Dodge Caravan/Chrysler Voyager Engine or Oil Pump
dlucks1212
Member Posts: 2
We were driving on the freeway. I started hearing a knocking. Then the car died. No dummy lights came on all gauges were normal. After 30 minutes car started. Still could hear a knocking and started to over heat. We replaced the water pump and the radiator. Still knocking and overheating. Took to mechanic and they said we need a new engine. I was thinking a new oil pump and possible thermostate. I could even buy a new head gasket but I don't think it needs a total engine. Is this a good estimate?
Best Regards,
Shipo
Regarding the transmissions on these vans. While vans prior to 2001 used basically the same transmission as the one in your van, there were a number of differences, particularly the type of fluid used. The older vans came from the factory with ATF+3, a conventional transmission fluid that had roughly a 30,000 mile life, however, your van (and all vans since) came with new Group III synthetic oil based ATF+4. This new fluid is good for at least 100,000 miles (the factory fill in our 2003 has nearly 110,000 miles on it and it's still going strong), and along with the other revisions Chrysler made in the transmission, you should be able to get an easy 200,000 miles out of the transmission before it fails (if it ever fails at all).
A cautionary note on your transmission: A significant majority of the transmission failures on these vans can be traced to the fluid in the transmission. In fact, for a long time even Dodge, Plymouth, and Chrysler dealers refused to stock the "expensive" Chrysler fluid and used the "cheap" Dextron or Mercon fluids (both of which WILL cause a transmission failure within several thousand miles of their introduction into the transmission) as a means if increasing their profit. Fortunately the dealership base has been enlightened regarding this issue for at least the last decade, however, many service centers (iffy boob, Pep-Boyz...) still insist on using the GM or Ford fluid and then adding some magic elixir that allegedly makes it compatible with ATF+4 (NOT!). They can insist all they want, that crud ain't goin' in my transmission. Long story short, if you are going to have your transmission serviced, go to your dealer and have it done properly (i.e. a pan drop, a filter change, and a top off of new ATF+4). Do not, errr, let me say that again, DO NOT opt for a "transmission flush", there is considerable evidence that this type of service will kill your transmission as well.
Best Regards,
Shipo
I need to know how to remove the crankshaft timing pulley on a 1992 Camry. I want to remove the oil pump so I can take out the oil seal which is stuck.
Here is what I tried:
- tried using the two screw driver method to remove the seal after taking off the face of the oil pump. I was told it should come out easy but it is stuck.
- now I am attempting to take off the oil pump and see if I can just knock out the seal that way
Note: I don't have the special tool to remove the crankshaft pulley.
Question: Is there a way to remove the pulley without the tool?
Or is there a better way to achieve my objective(getting out the oil seal)?
I am not a mechanic but am not afraid to learn.
Can someone help?
Patrick
Best regards,
Shipo
You might want to consider asking your question over here:
http://townhall-talk.edmunds.com/direct/view/.ef0c3ff/1167#MSG1167
Best regards,
Shipo
