2. Wait and get an '05, you're just 8-10 weeks away or so...
I have the V8 with 4WD. Gets 14 mpg. I wish I bought the V6,V6 handling is also more nimble due to light front end.
Wait for the 05 V8 with VTEC if you must have a V8.
In short the X-Reas system works on inertia of the vehicle when going around corners causing the shocks to stiffen up on the leaning side. In theory it sounds great, but in reality I don't see much difference. I complained to Toyota, they said it was working within specs, whatever that means. I also talked to a 4X4 guy, he suggested dumping the X-Reas system and putting on KYB shocks and a stiffer sway bar. I may do that in the future, but will wait until the vehicle is out of warranty.
To be fair about this, I drive in the mountains of Colorado on twisty roads. I don't expect sports car handling, but to me, the Toyota leans to much in the corners.
If you're going to pull a trailer get the V-8, it's a proven engine and performs wondefully. It has a lower power band where you need it when pulling a trailer.
Calling the V6 just as powerful as the V8 is wrong. The V8 has significantly more torque. However, for towing only 3000lbs, either engine will do.
" You also get much better mileage"
2mpg increase is hardly much better mileage.
As for power, the V6 is more powerful by about 4% at its peak, and the V8 has about 14% more torque at its peak. The V6 is lighter and can be operated in 2WD, so acceleration figures are very close. The V8 is quicker off the start, and then the V6 catches up, and some tests indicate it's faster at the top end.
But are you really buying this vehicle for its acceleration? Do you drive with your foot to the floor more than rarely? Do you have a strong desire for the V8 badge and V8 bragging rights? Both engines will likely have ample power for your needs. Only you can weigh your own needs.
I had no problem with the cost of either engine, and drove them both repeatedly. I liked the way the V6 drove a little better, and bought that one, but of course I wasn't spending *your* money. You may be swayed by the greater towing capacity of the V8 or the 10% better gas mileage of the V6, or some other factor not mentioned yet.
On the subjext of X-Reas, I didn't see a lot of difference, and I'm pleasantly surprised at the lack of body lean in corners even without it. In freeway sweepers (ramps, etc) I go faster than many sedans, and still feel I'm being reasonably conservative. Rapid twisties in the mountains aren't going to be fun in any SUV, I suspect.
Hey alfa, congratulations on being the 10,000th poster in this thread!
By contrast, my X-REAS, AWD 4Runner negotiates the same curves (at the same or even higher speeds) with tremendous stability, surefootedness, and without any teetering or impending roll sensations whatsoever. Now mind you, I'm not about the business of trying to see just how far I can push the 4Runner, because it certainly has its limits. I'm merely saying that compared with the Fords; the X-REAS, AWD 4Runner is the most stable, well-mannered, maneuverable, safe, and above all, FORGIVING sport utility vehicle I've had the pleasure of driving (and I've put over 19,000 miles on mine so far).
Quoting Toyota's literature: "X-REAS links each of the vehicle's shocks to their diagonal counterpart via a gas/hydraulic chamber-- front-left to rear-right, and front-right to rear-left. During cornering or traveling on a bumpy surface, the gas/hydraulic chamber acts like a bank, 'borrowing' fluid from the cross-linked shock bearing the least amount of force, and 'loaning' it to the shock sustaining the greatest amount of force. This helps the 4Runner's wheels maintain contact with the driving surface and helps lessen vehicle body roll and pitch..."
Let's suppose you're heading into a rightward highway curve just a little too fast or "hot" in a top-heavy, lesser SUV that lacks X-REAS (such as the new Explorers). As you enter the curve, the lesser vehicle will begin to teeter to the left, and you will feel the vehicle's top-heavy body beginning to roll to the left. You will also feel it starting to understeer and wanting to travel to the left, possibly running off the road unless the appropriate corrective actions are taken. At this point, an inexperienced SUV driver may try to OVERSTEER the vehicle back to the RIGHT (back into the curve), and this may very well cause the vehicle to completely roll over. (In my experience, the most appropriate corrective action in this situation would be to first begin gently but assertively applying smooth and steady braking in order to slow the vehicle fairly quickly, thus quickly bleeding off the offending angular momentum The more the vehicle is slowed down, the more it will permit and tolerate being steered back to the right.)
