Nissan Altima Hybrid Transmission Questions
My 07 Altima seems to have some type of power issue. If i start from 0mph and press the peddle down a thirdof the way (50kw) and keep it in the same place when the car gets to about 45mph the car kicks the power meter all the way to 0 forcing me to press the peddle down again to get it to stay at 45. It almost feels like it could be the cvt doing something. Feels like shifting from 2nd into 5th - very annoying. Took it to the dealer who told me this is how they work - i dont think so as it wasnt doing it when it was warmer.
Problem still exists and is repeatable. From a standstill press the accelerator down till power level is an inch over the 50kw line. When car gets to 50mph slowly let off on the accelerator as the power drops off it will hang at the 50kw power level and stay there even as you let power off then suddenly power will drop from 50kw to zero which will force you to press down on pedal again to get enough power to maintain constant speed. I would like to know if anyone else has this issue. The car does not stop running or sputter or misfire but feels like it is kicking the gas engine out and substituting the electric engine in its place. The effect is like driving a standard transmission car under heavy acceleration in third gear and taking your foot quickly off the gas the [power drops and nose slighly drops.
The local service manager rode with me as i showed him the problem and he agreed that the power drops off abruptly and he was able to replicate the problem with him at the wheel. He called his hybrid tech who looked at it and stated it was normal function of the car. I called corporate twice on this. Once a year ago when i originally noticed it and also last week. They even let me take a used 2007 altima hybrid to see if it also does it and it does it too but power does not drop as suddenly as mine. Corporate states car is doing what it is programmed to do. I told them it was a safety issue as I do not expect ANY car i buy to loose power while i am driving it.
I beleive the programming on the car is the issue. When it is put in that small power/speed regime it is programmed to drop power to battery or shift cvt to full overdrive or such. I also never seem to get the milage stated30-31 is my usual mpg with winter readings in the 27-28 range.
Nissan has a safety issue regarding this and i am going to contact the NY state attorny general and transportation safety admin. If they do not do something I will seek legal representation for a possible class action suit.
I really love the look and style of the car and would love to keep it but the constant power drop is so annoying i cant stand it anymore.
Anyone have any ideas? Anyone know if it is possible to buy a car data logger that will tell me exactly what the car is doing as I drive it. I am considering buying some type of data logger and hook it to a laptop so I can figuire out exactly what the car is doing when the power drops but im not a car guy so dont know what the sensors report and what equipment i would need to hook up.
Frank
Has anyone else have a parking gear failure? (without the parking brake engaged)
So when I bought the car I had no idea why the KW meter read what it did while driving. Now I think it makes sense, I guess at highway speed in order to get the engine RPM down, the car controls the generator to speed up, generating more power, which it dumps into the electric motor.
In my searching I found some good links on the Toyota planetary systems if anyone is ineterested. I suspect Nissan has nothing out there.
Eph
http://auto.howstuffworks.com/hybrid-car7.htm
http://www.toyotapartsandservice.com/pub/pdf/TechCenterLibrary/ToyotaStarService- News/2007/2007_TSSN_Fall.pdf
http://www.osti.gov/bridge/purl.cover.jsp;jsessionid=F5CBE51F1B2FBDF8F160E7C999C- 2C97A?purl=/921781-VVowU8/
I have no problem around town and when I brought it into the dealer, they said it had not thrown any codes. They drove it and couldn't replicate the problem, but weren't willing to drive it the 30-50 miles it usually takes for the problem to happen.
But I've had this happen so often that I am QUITE sure it is a real problem.
If the temperature outside is cool, I can sometimes get it to go a couple hundred miles by babying it going up hills and not exceeding about 65 mph. But if I go 70-75 mph, it will happen no matter what.
Any ideas?
I imported my Altima hybrid 2011 from the USA , unfortunately the nissan dealer in our country does not import hybrids or their spare parts.
As I bought this car as used, I would have liked to change the eCVT transmission fluid as it has 44000 miles on it, I have read the maintenance book, and it says that the fluid is very specific for this car and have to use nissan genuine Matic W, which the dealer in our area does not have.
Some people have told me you can use Toyota ATF WS, which is specific for Toyota Camry hybrid (as nissan hybrid system is licensed from Toyota ).
Can some one help me with this problem, I am afraid if I do that I might damage the transmission ..
No word yet whether the note applies to the hybrid, whether it would be covered by the warranty, etc.
So my question is whether any of you know whether this has been a common issue with the Nissan 2008 eCVT, with the hybrids, etc.
