Acura Integra Interior Questions
When the Acura Integra was new, I had all the windows tinted professionally. With the vehicle being almost 14 yrs old, I had to remove the tint from the vehicle. Removing it from the back window, must have pulled some of the defroster lines off. Is there any way to fix this?
1. Water is leaking onto the passanger side floor. A new windshield was put in before she bought it. The cabin has been pressurized to find the leak location without results. I have found that running water at the very base of the right corner of the windshield results in the water in the cabin. From under the dash the water is running off the heater box. Any idea as to what I should look for when I get the black plastic cover off the base of the windshield/engine compartment?
2. An Acura dealer thourghly checked the car over before we received the car and recommended what they called a major tune up which was done. Now twice (21 days apart) at the end of her work day the car would crank over fine but would not start. Either no fuel or no stark but which? On both occasions letting it sit for a couple of hours "fixed" the problem until the next time.
I did say these were long shots but if anyone has a suggestion or two would be appreciated.
have to remove wiper arms to take it off) there is another
plastic cover secured by black plastic clips.on my car the
clips had fallen apart from time and weather. and water was
going thru the clip holes and pouring right down in the blower
motor case,which in turn ruined(rusted out} the blower motor.
tried to get correct clips from dealer, never did,used store
bought push in plastic clips and sealed around them with clear silicone, this fixed the problem. had to replace blower motor.
it wont come out of case with blower wheel attached,will post later how i managed to replace blower motor without
tearing the whole evaporator and dash out of the car.
hope this info helps??
i have a 1995 - Acura - Integra LS Special Edition.
any help on locating these parts would be appreciated!
http://www.uneedapart.com/
Regards
Corkscrew
The front leather seats started to wear/tear abnormally. This has occurred on both front seats. On the side upper panel closest to the door.
I was wondering if anyone else had experienced anything like this??
Only thing I can think of is the rubber lining going bad. Rain or water usually runs down the channels in the hatch area if coming from outside so it doesn't get in. Are the side window seals all OK? Any seals around the doors going bad and leaking? Tough to say without being able to look it over. Do you have a moon roof? Is it shut and sealed properly when closed? IThe only thing you can do is look for the source of the leak.
Open the trunk, standing against car, looking down at the black big plastic piece, but on the end towards you around the front edge there are square black holes...I put electrical tape on all the holes and now no water gets in. Might or might not fix your problem, but thought I'd let you know what I did. Kind of hard to explain, but hopefully you got what I was trying to explain.
I have the same problem ... there is a lot of water where my spare sits, and it's coming from somewhere inside the truck but I can' tell.
It's a pain though since it's hard to tell where the nicks are. I damaged 85%+ of the defroster lines when I had to remove bubbling tint. I managed to fix 3-4 lines using the paint.
Is there a painless way to remove the tint? I need to remove the tint on my driver's side window since it's beginning to peel.