As the above rollover scenario unfolds in your mind, note that as the lesser SUV begins to teeter and roll to the left, the shocks on the same side of the vehicle are becoming evermore compressed and overloaded with stress and weight. Meanwhile, the shocks on the right-side of the vehicle are becoming ever more extended and unloaded as the right side of the vehicle begins to lift up in the course of the vehicle's leftward teeter and roll. In this situation, as the right-side shocks decompress and extend themselves, they may tend to further TIP the vehicle's precarious attitude towards a leftward rollover.
Next, consider this same scenario with the X-REAS *safety* technology in place. Here, the left-side X-REAS shocks would progressively stiffen as the X-REAS system dynamically strives to correct these force imbalences by diagonally cross-transferring hydraulic/gas pressure into the left-side shocks, thus directly COUNTERING the leftward rollover forces and angular momentum. At the same time, X-REAS is temporarily transferring hydraulic/gas pressure AWAY from the right-side shocks, thus reducing their tendency to "bounce" the vehicle back towards the leftward tipping if/when the vehicle's body should roll back to the right in the course of corrective actions on the part of the driver.
In my opinion, X-REAS works as claimed, and then some. Indeed, I do a great deal of freeway driving, and I've had several close calls in my 4Runner, in which someone abruptly pulled out closely in front of me, right in my path. At these times, I've instinctively taken emergency evasive actions, and thankfully I've not been involved in any accidents, thanks in large measure to the truly remarkable stability of my X-REAS, AWD 4Runner. Indeed, this magnificent vehicle often feels like it's Michelin Cross Terrains are "glued" to the road, and I've simply never driven another SUV with this degree of performance.
That said, when we're suddenly faced with this type of split-second hazard, I don't care how good a driver you are-- your first instinct will likely be to (1) abruptly jerk the wheel in an effort to steer out of the impending collision, and (2) aggressively apply the brakes. (In fact, if we can train ourselves to do so, I believe that within the world of "microseconds", the very first countermeasure should be assertive BRAKING, followed a "microsecond" later by reasonable attempts at evasive steering maneuvers.) At any rate, any time you jerk the wheel of an SUV in an effort to avoid calamity, you risk rolling the vehicle and possibly killing yourself and others. But as I've opined above, it is my humble opinion that the X-REAS equipped, AWD 4Runner is the most FORGIVING, SAFE, NIMBLE, MANEUVERABLE, SUREFOOTED and ROADWORTHY truck I've ever had the pleasure of driving.
X-REAS is our good friend. While its many virtues may not often be so "obvious" in the course of more mundane day-to-day driving... those same virtues, especially the enormous SAFETY value of X-REAS, should become quite evident if you ever need to call upon it. In my opinion, those who would claim that X-REAS is hype, don't yet really know what they're talking about. If your 4Runner has X-REAS and you're not yet "impressed" by it, perhaps you have yet to encounter (or to fully recognize and appreciate) the many moment-to-moment situations where X-REAS is actually at work, unobtrusively and adeptly assisting you, the driver.
I rest my case.
- Mark
A few months ago, MSNBC did a special about SUVs and their propensity to roll over. Their was a test (performed by NHTSA, I believe) that showed both a 4Runner with and without X-REAS. The S-REAS equipped 4Runner performed much better at the slalom and in the emergency lane change maneuver.
There was also a video link showing the X-REAS in action on the MSNBC site, but unfortunately, the article and video are no longer available.
The X-REAS is not just for show. There is a clear demonstable advantage in having it.
I whole heartily disagree with you on that statement, it is part of of the total handling makeup. You get some tires with weak sidewalls, and/or improperly inflated and you will definitely experience more body roll in just about any vehicle. Not to mention cornering and just about any kind of road handling manners can be improved with better threads on the ground.
I do like and believe in the X-REAS setup, and plan to get it on my 4R.
