluid out the filter off as well as solinoid 1&2 and as I was taking off the rear sol. I noticed the bolt was about two threads loose whaat would cause this and more important do you think these would cause the tranny to shut down or is the speed sensor suspect to, also is there a way to bench check these to see if possibly the loose bolt was the problem...
Thanks so much for your help
Check your carspace mailbox ryan99. Access your mailbox via the 'Mailbox' tab, upper right hand corner.
I have the exact same problem as ryan99 regarding the intermittent wipers on my '97 Camry - is it the switch or is there a separate solenoid I can easily change out? I do have auto repair do-it-yourself experience.
Appreciate your help.
Phil63
wiper circuit
Phil63
You might also check to make sure you don't have a lot of crude in your radiator, blocking the coolant flow thru the radiator.
Warning light coming in saying "replace brake light". All brake lights are working. Assuming problem is light sensor module.
Would appreciate any one's help with on-line source for a picture and purchase sight.
I'd suggest taking it to an autoparts chain, and have them read the error codes for you (or buy your own reader and do it yourself). Let's see if we can get an error code which will point you to the right area.
I just purchased a Toyota Camry xle v6 from a seller.
It has 74k miles on it.
I got it inspected from Pepboys before purchasing it.
It seems the previous owner has not done any 60k servicing to the car.
Can you folks please suggest me what are the things to be done. This is my first car, so i dont have much knowledge about this.
Adam
E-Mail: Adam_Michael_00@yahoo.com
I don't know what you have for a continuity tester, so I don't know what the results mean. I assume by using a continuity tester on the fuses, you are using an ohmmeter which measures the resistance, and that resistance is now showing a short with no resistance.
You say the continuity tester has a light on it. When is the light on that tester supposed to go on, and what does it indicate when it's on? Is it indicating that it has detected a voltage, and if so what is the minimum voltage that it is indicating? Or is the light indicating that there is a minimum resistance (of some level) between two probes of the tester?
I'm suspecting that what you are finding with your tester (light goes off when you crank starter), is not really a problem.....but it isn't really clear to me what and how your tester is measuring.
The starter puts the maximum load on a battery, so if your starter is running fine then I assume that your battery output is fine, as well as the connection to the main power buss (no corrosion on battery terminals, and you replaced the first fuse box holder and fuses).
So with the engine turning via the starter (but not starting up), the next place to look is for fuel delivery, compression in the cylinders, and electrical spark.
I'd suggest pulling the plugs and checking their status (how old are they, is the gap still correct, do they need replaced?) . What color are they collectively, and individually? Are the blackened showing too rich condition or buring oil? Are the wet showing flooding/too rich? Is one color different than the others, showing valve/electrical spark/compression problem? What condition are your electrical wires and rotor?
If all of those check out fine, or you find differences in the look of the plugs, then consider doing a cylinder compression test to verify that your valves and rings are okay.
From a fuel delivery perspective, you need to know that your fuel pump is working and able to deliver fuel.
I don't know what diode you are referring to. Diodes are used to convert alternating current to direct current (your battery). There are diodes in the alternator, but you indicated that the alternator checks out okay. Was that comment just a shot in the dark type of statement, or are you suspecting one of the alternator diodes?
I was getting 12V from the connector that goes to the master switch, but now its only getting around 6V. Im guessing theres another fuse or something fairly obvious that blew when I tryed the second switch (since then its only putting out 6V). The only fuse ive found to be blown is the obd fuse. Are there any other fuses relays etc that affect the power going to the master switch?
I have a 2001 Camry Collectors Edition. Regular oil changes/maintenance. Recently the check engine light went on, at first the dealer said the oxygen sensor needed to be replaced. Then they called back, saying they are having a hard time taking off the oxygen sensor because the manifold may be broken and they may have to replace the manifold? This is going to cost $1300 per the dealer, and I was wondering if there was a TSB or something covered under any kind of warranty to reduce the costs. My car only has about 46000 miles.
Mahalo!!
- When I bought the car, I used to get 33 MPG on average between Highway/City driving.
Lately (5 month ago), the car MPG went down to 22 MPG. I took the car to mechanic shop, which changed Air/Fuel filters, spark plugs , balanced tires, did some other tune ups . These misc. repairs did not result in any improvements.
- In the last year or so, every time I speed up to 60 MPH or more usually in highway, I either smell burnt rubber or any bad smell.
- Two days ago, check engine light came on; the mechanic put it in computer which indicated problem with catalytic converter.
Any idea what is going on with my car? Are all these issues related? Any suggestions to fix the MPG issue?
Appreciate help in this regard
