Jeep Grand Cherokee Radio Problems
kbr1350kbr1350 Member Posts: 1
edited August 2015 in Jeep
Turned on the jeep this morning, radio will not play. cant scroll through stations or toggle AM/FM so i know its more than just an issue with speakers. cd will not play. The CD player will take and eject a cd but will not play it. it will not switch tracks. the clock is on and working fine. Very weird... I have been through the obivous... knob is in the on position, fuses are all good.... Any ideas?
See also: Jeep Grand Cherokee Radio Removal and Installation (Video, 15:05)
«1
    saysay1414saysay1414 Member Posts: 1
    The SAME exact thing happened to my radio!!!! I thought it as the fuses, so I bought new fuses, nothing was fixed. I pushed every button, still nothing. The clock orks still and some of the buttons are lit up. PLEASE let me know if you get yours fixed and how and what you did!!! :sick:
    grandpopdgrandpopd Member Posts: 4
    I just purchased a 2008 Grand Cherokee 2 weeks ago. On day 3, I stopped for gas and the radio w/ NAV stopped working. There was no sound from AM, FM, SAT, CD, or NAV. Yet I could apparently change stations. Several hours later, after the car sat for awhile, it worked again. I had the dealer check it and they found a TB for it. But several days later, the same thing happened. Believe it or not, it was just after I filled the tank again. Once the car sat for a while, the radio worked again. REALLY WEIRD! I haven't contacted the dealer again just yet.
    naatz1naatz1 Member Posts: 188
    I posted this on the gen'l JGC problems & maintenance forum but thought other owners might find it here first on this new radio oriented forum. From Feb 17:
    I have a newer 07 GC Laredo with X package and am wondering if any out there have figured out how to keep the radio in AUX mode.
    The audio system is a base single CD w/Bostons Acoustics amp adder. This REF model radio has AM/FM stereo, single-disc CD player w/bass, treble, balance, and fade control through on-screen menu -AND- front mount auxiliary audio input jack. I did not want Sirius since I have had XM for many years and own the Delphi portable XM that I dash mounted. In our 01 & 04 cars we used a cassette deck adapter to direct feed audio from the XM unit and the car audio always stays in cassette play when you turn it off/on. However this Jeep radio goes back to FM radio mode upon restarting the Jeep when you turn off the Jeep with the radio in AUX mode (the XM unit powers off/on automatically when is senses a loss of 12VDC power, 4 years old and perhaps "smarter" then the newer Jeep radio?).
    Anyone with a 07 or 08 model feeding the AUX with XM or even a MP3 player ie ipod figure out how to keep this Jeep radio in AUX mode?
    From Mar 14 07: I will answer my own question with what our dealer got from Jeep engineering: you must turn the radio OFF before turing off the ignition and then the radio stays in AUX mode when you start the car. But of course you have to turn the radio back on again as well.
    One of the crazier answers I have ever heard. The radio does not require that operation to stay in AM,FM or CD mode as you can switch off the car with the radio on and it goes back to the mode you left it in. Seems to me a true design bug! I don't think it's worth fighting, but one of my first (minor) disappointments with this new vehicle.
    flammableflammable Member Posts: 1
    similar problem wev got, started off as an on and off problem but now dosnt work at all, thers like a squeeling constant static coming thru the speakers and if your able to get any proper sound its muffled, thought it might of been the speakers so we swaped them for new ones and the problems still there, its not just the radio it happens when a tape is in aswell, we tried putting a speaker directly to the radio and it worked perfectly but when its hooked up "properly" it dosnt, its really starting to get annoying now.
    scott108scott108 Member Posts: 1
    i am not sure if i found the answer but here goes the question.
    the radio still lights up and i can change the channels, enter a cd etc but there is no sound. replaced the fuse but to no avail. any suggestions?? if 1 speaker is bad or the wire is disconnected will it effect all of the speakers.
    After several repair visits, the dealer douwnloaded an update to the Nav system, whic was supposed to cure the periodic no-sound problem. But the update has changed the icons on the Nav system, but now it doesn't match the instruction in the manual. While I think the update added so features to the Nav system, which I like, it would be nice to have the addendum to the manual or a new manual. The Service Manager at the dealership has the same problem.
    allengoallengo Member Posts: 1
    My '08 GC has had the REN stereo (MyGig without nav) replaced twice and still has the same problems. As I switch from mode to mode (satellite to hard drive to bluetooth, etc.) the volume controls become unresponsive. The volume levels go up and down, but the sound remains the same. I have to turn the volume down to zero, wait a few seconds, and then I can control it. Anyone else have these problems?
    moorefieldmoorefield Member Posts: 1
    Does anyone know if there is a code to get my 6 disk cd player to work on my 99 Jeep Grand Cherokee Laredo? It stopped working after my battery was replaced. The radio still works, it's just that the cd player option is not there anymore.