Also, I think the biggest roll danger isn't from the first quick or hard turn you make. It's from the compensating turn you make the other way after you've avoided what you were trying to avoid (or the turn you make to straighten out after you've turned too far). The problem is is the momentum in the body roll as it's trying to roll back upright after being disturbed by the first hard turn. During the second turn it adds to the tendency of the vehicle to roll. VSC and X-Reas, I think, tend to prevent this, though they do it in different ways. VSC probably helps control turning, while X-Reas lessens body roll.
If you want to understand this better, just imagine accidently drifting off of the right side of the pavement due to falling asleep, inattention, etc. When the wheels get off the pavement you jerk the wheel hard/fast back to the left to get back on the road. Then you find you've over-corrected and may be in danger of veering into the oncoming lane or going off the other edge of the road. You yank the wheel hard/fast back to the right. Imagine the side forces and body roll sequence in this case and you'll see what I mean.
Regarding the role that tires play in this debate, I would mention that my 2002 Explorer was also equipped with Michelin Cross Terrains (my favorite tires). Also, I would think that the past issues with certain Firestone SUV tires would seem to suggest that tires which are over-inflated, oversized, or prone to catastrophic failure, are likely to be important contributing factors in some rollover accidents.
Corancher raises some interesting points regarding the likely succession of steering countermeasures, along with their possible consequences. To this I would say that in my previously posted scenario, I actually addressed this to a limited extent when I wrote: "At the same time, X-REAS is temporarily transferring hydraulic/gas pressure AWAY from the right-side shocks, thus reducing their tendency to "bounce" the vehicle back towards the leftward tipping if/when the vehicle's body should roll back to the right in the course of corrective actions on the part of the driver...."
I believe a key point here would be that evasive steering maneuvers (or other sudden perturbations) in an SUV may be likely to send the vehicle into an "OSCILLATING" pattern of unwanted motion, including various combinations of roll and counter-roll (rotation about an axis); pitch (up-down); and yaw (side to side). Once these oscillating movements are set in motion, the vehicle is, of course, in an unstable and precarious attitude.
Aside from certain driving countermeasures (which may be unreliable), I believe that X-REAS and the new 4Runner's other on-board safety systems (e.g., VSC and TC) greatly increase the chances for a safe and successful recovery. Systems such as X-REAS (and VSC/TC) serve to not only DAMPEN and quell these unstable oscillations and assist in bringing the vehicle back to a safer attitude; they likely also help to buffer, "TRIM", and COMPENSATE for many over-exuberant (or ill advised) inputs from the driver. In addition, I'm inclined to believe that 4Runners additionally equipped with AWD may be even more capable of a safe recovery, even on dry pavement.
In my opinion, herein rests the true ingenuity and technological prowess of the new 4Runners, especially when more fully equipped. Its advanced on-board safety systems are in some ways analogous to those in the world's safest aircraft. Indeed, among SUVs, the new 4Runners (and Lexus siblings) are without peers.
V-8 with VTEC.
As an overall package, tires do indeed have some factor with handling, but compared to VSC, proper wheel alignment, X-REAS, and suspension, tires perform a smaller role.
I think that VSC involves braking, which improves handling while the X-REAS prevents body roll (also previously mentioned ) I would imagine that there is no indicator for the X-REAS system since I would imagine that it works very frequently to some extent. The only time that I was able to get the VSC light to illuminate was when forcing a hard turn on a slick road. VSC truly is a great feature now made standard on all 4Runners.
Happy 4th
An alarm does sound in the cabin when the VSC system finds that it's not able to get the vehicle substantially in the direction you're intending to go. Otherwise when it's working you just get the flashing yello dash indicator.
The idea of steering and/or body oscillations is just the kind of thing I was talking about. VSC helps with part of the problem, reducing understeer and oversteer, but X-Reas should help with more, preventing and damping the oscillations.
VSC does indeed involve braking and perhaps dethrottling. Sometimes it's hard to separate the effects of traction control and VSC, as I found after a snowstorm around the turn of the year. I posted my experiences and insights here then, so I won't repeat those now.
Good discussion!
( gold ) in a limited with Nav.I spoiled myself. And bought it. Cars direct was great. None of this start at msrp + and then fight with sales manager to get the price down. Cars direct price was very close to invoice. It was quick and painless.
