Volvo XC90 T6 Transmission
1242526272830»
  • kcv70kcv70 Posts: 1
    There was a class action lawsuit in which Volvo agreed to in 2012. I'm not sure what happens to those wth issues after the 2012 filing deadline. It might be worth contacting the attorneys...
    http://www.chimicles.com/volvo-xc90-transmission-class-action-litigation
  • My local dealership replaced my original transmission at no charge to me at 103,000 miles, now at 170,000 that transmission needs to be replaced. Do you think they replaced it with the same bad transmission? I am trying to get them to warranty this transmission also. I purchased a Volvo because my mechanic told me that these cars should last till 300,000 miles. Now I am looking at replacing this car at half of it's lifetime. I am very disappointed.
  • I had a 2003 XC90 T6 and it went through 3 transmission between 103k and 115K miles. The second one was purchased by me since Volvo refused to cover anything (the car had 100K miles warranty). The warranty for this transmission was 12 months, unlimited miles. The third one was warrantied by Volvo since I told them that I will join a class action lawsuit - still the same 12 months, unlimited miles. When I asked why the warranty is limited to 12 months I was told that this is the industry standard (I do not know if this is true or not). I guess you will have a hard time getting more warranty from them.
    As far as the type of transmission goes I was told by Volvo that the replacement transmissions are "rebuild" ones, meaning same old transmission, with a few new parts.
    I got rid of my Volvo XC 90 after realizing that in order to keep it running I would need to put $5 or so at 125K miles. It needed new rear end shocks (self leveling, very expensive, $450 per shock), $1200 for oil leak fix, all wheel drive gone and a bunch of other smaller issues.
  • I was going on my third transmission when I finally sold my Volvo----they probably put in a fresh new one at 103,000 miles---but it doesn't matter----the way the car was configured it destroys transmissions in that model year. Volvo should have recalled all of them or offered up free transmissions for life as it was their error---but they didn't.
  • kdvt26kdvt26 Posts: 3
    I had 2006 V8 XC90 and had to have the transmission replaced at 60,000. I called Volvo USA and they gave me $1500 towards the price of the new transmission (total was $7000) and had the dealer replace it. About 9 months later I was told the steering was failing and it was another $800 to fix. That was the last straw, we cut our huge losses with that car (that I loved until it had all these problems) and got a 2014 GMC Acadia - which is a dream and no issues at all, finally! These Volvos are no good, once something starts to fail plan for more to come. I called Volvo USA several times complaining that they need a recall on the 2006 V8 models but they won't take any action. (The other recalls I believe were for earlier years and not the V8 model). You are better off cutting your losses if you can and get something else. These SUVs are money pits and garbage.
  • Well, I never thought that I would have been SO disappointed at owning a Volvo! But right now I have only to say research, research, research! After having owned two older models of Volvos in the past (both of which were close to 200,000 miles before we retired them) we decided to become Volvo owners again. Found a beautiful well maintained 2006 XC90 V8 two years ago and decided it would be our step back into being proud Volvo owners again. (If I like this one, I would go by a new one) Out of the blue at approximately 70000 miles I started experiencing a "shudder" between 2-3 gears. I took my car to my mechanic for a scheduled maintenance and after several visits it was finally diagnosed as a transmission issue. Part of the problem being a cross contamination issue. With this information in hand, I went the dealer to obtain a second opinion and, yes, they agree I need a new transmission. AND yes the cost would be approximately $7500.00....same price I received from my mechanic. One nice thing, the dealer agreed to contact Volvo of NA to request assistance with the cost....knowing it was a design issue and not a maintenance issue. NO! Volvo would not even consider an assistance.....this was after 2 weeks of waiting. Talked with their customer affairs office and was told that since I couldn't provide adequate service records that there was nothing Volvo could do. Now I am perplexed and extremely disappointed. Will I buy another Volvo.....hell no! If someone isn't willing to admit that they have an issue and aren't willing to provide assistance with that issue then forget it! Volvo knows that the transmission issue goes beyond the T6 models and have failed the consumer.