    Don't recall seeing anyone post about that problem before; it's always the radio code that's needed.
    You could try finding and pulling the fuse for the CD player and see it that resets it.
    lauterbachlauterbach Member Posts: 2
    sound like your problem did you find a cure?
    i have the same problem did find a cure, i thought my radio was bad so i replaced it ,and i still have that squeeling sound
    Hey! I think that the dealer has finally been able to solve my problem. After several service visits, and two new uploads, the Nav works and I have been able to use it. The only remaining problem is that I believe that there is an addendum to the instruction manual because the icons are different, but no one can get it for me. I have contact Navtec and Jeep, who just send me back to the dealer. The dealer has been very helpful, but still not able to get me the instructions.
    spotz9spotz9 Member Posts: 3
    I just bought a used '08 GC and I have the same stereo. Mine did the same thing as you describe... volume display changes but the sound stays the same. I turned the stereo power off and then back on, and everything was fine. It hasn't repeated since.
    I saw a couple of people post about a squealing sound coming from their MyGig Stereo unit. I just bought a used GC and mine is doing the same thing I think. Flammable described it as "a squeeling constant static coming thru the speakers". That's exactly what I'm hearing. It does it when the vehicle is driving or is parked. It does it at random times, and lasts for a random amount of time.
    Last night I was sitting in my garage and it started doing it. Engine was stopped, no key in ignition. Had been parked for an hour after driving home. Only the interior lights were on while I was digging through my glove box. I was able to climb around to try and find the source of the sound, and it sounds like it's coming from *inside* the MyGig unit itself. There was no CD in the unit.
    Has anyone discovered the source of this sound? Do I need a new MyGig unit? :confuse:
    Took it to the dealership to have it looked at, and they just ordered me a new MyGig unit. If I get an explanation as to what was wrong I'll post it. :confuse:
    mangiam1mangiam1 Member Posts: 1
    I bought this radio on ebay, thingking that it would have fitted on my Grand cherokee 2008 Laredo.
    today I spent 2hours and 150$ to the jeep dealers here, and they said I can't mount this radio on the car.
    I've read somewhere else on the web, and the person who sold me the radio told the same, that I can mount this radio.
    Is there anyone who can help me?
    Thanks a lot.
    dianne3dianne3 Member Posts: 1
    New 2008 Grand Cherokee with 3000 miles. Radio problem. Dealership cannot solve. When I turn the jeep on sometimes there is no sound out of the radio/GPS/UConnect. I turn off and back on and it is fixed. Was told it has all the software upgrades so they took out the radio and installed another radio. This one does the same thing. Anyone have this problem? I was told there was an error code UO184 in first radio. No error code on the second radio. They made me drive to the dealership while it wasn't working and still no error code.
    cheoy_lee1cheoy_lee1 Member Posts: 1
    Radio with NAVI....shuts off for no reason....sound bounces back between speakers....NAVI acts erratically.....dealer says bring it back when the problem shows...any ideas?
    splotkinsplotkin Member Posts: 2
    My 07 GC radio did the same thing and eventually died completely. The fix was a new amplifier ($185.00) from the dealer. I had a car radio guy install it for $30.00 but can be done easily if you can figure out how to get to the location which is buried on the drivers side rear panel next to the rear hatch. The radio guy said that Jeep used to put the amplifier under the rear seat and in it's current location near the rear hatch, moisture gets to it. Jeep doesn't have a program or recall so you are out of luck. There is nothing wrong with the radio. The amplifier is digital and made by Damler Chrysler (same as Mercedes) and can't be diagnosed with a standard meter. Bite the bullet and just replace the amp or install an after-market radio but you most likely will lose the steering wheel volumn and track changing controls and the satellite radio interface as well.
    see post 21 above
    98jeep298jeep2 Member Posts: 1
    I have a 98 jeep grand cherokee limited. Factory stereo cd and tape. Might of happened when the battery connection came loose, not sure. The lighted button light up when the car lights come on and pressing the volume knob brings up the clock. Thats it. Will not turn on or accept CDs or tapes. Does not ask for a code. Any ideas?
    caradiodoccaradiodoc Member Posts: 4
    There's two fuses for your radio. The memory circuit is tied in with something else that stays hot all the time. Check the "radio" fuse if your radio acts exactly the same when the ignition switch is turned off. If the clock always shows "12:00", check for an inoperative horn, cigarette lighter, power outlet, or interior lights. If you find something that is dead, check the appropriate fuse. That circuit also feeds the radio's memory circuit.
