Veracruz Limited Power Tailgate
The subcontrol button on the base of the tailgate itself does not seem to be functioning, it just beeps when you press it. There is no problem with power operation from the key fob and driver's seat however. Does anyone have any ideas?
Two weeks ago the power rear tailgate ceased to function. Tried the fob, dash button and outside the hatch itself. Took it to the dealer a week ago and after hours of diagnosing, they decided to order a module and replace it. We picked up the car yesterday we tested the tailgate and it worked so off we went. My wife ran a few errands and then went to pick up the kids and....... the rear tailgate will not open. ><
So now we're back trying to have the dealer tell us what the heck is going on. Anyone else run into this?
See how long you need to hold it for it to start working.
If we do touch the button, it is far too slight a "touch" to have the hatch open.
Normally it needs to be depressed at least a couple of seconds as it should be.
This is a malfunction and I believe it should be recalled to properly repair.
Other wise we love the Veracruz.
Could it be????????????..(what are your thoughts people)......that some neighbor opening his electronic garage door or some other electronic device that has the same frequency is triggering the opening. If so.........wow, this is a real problem.
I tried taking out the 30a fuse in the engine compartment ( so I wouldn't have to "worry" that I'd come out and all my stuff would be stolen), but with that I was unable to even open the hatch manually as the release button on the back of the car to manually open the hatch has some electrical relay which won't work if the fuse is out............Your thoughts people
SUVs and Smart Shopper
1. Approaching the car with an armful of groceries or packages, or golf clubs.
2. Getting out of the car, needing to get something out of the back (saves time)
3. Just wanting a bit of luxury
Have I ever inadvertently hit the OPEN key when the garage door was shut...you bet. But when I first got the Veracruz I put heavy rubber padding at the place where the tailgate would hit the door. Result...no damage at all.
Where did you find the plastic 24pc gum case? I recently purchased a used 2008 Veracruz limited and I had the same problem. The garage door caught the lift gate and put a dent in the lift gate. I've been looking for the gum case but haven't found one yet.
Chumo
Chumo
1. tilt steering not working, replaced motor
2. c\d not working, showing error 42 message. Radio replaced.
3. check engine light on, awd light on vehicle stuttered to complete stop just as I was merging onto the highway. Restarted the vehicle and drove to the dealer. The dealer repaced the TPS (throttle position sensor) and reprogrammed ECM.
4. replaced driver side headlight and passenger side daytime running headlight at my own cost
5. check engine light has come on 3 or 4 different times.
6. after filling up with gas odometer reading not accurate.
7. squeaking sound under the drivers rear suspension.
8. transmission push or clunk when decelerating from 2nd to 1st gear.
9. some plastic trim parts have broken off , dealer replaced under warranty.
items 5,6,7,8, have not been dealt with. I deal with Mississauga Hyundai and they have been helpful in correcting these issues. Have other owners had similar experiences. NOT SURE WHETHER I BOUGHT A LEMON AFTER DOING SO MUCH RESEARCH ON THIS VEHICLE. DEPRICIATION IS BRUTAL ON THIS VEHICLE AND WILL LOSE A TON OF MONEY IF I SELL.
I noticed quite a few complaints of Cruz hatches opening on their own but none with my specific symptom. Please let me know if this has happened to any of you.
One other thing-when we are driving around the city and step on the gas it seems as if the transmission is in too high of a gear. It lugs and feel like there is a loss of power then it catches.
Other than that we love this car! Dark brown exterior and dark leather interior.
