Also, I'm looking for the company that made the cold air intake for Brian when he was with LLSOC.com. The smog inspections are wanting to see a sticker on it so they can pass it through the smog rules. I have the receipt but there's no manufacture info on it or anywhere on the polished intake.
My understanding is, if you catch the secondary chain tensioner failure before the nylon comes off, is wound through the 2ndary chain and sprockets (stretching the chain) then that crushed nylon drops down onto the primary chain and/or tensioners causing more chain and tensioner damages before all the residue ends up at the bottom of the front cover area. Some folks are lucky, the nylon comes off, does not grind past the 2ndary sprockets etc and free falls to the bottom of the front cover.
With that, the noise of the upper chain and tensioner are loud enough to alert the owner/driver something is wrong enough to no longer run the motor and seek repair. Those who aren't that lucky and both tensioners/chains are damaged, the resulting damage is from the pistons striking the valves bending them. Once that is done, the heads have to come off both side and the job is likely going to cost more than the vehicle is worth.
I had two Ford Products before this and they were great. Lincoln would have to come up with the best warranty out there before I would consider another one. I now have a Lexus and am very happy with the quality of it.
p.s.
do a little forum research on the product that you find before purchasing
I get the frustration with a lemon car, I have a backyard full of them. However its ignorant to pursue a company that didnt even design the engine. Ive always had the idea when buying an expensive car that its going to be high maintanence and expensive. After all its a jaguar engine.