  • abdknsnabdknsn Posts: 1
    edited November 2013
    The 99-05 Volvo S80 and 2003-2005 XC90 models use the GM 4T65E transmission. They are prone to failure. The early versions (pre-2003) used a 4th clutch hub that didn't have hardened splines on the input side. They are quite common to strip out. The result is no 4th gear and whining from the debris going through the pump. The 2nd clutch drum is also prone to failure on all units. The forward band is also prone to wear and breakage causing a slipping when going forward (when worn) to no forward movement at all (when broken). I've found that certain reputable rebuilders like Certified Transmission are the way to go for replacement. The O.E. replacement from Volvo (read GM) are built to early specs and don't last any longer than the first unit. The rebuilds from companies like Certified actually modify the build specs to tighter tolerances resulting in a longer lasting unit. Unfortunately, Volvo believed that the 4T65E was necessary because the tried and true Asian Warner 50-42 that was used for years wouldn't be able to withstand the power and curb weight of the full size Volvos. They phased out the 4T65E beginning in 2006...
  • Hi, How do you know all this? Is there anywhere you can point me to where this information is documented?
    I am not doubting you for a moment - clearly you know what you are talking about but I am in the UK and when our vehicle died we referred the matter to VOSA - the government department that investigates vehicle issues. They have the power to instruct Volvo to recall a defect and rectify it. The official response from Volvo was that they had no knowledge of any issues with the XC90 transmission at all, ours was an isolated incident and they would not inspect the vehicle and so could not comment on specific cases. VOSA accepted their response and the matter was closed.
  • If you go deep in this site to the myriad of letters, you will see the same problem confirmed over and over and over again---and in some cases Volvo offered help to the dealers and in others they denied it. Yes, the vehicle absolutely should have been recalled---those early years of the XC90 the cars transmissions were "lemons." Disaster. And why the car wasn't recalled officially is a miracle to me---along with why Volvo did not get more bad publicity from what they did. This problem seemed to be an exception to their normal high quality--(I have an XC 60 now that is great).
  • I just bought a 2006 Volvo xc90 for $14999. Has 62,167 miles on it. I have driven it 650 miles and just found out it needs a new transmission. $7,500!!!! I haven't even made my first car payment! My 30 day or 1,000 mile warranty ran out 7 days before I was able to take it to a certified mechanic. I am trying to work things out with dealer. Volvo of America says they can't help. I am trying to figure out if I should try and rebuild it or replace it. I don't want to spend another $7,500 when my car gets to 125,000 miles. Is this car worth holding onto?
  • Did the 2006 cars have the same transmission? If they did----and I'm not sure if it was fixed by then with a different transmission----then sorry---get rid of it. I already had TWO new transmissions by that point and knew that there would soon be a third transmission coming up. As you can see from hundreds of postings here---this car should have been recalled a long time ago or only been sold with a huge caveat. I loved my XC90 and I had intended to keep it for a long time---but defensively knew I had to dump it before my final extended warranty was about to expire lest I pay for a third transmission--. Good luck.
  • Looking at buying a used XC90. I have been told this problem is mostly with the XC90 T6 and V8 models but not the I5. Should I stay away from all XC90s, just pre-2006 models or just the pre-2006 T6 and V8? Any advice would be appreciated.
  • I think most of the issues occurred with the 2006 and earlier models (mine was the 2006 V8 model, only 60,000 miles with all service requirements completed on time and on schedule ). But I, and it sounds like most people posting on this forum, were treated so poorly by what we thought was a reputable car company that I will NEVER own another Volvo again. They have proven they do not care about their customers, leaving us to take on a costly burden that was due to their negligence. Learn from this and DO NOT BUY A VOLVO, no matter the model, because they do not care about their customers, or doing the right thing.
  • This is just my opinion. Its informed - based only my my own experiences. Others may have different opinions.
    You ask which models to avoid. My opinion is that you should stay away from Volvo full stop.
    The issue isn't that their cars don't last or that their gearboxes fail after about 50,000 miles or even that a new gar box costs more than the value of the car - all cars wear out and some are better than Volvo and some are worse. The issue for me is that they are putting their profit ahead of customer safety and appear to be doing so in plain sight. Its the opposite of what I thought I was buying when I spent £50,000 on my XC90.
    In the US there is a class action suit for this issue. There are customers from the UK, Australia, South Africa and Canada also experiencing the same problems but although its the same vehicle and the same gearbox and the same fault they will not admit that its the same problem even when Volvo drivers are at risk and could cause risk to others.
    In my mind that is simply not good enough. Volvo in Sweden would not even discuss the matter. I bought my Volvo because I thought it was safe and I have a young family. When I approached them after the gearbox fault left us stranded in the path of oncoming traffic Volvo told me that this was the first time they had ever heard of the fault. I called them because the patrol guy had correctly guessed the exact defect in the most minute detail from the side of the road based only on the make and model of the car and its mileage.
