whats the difference?
gsxrider137
Member Posts: 3
i am looking into buying an 08 impreza wrx, but i noticed the horsepower difference between the wrx and the sti is 80 hp. whats the diffence that nakjes the same motor make more power? anyone know? i am more interested in buying the wrx...esspecially if i can make it make that kind of horsepower easy
Basically, you get a lot more boost and forged pistons to handle the boost, a semi-closed deck block, a much stronger 6 speed manual, and a stronger clutch, and I'm sure much more.
It's not as simple as a manual boost controller and a Turbo-back exhaust to get from a WRX to an STi.
And I also suggest if anyone is going to push a WRX to STi levels, you'd also want the STi suspension, tire width, brembo brakes, transmission, rear diffy, etc. etc. or you run a safety risk.
-mike
with upgrades, whqat can the wrx push out safely?
The weak link will be your transmission and internals of the engine IMO.
-mike
The automatics are actually a little more robust, and can handle more.
