Mazda 323 Engine Problems
hey guys i have a problem with ma mazda 323 stalling which is od for automatics. i have put a new fuel filter in/ new spark plugs/ new air filter/cheecked my leads and distributor/ ive even had my batt tested and its fine. wot other things could cause this never ending mission 4 me? it also has new trans and engine head new tapet gasket/ new oil and filter and sump plug. in other words its been fully serviced and i still cant work out my situation. any help would be good. and do you now of any local mazda 323 groups in Lower Hutt Wellington NZ? Thanks
bought a mazda astina 1989.....
it has a problem....it doesnt seem to start very easily and sometyms takeas a long tym b4 it does.....sometyms it starts in a jiffy but sometyms no!!!
afta a run around the streeets i [non-permissible content removed] hme...turn the engine off...afta a while i go back start it again and it doesnt...
pump the gass while stating it and it does start afta a while....
got it checked...evrithing..fuel pump,injecter, evrithing...cant seem to work it out.....can nyone out there help me out......i need the car for work.....
...thanks ben
When idiling after being warmed up, the idles dont sound right! Maybe timing?? Vacum Leak?? Im a female so i am really puzzled, and i dont want to waiste money i dont have! Does anyone know how to check and find vacum leaks?? I got told brake cleaner sprayed lightly around the hoses will make the cars idle rev a little... I dont understand this?? Is there any other way?? Also i got told it could be air flow sensor?? Im puzzled... And yet when i compared to my m8s hatch gtx, all my hoses and plugs are jimmied up different!
When i am not thrashing it and using high rev's... It surges!! But when it goes, it goes real fast! Its got a TO4 Garet turbo, GSR Chip! Yeaha i luv my baby!
I just want to brainstorm what could be wrong, before it got parked up ... I had no problems...
Any help or advise will be appreciated!
I cant see the timing marks well enough with the timing light. which makes me wonder how the dealer technician could???......so i set it with a vacuum gauge. its not to factory spec or at least i couldn't say for sure...but the idle acceleration and shifting have all improved quit a lot. is there some tricks i should learn?