    Then when the accident inspection service in the UK asked Volvo to comment Volvo said they had "no knowledge" and the matter is on hold pending further 'incidents'. Someone else has to suffer or get injured or die before the defect is looked into further. Then it transpired that at the very same time they said they had no knowledge, Volvo were in court in the US over the exact same issue.
    This is not about trying to find a decent model Volvo from those available, its about how safe you and your family are in a Volvo. Volvo have chosen not do something about a gearbox defect that can suddenly and completely incapacitate your car as you are driving along even though there is a risk to you, your family and other road users when you come to an unexpected stop. They knew of the defect while the vehicles were under warranty and did actually extend the warranty because of it, but did not warn drivers and did not recall the cars. Instead they have chosen to profit from the repairs to the original gearboxes and the replacements which also fail.
    In my case the "gestures of goodwill" after the event were not enough. Its my opinion that Volvo should have told me or my dealer that they were aware of a problem - before the catastrophe struck. They should have addressed it before the accident and before anyone else was put at risk, but they didn't. Ours came to an abrupt stop at around 56000 miles - just a few hundred miles after a main dealer 96000 mile service. The incident was avoidable and its unforgivable when they knew already that the fault was there.
    The closest they ever came to giving a warning was instructing the dealers to carry out extra work during the service if the vehicle is used for towing caravans, although we have never been asked what we tow with the vehicle.
    It appears that Volvo were already dealing with hundreds of other drivers who had hit the critical mileage and experienced the defect well before we did yet they took no action at all to prevent the same happening to us.
    These and many other forums are full of Volvo customers and victims that have unwittingly bought Volvos only to find themselves stranded, injured or facing repair bills well in excess of the value of the vehicle often very soon after buying the car and its not fair or decent.
    The bottom line? A new gearbox costs around £4000 - £5000 (retail price) and to Volvo that money was more important to them than the safety of my family.
    NEVER AGAIN.
    As I said, thats just my experience and just my opinion.
  • We ordered our 2004 XC90 new from the Massachusetts dealer in late 2003 and had the dealer do all of the service for the first 90000 miles. Since then we've been using a very trustworthy independent Volvo mechanic. Volvo's are not cheap to keep … having owned at least 1 for the last 31 years … and the XC90 is no exception. However, the day that we feared would come arrived three days ago when our transmission died. I suppose that I should feel fortunate that we got 170,000 miles out of the original transmission given the experience of many other owners who are on their 3rd or 4th transmission with fewer miles. Our dealer has offered to replace the dead unit with a new transmission to the tune of $7500 … less a 10% discount on parts and labor. They'll also give us a 2 year warranty. My wife loves this car we are considering the new transmission in the hope that we can get another 50000 miles out of it. But I am having 2nd thoughts about this given all of the negative experience that's been shared on this site. I think I've read every post and I don't recall one single post saying "we replaced the transmission and everything was fine after that".
  • jbs05jbs05 Posts: 13
    I received a goodwill notice from Volvo the day before Christmas that they are launching a service campaign. They are upgrading, for free, the TCM software installed on our xc90. I already had it completed. Back history... We only have 80k miles on it currently and the original transmission did not go out but started to slip at 32k. Volvo replaced that one free and have not had any problems since.
  • @jacostello said:
    After reading all the posts about Transmissions, I decided to give my story as well, most of it similar to many of your stories, except that I didn’t take it to the dealer, I actually had it rebuilt. I bought the 2004 XC90 T6 used with about 48,000 miles on it, drove like a dream until 62,500 when the infamous "TRANSMISSION SERVICE URGENT" came on, we took it our local Volvo specialist (not the dealer), and they flushed the tranny and reset the light and updated the computer, they didn't find any metal shavings or off color fluid, it took about a week for light to come back when the shop referred me to a local transmission shop (Bradshaw's Transmission/Portland, OR)
    We had an aftermarket warranty who wouldn’t even review the claim until the transmission was out and broken apart to assess the situation. After the report, the warranty company declined to pay for anything, and it was $1,300.00 to take out the tranny and break it down, since I was already that much in, I decided to keep it there and not take it to the dealership, which quoted me $5,500.00. Since many of you took it to the dealership, I assume you never got to actually know what went wrong with the transmission, I got to find out every detail since they took it apart. I am in no way a mechanic, my experience ends outside my 1974 VW Super Beetle, so I’m taking a lot of this straight from the report and bill for the rebuild and from my conversations with the gentlemen who rebuilt it. So they found the “transmission fluid smelled burnt and was slipping under load, the second gear clutch pack was burnt and the second gear apply piston and the drum was damaged causing metal particles to contaminate the entire transmission and shift solenoids.” That came straight from the report. They were able to provide me with copies of their ATRA (Automatic Transmission Rebuilders Association) manual from the 2005 and 2006 year. The 2005 manual stated that the 2nd and 4th clutches are prone to burning and to inspect them when in for service. The 2006 Manual identified the problem as being improper machining of the accumulator housing, the chamfer angle was changed from 15 degrees to 10 and the depth was shorted from 2.7mm to 1.8mm.