    These cd / cassette combo units are made by Mitsubishi for Chrysler vehicles, and are extremely high quality. There are four common problems that occur to these models. When a dealer ships one to me, I address all four issues right away so their customers won't experience any of the other problems in the future. However, a dead radio is not one of these problems unless the UPS basketball team handles it; then the power supply board can be cracked when the radio gets dropped. If that happens, you won't have any display at all.
    I suspect you will find a blown fuse due to the bad battery connections. The rapid repetitive voltage spikes can pop a fuse from the charging of the memory circuits in the various computers on the vehicle. This usually results in no permanent damage other than the fuse.
    caradiodoc
    jag1049jag1049 Member Posts: 1
    FYI This may save someone some aggravation and a diagnosis bill from Jeep:
    My AM/FM portion of my 07 JeepGC worked fine but the SAT portion did not work. In fact it kept blinking on and off as if it were trying to find a signal. It appeared to be stuck on the last station that I used 184 and no volume. I tried some of the suggestions posted including disconnecting the battery but to no avail. I went on to my sirius radio account and treated the radio as if it were a new installation. I had a new activation signal sent and 5 minutes later my radio was working fine.
    cabinfeverkidscabinfeverkids Member Posts: 1
    I bought this from a neighbor last year. Radio works intermittently. Will work fine for 1 week then nothing for 4 months. No AM, no FM, no cassette, no light except the dim backlighting when running lights are turned on. I checked/replaced all fuses and even swapped with another like unit but had same issues. Previous owner said problem started about 10 years ago when he had car phone installed; phone has since been disconnected. Both radio wiring harnesses appear fine. Any ideas?
    davescoupedavescoupe Member Posts: 4
    Just picked up my new grand on friday i am impressed and i got a great deal with clunker program,it has the x package on it.... i wanted the navigation/rear camera group package but couldnt locate a jeep within a 500 mile radius with all the goodies on it.
    Can i have the nav-rear camera group package installed now or do you have to order from the factory that way. Thanks folks
    londonjeepgclondonjeepgc Member Posts: 1
    I recently bought a 2002 grand Cherokee. The RB3 satnav/radio is not working. I get power on the radio but all it does is display the word 'Jeep' and nothing else. This will last for a little while, then a red light flashes and the unit turns off. Does anyone have any suggestions on what I can do
    boomdiditboomdidit Member Posts: 2
    #1 thing that breaks down on them is the radio...Mine was two weeks in and had a little over a hundred mile son it. After the dealer switching them out four times. We installed a after market and have not had a problem ever since and also, recieved a sound that was ten times better by just changing the radio only. WOW And the price was cheaper for buying the new one and installation compared to what they charge us for the factory garbage ...even if it is infinity or factory...Major difference... I also, found out that Infinity only puts their name on it and they have nothing to do with manufacturing....WOW...
    There is no need to post the same message more than once. :)
    SUVs and Smart Shopper
    yorkie01yorkie01 Member Posts: 5
    We just bought a 1994 Grand Cherokee here in Germany.
    Our Radio just keeps telling us 'Please wait for 2 hr', then switching to 'wait'.
    This weekend we had to travel to York, UK and a guy told us that we have to reset the code, since it was entered incorrectly.
    Any hints where to go to reset it ?
    :sick:
    tuggajbtuggajb Member Posts: 646
    should be able to get code from jeep
    check the internet for radio codes will need your cearal number and pos barcode number off radio sould be able to get codes then
    Thanks for the reply.
    Unfortunately Chrysler Germany has no idea if they can get the code, since the Serialnumber is not in their list (E405....).
    The model number is : 5269488.
    Supplier: 26777
    Date Code: 1304
    Issue: 1
    Serial Nuber; E40510134
    Any ideas ?
    Cheers,
    I got the code.
    Are there any walkarounds to get rid of this 2 hour wait on the radio display ?
    Best Regards
    Michael
    :confuse:
    shoul be able to enter code and start right up without the wait
    Unotunately not. Had the Battery disconnected and took out the radio for the serial, brand, etc...over night.
