Rocker Arm Gone Bad
I recently found a loose rocker arm on the front of my 02 Bonnie. I thought it was just a lifter tapping until I removed the valve cover and found a very wobbly and loose rocker arm. The push rod is loose to. My problem...do I have a damaged lifter or has the rocker arm gone bad.
Rr Susp; Lower; To Frame
$15.84
Found at rockauto.com. Drill through the choices for identifying your car and pick "suspension."
Go to a quality alignment and repair shop. They'll take care of it, including a recheck to see what the problem is for sure. I'm surprised the dealer doesn't want to do the parts.
