Fixing Your Blazer's Squeaks and Rattles
jlflemmons
Member Posts: 2,242
Okay, troops. If you own a Blazer or Jimmy, two door or four door, and you still have your hearing, you have to listen to squeaks and rattles from the interior and exterior.
So? What ingenious fixes have you come up with? I will open the floor with:
Those nasty little creaks coming from the interior side panels on the 2door. Pulled the panel off (carefully, not only are these things rather delicate, they cost a small fortune) and noted where the plastic had rubbed. Pretty obvious as it leaves a tell-tale powdery substance.
Put a small film of dielectric silicon grease where ever I saw the rubbing, also where the metal clips snap into the body, and removed almost all the weird little noises. Almost. After all, we are talking Blazers here.
Other thoughts?
Other thoughts?