    Starts always with "Please wait 2hrs", then switching to "wait"...
    I never had the car running for 2 hrs, so I can't say if it works then...
    Thank you anyway and kind regards from Heinsberg, Germany.
    Michael
    :cry:
    Would it be possible to use another radio in there ? :confuse:
    You could try it with the key on but without the engine running. Some Honda radios work that way.
    Here's the Volvo technique - maybe that'll help.
    link
    kyra9kyra9 Member Posts: 1
    Hi, I have exactly the same problem.
    I have given a bad code (because battery was low and I didn´t know something about code) My husband has a right code of course, but when I turn the radio on, there is wait for 2 hrs and then it switch to WAIT.
    I dont know how can I give the correct code now, I had tried it with engine off, but still nothing, still WAIT there :(
    pls could you help me?
    thanx katarina
    Katarina,
    I didn't have time to try it until now.
    I'll keep you posted.
    Regards
    Michael
    ronstlronstl Member Posts: 1
    My 98 GC has the original radio and recently only picks up 4 or so radio stations. It seems like there is no antenna attached to the radio. I pulled the antenna out of the fender well and everything looks good and connected but getting to the back of the radio was more than I was up to...
    The CD player works great as do all other features on the radio, just very poor reception.
    Has anyone come across this problem and can offer suggestions on what the problem could be?
    :confuse:
    abbottfabbottf Member Posts: 1
    Does anyone have a source for replacement bulbs for inside the radio. Went to dealer & the part nos are not listed in the radio diagram.
    chicken4chicken4 Member Posts: 1
    antena has a connector by the fuse panel under the glove box, take the connector apart and pull out the spring inthere then connect it back up, worked for my buddy believe me, if your radio just seeks and cant pull a station
    figue01figue01 Member Posts: 1
    The radio controls on the steering wheel not working
    tjhendietjhendie Member Posts: 1
    hi,
    the mode button on my 05 grand cherokee stopped working a few weeks ago, all the fuses r intact and all the other buttons on the radio work perfectly. battery died before the button stopped working, does anyone know how i could fix this or is it something a jeep dealer will have to fix
    happy75happy75 Member Posts: 2
    scott, did you ever determined what was wrong with you radio? i have the exact problem with my infinity gold (1994grand cherokee.) i even purchased a remanufactured radio and still have the problem. hopefully you have a answer if so please share. i have the door panels off but dont know what to do
    matt608matt608 Member Posts: 1
    I have a '05 Limited with the 6 disc changer with navigation. I got in my truck the other morning and the highs were the only thing that play music now. All my door speakers stopped working. I checked the fuse in the fuse box that was assigned to the amp and it was fine. The highs quit when i pulled it out. Does anyone know where the factory amp is physically located in the vehicle? Does anyone have any idea what this may be? Are there other fuses I should check?
    Matt
    bfdbeebfdbee Member Posts: 1
    did you ever get the cd player working, I have a 2005 with the same exact problem.
    rocostellorocostello Member Posts: 1
    I have a 2011 4X4 Laredo with the 430N radio. I have an intermittent problem which is annoying. Generally when I go around a corner, the radio turns off returning to the clock screen. Within 5 minutes the radio comes on again. I had the radio back to the dealer and there were no error codes. Has any one had a similar experience or know what is going on ?
    11jeepoverland11jeepoverland Member Posts: 1
    I am having the same problem on my 2011 overland. I turn left or right and radio shuts off, turns back on in about 20 seconds. It even resets my equalizer settings which is annoying the heck out of me. This seems to happen 1 or 2 times a day. I am taking it in for service tomorrow, hopefully they can fix what is wrong with it. If they find the problem, I will try to post their solution.
    jrmcarthurjrmcarthur Member Posts: 3
    I have owned this Jeep for over two years and been very happy with it. I purchased it used; it's a 1999 GC with a 6 cylinder. The previous owner had installed an aftermarket stereo, and I have since installed a new Sony unit after experiencing the following issues. My issue is this: The front door speakers would intermittently not work and now don't work at all. The remote door lock would ALSO intermittently work to unlock, but always lock. Now the remote does not work to unlock at all. BOTH of these events seemed to happen concurrently. I'm wondering if the passenger control module could be the source of my problem as the two seem to be part of both systems (at least according to what I read in the manual). I would appreciate anyone's input as far as a resolution for the issue is concerned. Thanks in advance!