Well now I'm in love with this machine. The V/8 5spd auto is very smooth. The 10 speaker sounds just fine to me I wanted a V/6 at first ,but decided that a v/8 might be better for pulling a boat.Did not get X-REAS .Seems to drive just fine.I'm in the auto business ,been around boats , cars , trucks ,motorcycles for years,I can't remember the last time some told me there machine had to much power so they were trading for something thats more under powered.
Lol.
For what it's worth, I'll mention a few products that I've found to be worthwhile: (1) Chevron Techron concentrate-- every ~2500-3000 miles, try adding a 20 oz. bottle of this fuel system cleaner to a tank of fuel. Highly recommended; (2) Quaker State Full Synthetic 5W30 motor oil. I change my oil every 5000 miles, and therefore I don't feel a more expensive synthetic oil such as Amsoil is necessary; (3) ZAINO exterior and interior finish products http://www.zainostore.com/Merchant2/merchant.mvc (4) Husky floorliners and cargo bed liner (highly recommended); (5) ScotchGard for protecting carpet and cloth headliner against stains; (6) Michelin Cross Terrains. A matter of preference. You may already have these on your truck. My 4Runner came equipped with Bridgestones, and my dealer was happy to replace them with Cross Terrains at no additional cost.
Alfa, enjoy your new 4Runner!
My Explorer Sport has an engine problem, including a knock.
Any suggestions I would appreciate.
Cheers
Pat
Today's better synthetic oils are not the same as friction-lowering oil ADDITIVES such as Slick 50, which should be avoided.
of Knoxville, Tennessee. I'm afraid it may be to late to order a 2004. However, I guess I will find that out in the next week
if I can't find what I want on a lot or through a dealer search.
I currently tow a Coleman popup trlr., loaded it weighs 3000lbs. No problem whatsoever. The Mountains begin at 5600 ft elevation and go up from there, this can be a challenge for many rigs.
Later this year, I plan on purchasing a 23-25' travel trailer. Longer, more mass, more height. Naturally, the RV dealer thinks this should be no problem.
Anyone have any experiences, good or bad? Please advise, THANKS....
Cheers
Pat
I think both the V6 and V8 will get you where you want to go, and do it well, but you might check out the Consumer Reports reviews on them too help in your decision as well.
Dave
If you're not frequently towing heavy loads (i.e. 5000+ lbs.) I would get the V6. You will get more horsepower (245 vs. 235 in V8), better gas mileage, 125 lbs less engine weight, $1300 cheaper, and the ability to ride around in 2WD with full time 4WD capability when needed.
On the other side of the coin, the V8 is an older bullet proof engine, with more torque (320 lb-ft vs. 283 lb-ft. in V6), with a new 5 speed automatic, that can tow 7000 lbs. In any event I'd wait for the 2005 models to see what (if) improvements they've made in both the V6 (5 speed tranny) and V8 (VVT-i).
I used to fund some locksmiths. They showed me a few tricks.
I have my own piece of piano wire.
Looking two buy a new 2004, or 2005 4Runner. I'm hoping you folks will lend a hand with a couple of questions, and add any tips that you may have concerning the purchase.
First, my intent is to purchase the V6 4WD SR5 or Sport model. The V6 should save me 3 or 4 miles per gallon over my current F150 4WD pickup. However, it seems that there is some question to the grade of gasoline that can be used. The salesman I've talked to assures me that it will run fine on regular unleaded (87 octane). From what I've read in these forums, many people are running 89, or 91 octane.
So, my questions........ will the 4Runner run fine on 87 octane? Are most of you using regular gas?
Next, I guess some other things I should check, or be aware of are the following:
Sulfur smell - Is this generally noticeable at first, or does it develop over time?
V6 engine making a whirling sound - noticeable with windows up?
Leak around the crankshaft pully.
Fuel delivery problem - sound like this one is taken care of?
Rocking seats?
Anyhow, does that pretty much sum it up? Anything else of major concern? Anything else to listen for/look for? Any other tips?
Obviously, I'm sure Toyota is taking/taken care of some of those issues in their current production........ still, any tips/pointers would be great.
Thanks in advance.