    So they rebuilt it with the new specifications, and at first the light would come back on every 6 weeks or so, after taking it in a few times, they eventually found out that their computer wasn’t updating the new specs to the transmission and it was still programmed for the old worn transmission, once that got updated properly, it’s been handling like a dream ever since, it actually drives smoother.
    I can’t say with any certainty that this is what happened to everyone else's transmission, but it sure seems likely. I wonder if Volvo is just replacing the transmissions and discarding the old ones so no one investigates the root problem, this is only speculation. I have filed a complaint with the NHTSA, and I’m writing a letter to Volvo demanding payment for my transmission, which by the way was $4,512.00 in the end, that’s not including the $500.00 tranny flush I did a week prior to having it rebuilt. I’m also advising them that if I don’t receive at least a reply within 30 days that I’ll be filing a complaint with my state’s Attorney General, I’ve filed with them before with an other company on another issue and the issue was resolved pretty quickly, apparently companies don’t like to be flagged by any AG, so I urge you all to complain to your state AG, the more they get, the more likely they are to give in to us!
    I’m more then happy to provide anyone with PDF scans of the manual pages and even my bill with all the mechanic notes (my name and personal info redacted) if you’d like them to file complaints.
    So am I crazy for not letting Volvo replace it instead in the first place?
  • Hi, just read your post after bying my CX90 T6 - could you provide me with PDF scans of the manual pages and even my bill with all the mechanic notes. I do not have the same problem with the car yet but would like to be prepared :)
  • i have a 2004 xc90 t6 volvo and it has 120537 miles on it. My husband and I came back from a 6 hour trip and got to a stop sign and tried to go but nothing happened till he put it in manual and had to put it into 2nd gear before it would even move. We have only had the car since 4/21/13 and on May 22 of 2014 it did this. It tossed out 3 codes but have no clue what to do pick and pull dnt carry volvo xc90s. One of the codes says it might be my control module which is the brain but can't get it. Where do i go to find a cheap reliable part. i dnt have a warranty on it for we got it from a place called choice auto. We had no warning it just was there with no warning and no symptoms at all please help. Im not hard on it i am also a mother and take kids to school and shopping I dnt even work lol.
  • kmart5 i take my car to a place in Sacramento called superior automotive and they are good i like them my father in law chose them and referred me.
  • Everyone needs to go to the NHTSA and file the problem for transmissions. The service manager told me the other day that the only way there could be a recall is if the NHTSA were to go to Volvo. And only if it is considered a safety issue will Volvo conduct a recall. www.safercar.gov
    Volvo Cars of North America, LLC -President/CEO Mr. Speck
    PO Box 914
    Rockleigh, N.J. 07647
    A better day. Tech new online, Cộng đồng internet việt nam lớn nhất.
  • nycjswnycjsw Posts: 15
    We had a 2004 XC 90 T6 loaded that we dumped at a high loss.  We got rid of ours a few months after having a timing belt coming off and rubbing a plastic cover way before the recommending replacement time. It also just has a $1,500 brake job where to rotors had to be replaced. It was only about 5 years sold and had 68k miles.  The transmission was starting to shift hard and had me worried.  I will never buy another Volvo again.
    We went looking at getting a new VW TDI station wagon. We started talking trade in - the VW dealer called the Volvo dealers saying something they will swap used cars.  The dealerships were not related in any way.  I overhear the conversation and the Volvo is throwing my car under the bus point out how they don't want it and how problematics the transmission is - I was offered only $8,000 for a loaded vehicle (even had that double unbreakable glass etc) that was in mint condition.  I went to Carmax and sold it for $9k. I sold this thing back in 2009 and it still annoys me and I should be included in any lawsuit.  The car had a beautiful interior but without a transmission it's not much use.  Another thing the Volvo dealership did that was annoying was they refused to reset the oil change computer with oil changes - wth? They wanted a seperate $50 fee.  Bottom line was they tried to be a premium brand but failed in so many ways and their dealerships weren't held to the standards or given the support that other premium dealerships have.
Volvo XC90 T6 Transmission - Page 30 - Car Forums at Edmunds.com
